I'm thinking about mounting these BT30 spindle with 90OD mm to X2. Do you think it is too big?
https://www.aliexpress.com/item/BT30...4-b32e5db2c49e
It won't fit. You would need to go with a new head entirely. Also note that the 90mm is the outside of the body, the flange is 126mm. I would consider selling the X2 and buying a slightly larger machine before trying to make a huge spindle fit on the X2.
I'd prob go with a PM25 size machine as a step up from the X2.
Most likely R8 spindle and TTS system for toolchanger option.
I wouldn't go MT3, needs a fair whack/pressure to get a tool out compared with the R8.
I'd like a PM30 size but it would be too heavy for me to convert.
