603,848 active members*
4,397 visitors online*
    Jan 2007
    7
    multicam & G-code?
    Hello,
    I am a Mach3 user trying to help a multicam owner cut some 3D pieces. They are only doing 2D cuts using enroute & plt format.
    I m trying to send a G-code to the machine generated from Visuamill but I get "unkown format" error on the pendant.
    What am I doing wrong? do i need to pass the G-code through a translator to be recognized by the machine?
    Thanks !
    Apr 2003
    67
    my multicam router requires a .cnc format
    ie. filename.cnc
    if it is a g-code .gc, try renaming it with .cnc
    also, you may need m-codes for the spindle
    if you have enroute available use the post processor to create the machine code.
  1. Need Help with MultiCAM
    By loyedp in forum Multicam Machines
    Last Post: 11-09-2021, 07:12 PM
  2. Getting Multicam to use G code
    By peterdewstow in forum Commercial CNC Wood Routers
    Last Post: 12-09-2016, 03:36 AM
  3. Multicam MG
    By Dropout in forum Commercial CNC Wood Routers
    Last Post: 10-18-2010, 08:26 PM
  4. Multicam mg204 error code 9742
    By japco43 in forum DNC Problems and Solutions
    Last Post: 06-11-2010, 04:53 PM
  5. multicam MG 205
    By patrick kilby in forum WoodWorking Topics
    Last Post: 11-02-2008, 08:00 PM
