603,336 active members*
4,116 visitors online*
Results 1 to 9 of 9
    Nov 2008
    37
    Motor speed issues
    Hi everyone. I'm struggling a bit to get my motors running right. I'm running Mach 3, with a Gecko 540 and Kelling 48V power supply & motors on a Taig mill.
    I managed to calibrate everything fine, so each axis moves what it says it should when I ask it too. I tried some of the wizards in Mach 3 and they all seemed to work ok as long as the feed rate was high.
    My problems come when I tried to cut my first proper part. I generated the g code in meshcam and I was really conservative with the feed rates (didn't want to do any damage). It seems my motors just don't run at all if the feedrate is too low. By low I am talking about 4ipm (100mm/min). Surely I should be able to run the motors this slow?
    The part I test cut looks a mess. It's all of about the right dimensions but the circular pockets are all out of round, and the external walls are a bit chewed up where I'm guessing the mill has lost/gained steps.
    Any ideas why my motors stall at low speeds? Is this normal??? When I jog, if I set the reduced jog % too low then my motors don't move, but if I hold the shift key down they move fine.
    Thanks for any help guys!
    Rich
    Mar 2008
    3655
    Hi Rich!
    What Keling motors are you using? Have you tried adjusting the "trim" on the G540?
    CR.
    Nov 2008
    37
    I've got this package:
    G540 4 axis package (one G540 + Three KL23H276-28-4B( 1/4” Dual
    shaft with a flat) 270 oz-in + one KL-350-48 48V/7.3A 115V /230V
    power supply).
    Trim, no I haven't tried that. What does it adjust?
    Mar 2008
    3655
    Quote Originally Posted by rich_cree View Post
    power supply).
    You may not HAVE to adjust this. First, make sure your step/direction pulse width is set to 2 in Mach3.
    ADJUST: This trimpot adjusts the motor for the smoothest possible low-speed operation. Set the motor speed to
    about 1/2 revolution per second and then turn the trimpot until a distinct null is noted in the motor’s vibration. This
    will result in the most even microstep placement for a given motor and power supply voltage. The default setting for
    this trimpot is at ½ -turn and the setting for your motor will be within +/- ¼-turn of the default setting.
    CR.
    Nov 2007
    981
    Rich, I asked you a question about your issues here in your other thread but I see you haven't replied.
    Please have a look and see if that may be your problem:
    http://cnczone.com/forums/showthread.php?t=73778
    Dave
    Dave->..
    Mach3 "ports and pins": Set step "active high".
    Mach3 "motor tuning": Set step pulse width to "2" microseconds.
    In BIOS: Set parallel port to "EPP".
    Mariss
    May 2008
    45
    Does the trim pot turn all the way around without wrecking? I was trimming my motors with the g540 and now I can't get one of my motors to spin when the speed is low like .5 rpm. I don't know where the original spot was on the pot now. I know so stupid of me.
    Mar 2008
    3655
    CR.
    codevark,
    Did you see my post #6?
    Mariss
  1. 5.25 floppy motor issues
    By KsiR in forum CNC Machine Related Electronics
    Last Post: 05-10-2009, 11:33 AM
  2. X3 spindle speed issues
    By Legion99999 in forum Syil Products
    Last Post: 12-08-2008, 11:42 AM
  3. Replies: 13
    Last Post: 07-31-2008, 11:32 PM
  4. More Motor Issues
    By pzzamakr1980 in forum Benchtop Machines
    Last Post: 10-19-2007, 10:35 AM
  5. speed issues
    By sixpence in forum DIY CNC Router Table Machines
    Last Post: 09-19-2004, 02:28 AM
