603,939 active members*
2,355 visitors online*
    Move from NCCOMMS to Predator
    I've recently bought new PC's and some new hardware/software called Predator DNC.
    We have 3 machine shops with various CNC machines with different controllers. I thought I would start on the smallest shop which was two Siemens 840D controllers.
    The old software was called NCComms made by a company called Camtek. The program is dated 1995 so it was well due to be replaced.
    However, I can't get Predator to work. The program sends but it doesn't end the transmit. If I stop the data transfer, it seems to lose data.
    I've replicated most of the settings from the old software, but in the Predator software there seems to be less options. Does anyone know what the settings are in Predator?
    Can someone point me in the right direction?
    Thank you.
    May 2004
    35
    Re: Move from NCCOMMS to Predator
    Hello,
    It sounds like the Send to CNC command you have created in the Predator Software for this machines needs a "Send Events" object to tell the CNC, you hit the end of the program. \027 or check your existing software for the ascii character and add that to the end of the program line in events.
    Also, if you purchased from a dealer, they should support you for this. If you don't have a support dealer, feel free to reach out to us. We are Predator's largest dealer in the USA.
    Should have no issues with Siemens 840 controller.
    Regards,
    Greg Mercurio
    Shop Floor Automations
    www.shopfloorautomations.com
    877-611-5825
    Greg Mercurio
    Shop Floor Automations, Inc.
    (619) 461-4000 Tel
  1. Replies: 0
    Last Post: 03-12-2016, 08:30 AM
  2. Replies: 2
    Last Post: 11-11-2015, 01:55 PM
  3. Replies: 1
    Last Post: 10-12-2015, 03:09 AM
  4. move to saved location or move a fixed distance
    By BikeCourse in forum Mach Mill
    Last Post: 03-21-2015, 03:06 AM
  5. predator missing menus-predator v7
    By ricowind67 in forum BobCad-Cam
    Last Post: 10-08-2012, 03:23 PM
