hi there
got a question but i don't know if it is possible to do. in the attached drawing is a very basic drawing of a rear suspension. heres the question, is it possible to move the objects in the drawing (upper link,lower link,rear end)as one unit while maintaining the two chassis pivots as base points and keeping the the length of the upper and lower links fixed so that the rear end would follow the links all as one unit? basically cycle the suspension to check pinion angle, plunge etc. i've been having to do each part individual (rotate,move,rotate, move, etc) to extended, mid, compressed to check it now. hopefully that makes sense, most of the time it does in my head but getting it out of there isn't always the easiest.
thanks
bear
i have autocad 2005
All work and no play makes jack a dull boy!
