603,946 active members*
3,164 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > motors requiring different voltages on same controller
    May 2004
    3
    I have a controller with G320's and a 55 vdc power supply that drives servos on a large machine. I would like to be able to share the same controller with a smaller machine with servos wanting only 36 volts. I suppose I could swap power supplies to motors as necessary, but I am wondering if there is a way to use the 55 volt power supply in both cases but limit the voltage to 36 volts when using the controller on the smaller machine. Also, in some cases I may want to use 55 volt motors and 36 volt motors on the same machine, so I'd really like to control the voltage going to each axis.
    Dec 2003
    24260
    I am not sure what the recommendation is for the drives you have, but the AMC drives I use they recommend a PS to be from 10% to 50 % higher than the rated motor voltage.
    And mention that higher voltage is nor normally a problem.
    http://www.a-m-c.com/content/support...ml#selection03
    Al.
    Albert E.
  1. Enable voltages on M1 pin 1
    By dodgy74 in forum CNC Machine Related Electronics
    Last Post: 01-04-2010, 10:35 PM
  2. This Motors + This Speed controller?
    By JMcDonald in forum Benchtop Machines
    Last Post: 10-01-2007, 04:46 AM
  3. Combining servo motors that have differing voltages ~ Question
    By RotorRouter in forum Servo Motors / Drives
    Last Post: 08-19-2005, 01:08 AM
  4. need new motors and controller
    By DAB_Design in forum CNC Machine Related Electronics
    Last Post: 09-08-2004, 03:57 PM
  5. Wish controller and step motors should I use....
    By Mikael in forum CNC Machine Related Electronics
    Last Post: 06-30-2004, 10:35 PM
