587,625 active members*
3,322 visitors online*
Results 1 to 5 of 5
    Oct 2007
    19
    MRj2-100-CT Turret Unit
    Dear all,
    mazak QT200 all condition ok ( x,z axis and spindle are normal ) except the turret unit can not rotate when give command, on mrj2-100-ct unit led show B1, as far as i know when normal condition must have C1 code on unit. tq
    Jul 2009
    Quote Originally Posted by andra View Post
    Dear all,
    Hi Andra,
    are you sure it is B1? Not 61?
    If 61 it means reference point return unfinished.
    What about backup battery?
    You should run Mitsubishi software and check Alarm Display screen.
    Tell me actual alarm please.
    Bye, Gabor
    Oct 2007
    19
    Dear gbezzegi,
    sorry for late reply, on unit show b1 not 61. On mr-j2 setup software not have alarm.:drowning:
    Jul 2009
    Dear Andra,
    may I ask you to take a picture about your drive please?
    In my manual there is no alarm B1.
    Thank you!
    Gabor
    Dear gbezzegi,
    Oct 2007
    19
    dear Gabor,
    following the instruction manual, this condition not indicate have alarm, but have incomplete initialization when start up, something like waiting some signal for make the unit in ready status, i look on diagnosis monitor on mr-j2 setup software SA & RDY output signal is turn off, i try to replace with other unit still same.
    Attached Thumbnails Attached Thumbnails Foto0115.jpg   Foto0116.jpg   Foto0117.jpg
  1. MRj2-ct setup software
    By terra103 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-19-2018, 01:16 PM
  2. Configuring steps/unit.....what unit?
    By HereinCS in forum Mach Software (ArtSoft software)
    Last Post: 03-08-2011, 02:57 AM
  3. FANUC 15-MA Battery unit & I/O unit etc
    By gbowne1 in forum Fanuc
    Last Post: 05-05-2010, 02:47 AM
  4. Tool Turret Fault Alarm on TL-1 with no Turret?
    By Edster in forum Haas Lathes
    Last Post: 02-08-2010, 03:35 PM
