Yes you can using the WCS in V9 but the hole drawing 2d profile make it a 3d model and use WCS for all the different sides and varify them all together and see the hole part after all you paths.
The only issue here is most do not run V9 anymore. I do not as it will not run on Win7 64bit and there is no reason with the newer version. but never the less you are running it. I may still have some were a video I did for V9 wcs years ago/ I will look later if I do I will post it.
Cadcam
Software and hardware sales, contract Programming and Consultant , Cad-Cam Instructor .
