588,205 active members*
4,384 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Motor wiring/connector questions
    Dec 2004
    229
    I am thinking about how to wire my stepper motors on a cnc router build.
    I was wondering if it is a good idea to have cabling that disconnects at the driver box and the at the stepper motors (or at a panel on the cnc machine), kind of like how a guitar cable plugs into the guitar and an amplifier.
    Should I wire up connectors for all the motors on a panel that is on a corner of the machine? That way all of my cables to the driver box can be the same length and tied together.
    I think I will be using these cables and these 5 pin connectors:
    http://www.ramcorpwire.com/proddetai...able-AWG-+18-4
    http://www.probotix.com/cable_and_wire/
    It is a lot of extra cable for my needs, but the price per foot seems right and I will have extra for the next build.
    Any thoughts on how people have kept their cnc cabling tidy would be appreciated.
    Thanks,
    Dave
    Dec 2003
    24220
    Generally quick disconnect at the panel is in order for ease in machine shipping or moving, another option is 1/2" conduit flex strain relief, these can be obtained to suit all diameters of cable.
    They require a standard 1/2" conduit hole in the panel and once the cable is inserted, they are tightened to form a sealed entry in and secures the cable.
    On the servo/stepper end, again, it is usually is done to allow quick change out of a replacement motor.
    Also with less connectors, the less likely hood of connection/continuity woes.
    Al.
    Albert E.
    Dec 2004
    229
    Al, thanks for the info!
    Dave
  1. Fairly basic questions re stepper motor wiring!
    By HankMcSpank in forum Stepper Motors / Drives
    Last Post: 08-22-2008, 09:58 AM
  2. Y axis connector wiring
    By metalworkz in forum Syil Products
    Last Post: 05-28-2007, 02:45 AM
  3. Boss spindle motor wiring questions
    By moto21 in forum Bridgeport / Hardinge Mills
    Last Post: 03-30-2006, 05:13 AM
  4. 4-phase motor and wiring questions
    By DmitryZ in forum CNC Machine Related Electronics
    Last Post: 04-14-2004, 05:14 AM
  5. Stepper Motor Wiring Questions
    By TRC1 in forum CNC Machine Related Electronics
    Last Post: 08-16-2003, 03:03 AM
