603,945 active members*
3,937 visitors online*
    Mar 2005
    8
    Cool Motor Direction
    When setting up a Rotary Converter, what impact will I have in the direction the 220 Rotary convertor motor is turning to the phase input to the Machine motor. Will it matter?
    Dec 2003
    24260
    The direction of the RPC will depend on what leg you have the start capacitor on, if you are using one.
    Otherwise, unless you have some 3 ph, direction dependant motors for e.g. then it will not matter.
    If inputing to drives and transformers it does not matter.
    The only thing to watch for is to make sure any 1 ph loads are on the 2 main 1 ph legs.
    Al.
    Albert E.
    Mar 2005
    8
    Thank you Al
  1. motor changing direction by iteself using picstep
    By oliverthepig in forum CNC Machine Related Electronics
    Last Post: 04-30-2007, 10:11 AM
  2. How to invert slave motor direction?
    By toolbox911 in forum Stepper Motors / Drives
    Last Post: 02-14-2006, 04:16 PM
  3. motor moves one direction: what am I missing?
    By boyvox in forum Stepper Motors / Drives
    Last Post: 10-11-2005, 12:43 AM
  4. Motor only moves one direction
    By spoiledbrat in forum Mach Software (ArtSoft software)
    Last Post: 06-12-2005, 07:02 PM
  5. motor direction
    By sixpence in forum Mach Software (ArtSoft software)
    Last Post: 12-29-2004, 05:15 AM
