Originally Posted by
Mountaincraft
Well, this is fun...
After switching over to Linux, half my websites are broken..It seems everything is case sensitive...
So, seeing as sometimes I liked a picture to a folder called CNC using lower case in the link, and other times upper case, I have to build two separate folders, on CNC and one cnc and then move the pictures inot the appropriate one on a case by case basis.. not only that, but the problem goes another folder/layer deeper, so there will be at least 4 folders involved..
To make matters worse, CNC Zone will not let me edit old posts, which if they would, it would make life easy (I could just edit the links), but instead, I now have to view the 'page source' of each and every page and see exactly how the link was typed, and then make sure I have a path identical to that for it to find..
This is going to take a while to fix... I have to do it in other threads too...
So, I guess Every night or two, I'll pour a beer, sit down and fix a few more links... And some day, before I die, this thread as well as my others, will all contain the pictures it originally did...
:drowning:
Sux, I can't just go back and edit the original posts, as that would make it all brain dead simple....
As usual.. learning stuff the hard way....
Stuff broken in other forums too... Nice!
