603,371 active members*
3,844 visitors online*
Results 1 to 5 of 5
    Jan 2012
    23
    motor tuning in mach3
    I have one here...how is it that when I calibrate in the settings that all axis move superb...nice and fluid..absolutely spot on...but when I leave and do a test in mdi...they judder like bugger!! a have tried loads of different vel/acc...get it not too bad in tuning and then again go back and run in mdi and it kak again.....I run at 160 steps per if this helps ( oh, I do click save settings every time on each axis)
    I got 160 steps per...get 2000mm/min and 400 acc and it runs nice and smooth in x and y...save...go to mdi screen run a simple g0 code and it sounds juddery..def not fluid...even whenI jog it..go back to motor tuning and fine!!!....anyone help with this...when I then run a programme I seem to lose steps...
    Mar 2003
    35494
    Something is probably interfering with Mach3, either software or hardware.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Jun 2007
    3738
    Have you run drivertest.exe?
    Super X3. 3600rpm. Sheridan 6"x24" Lathe + more. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
    Jun 2012
    i have a vortech 5x10 i can`t it to run smooth
    Jan 2005
    15362
    topchippy1
    You did not say anything about the Zaxes, is that set up & power up to, or not, are you just working on the X & Y axes
    Mactec54
  1. Mach3 motor tuning question
    By kn6398 in forum Machines running Mach Software
    Last Post: 06-10-2014, 09:21 AM
  2. mach3 motor tuning
    By taigfraeser in forum Taig Mills / Lathes
    Last Post: 07-03-2010, 05:51 PM
  3. Mach3 , Config, Motor Tuning problem ( FILM OF MOTOR)
    By MDF_Markazi in forum Mach Software (ArtSoft software)
    Last Post: 04-30-2009, 08:15 AM
  4. Replies: 1
    Last Post: 10-17-2007, 05:16 PM
  5. Motor tuning under Mach3
    By BAustin in forum Charter Oak Automation Support Forum
    Last Post: 12-24-2006, 06:23 AM
