588,348 active members*
6,164 visitors online*
Results 1 to 4 of 4
    Aug 2008
    36
    Multi fixture issues
    I try to setup a part for multiple part machining, and Featurecam is not cooperating. I follow the steps, to use existing files, setup the fixture offsets, the multiple pieces, by adding files as the help menu says. But not all of the geometry comes in the new file. Just a couple features, and no solids. And I cant import any other data. This is my first time doing a multi setup, so not sure on this one.
    Aug 2008
    36
    I think its supposed to be this way now that i have messed with it more. It uses a main file that is existing for all modeling and programming, and loads it into the multi file program. This allows the user to only modify one model or program, and reload it into the multi setup. The solid model is purpopsely not brought into the file so that you cant change it. It forces you to change the main file.
    Just an FYI
    Jan 2005
    49
    Mf files
    I to find that you cannot edit mf files so you must make the main fm files are correct before importing them into multi fixture control
    Aug 2008
    36
    Ive noticed that. Its nice really. Im running three of the same part on my VF2.
    And when I need to make a change, i only have to change one, and reload it. Pretty simple control method if you ask me! I havent used Mastercam, since X2, but i dont think that has anything like this.
  1. Multi-part Fixture with Single Point Clamping
    By Geof in forum Work Fixtures / Hold-Down Solutions
    Last Post: 08-22-2011, 03:13 AM
  2. Multi Cam MG 308
    By Pocock1 in forum Commercial CNC Wood Routers
    Last Post: 01-20-2011, 08:14 PM
  3. Fixture for PVC sheet
    By turbo2ltr in forum Uncategorised MetalWorking Machines
    Last Post: 12-16-2009, 02:19 AM
  4. fixture offsets
    By beartrax in forum G-Code Programing
    Last Post: 11-15-2008, 01:19 AM
  5. Vacumm Fixture
    By SPEEDRE in forum DIY CNC Router Table Machines
    Last Post: 11-24-2005, 05:15 AM
