603,344 active members*
2,669 visitors online*
    Sep 2006
    83
    Moving Fadal 6030
    We are getting ready to move or 6030 in the next month or so. What exactly needs to be done before we do so. I know we should block up the Z axis somehow. Does anyone know a good procedure for doing so. Any tips are greatly appreciated.
    Aug 2005
    249
    You will need to locate or make two (2) locking bars for the counter balance. There are two (2) holes in the column casting. Jog the Z-Axis slowly while another person installs the locking bars thru the holes in the casting and the counter balance. I then jog the table near the back of the machine and centered in the X-Axis. If you do not have the original 'fixture' for locking the Z-Axis to the table you can use a 4x4 piece of wood about 8" to 12" long. Slowly jog the Z-Axis down to the wood or the locking 'fixture'. Be sure not to rest the Z-Axis on the spindle nose. I usually rest the Z-Axis near the bolt hole for the 'fixture' if I use the wood block method.
    The above is over and above removing the obvious items such as power, air, coolant tank, etc.
    Jeff
    Jeff Lange
    Lightning Tool & Manufacturing, Inc.
  1. Trade offs between Moving Gantry and Moving Table
    By gregmary in forum DIY CNC Router Table Machines
    Last Post: 04-22-2011, 07:48 PM
  2. Reman Fadal 6030
    By redman in forum Fadal
    Last Post: 11-23-2007, 08:31 AM
  3. Fadal 6030 spindle chiller
    By 5th-axis in forum Fadal
    Last Post: 10-24-2007, 12:55 PM
  4. Fadal 6030 tools stuck
    By envisioneng in forum Fadal
    Last Post: 09-06-2007, 01:49 PM
  5. Moving Table vs Moving Gantry; Dremel vs Router
    By chuckknigh in forum DIY CNC Router Table Machines
    Last Post: 03-28-2007, 02:48 AM
