588,174 active members*
4,893 visitors online*
IndustryArena Forum > CNC Electronics > Dmm Technology > Motor sizing for Bridgeport Rigid head cnc mil
Results 1 to 5 of 5
    Jan 2006
    204
    I am retrofitting a Bridgeport Boss R2E4 CNC Mill and I am wondering what size of AC servo motors I need to replace the old DC servo motors. this KW sizing has me all confused.....
    Bridgeport R2E4 Rigid Head cnc mill
    Powertron Permanent magnet dc servo motor
    Rated tourque 30 inch pounds
    Max voltage 146
    Max RMS Amps 14.6
    Max Pulse amps 58.3
    Frame C402-3
    Model # 402CNSpo572
    serial # 15347
    any help would be greatly appreciated
    Thank You
    archie
    Jan 2005
    15362
    Re: Motor sizing for Bridgeport Rigid head cnc mil
    Quote Originally Posted by jeep534 View Post
    Max voltage 146
    Max RMS Amps 14.6
    Max Pulse amps 58.3
    Frame C402-3
    Model # 402CNSpo572
    serial # 15347
    Thank You
    archie
    Does your mill have a 2:1 Timing Pulley Ratio, then with the Dmm 750w is all you need, I have used them at 1:1 Timing Pulley Ratio on the Boss machines, post a photo of your machine, what series machines do you have
    Mactec54
    Jan 2006
    204
    Archie's first cnc machine Bridgeport R2E4 Boss 9 to Mach 3
    and yes I have been messing with this thing since 2008
    Thank You
    archie
    Jan 2005
    15362
    Thank You
    archie
    Yes you have a series 1 you will be fine with the 750w motors
    Mactec54
    Dec 2011
    155
    Straight from the manual. This motor can't make 30lb-in at speed. The manual says the stock servos are 284 watts. Correct me if I'm wrong but the ac brushless servos make rated torque up to the rated rpm, with a flat torque curve like an induction motor, right? 400 watt ac servo may be a closer match to the original motors except for low speed and holding torque.
    That said, I think I'm going with 750 watt servo motors on my boss.
  1. Bridgeport boss 5 rigid ram head
    By pyroboby in forum Bridgeport / Hardinge Mills
    Last Post: 11-04-2013, 05:47 AM
  2. Bridgeport Knee Mill 9" X 36" Table 1 HP Motor Year 1962 J Head
    By mpickell in forum Bridgeport / Hardinge Mills
    Last Post: 03-11-2012, 05:39 AM
  3. Pulley size for Bridgeport 1J head motor replacemet
    By PhoenixMetal in forum Bridgeport / Hardinge Mills
    Last Post: 03-09-2010, 04:29 AM
  4. Rigid ram head rotation?
    By arsenix in forum Bridgeport / Hardinge Mills
    Last Post: 11-05-2009, 10:30 PM
  5. Tramming the rigid ram head - how? Need to R&R...
    By swarf_rat in forum Bridgeport / Hardinge Mills
    Last Post: 06-10-2007, 12:23 PM
