587,319 active members*
3,389 visitors online*
IndustryArena Forum > CAM Software > Mastercam > multiple work offsets
Results 1 to 5 of 5
    Aug 2011
    121
    I am using Mastercam X6 and was wondering how to repeat a set of toolpaths in a g55 location or multiple g5x's. I have a large 84" table and multiple vices and would like to utilize it a bit more. Would I use transform toolpath?, or something in each toolpaths parameters
    May 2004
    4519
    Use a different WCS for each location. Set work offset to 0 for G54, 1 for G55, and so on.
    Apr 2005
    713
    You can set Transform to use different work offsets for each location. Just mess around with it, or do as Tx said, but that would require a new group and set of toolpaths for each location, wouldn't it?
    For what you're doing, G52 works really well if your control supports it. With Haas, you set your G54 in one spot on the fixture, then use G52 to shift that work offset to all your locations. I like it because you only have to locate one position for G54 versus probing ALL of your fixture locations every time you setup.
    Dec 2008
    3124
    Both replies would do what you are wanting.
    Using a WCS for each location
    - major problem with larger files - if needing to modify your toolpaths, you have to have your brain turned ON to know what needs altering
    Using Transform
    - initial problem is getting the correct boxes checked,
    - best method, as the toolpath ops are singlur, modify one op, & it is carried through in the transform ops
    - there are many features in transform, don't be disappointed if it isn't what you need, it's probably 1 or 2 items not being set correctly
    ( hint, "ghost" can be used to not post the actual operation, and let the transform op output NC code in the correct order )
    Aug 2011
    121
    Thanks for all the help. I will try and learn both ways. I mainly use only 2.5D prgms from ACAD wire frame drawings so i don't have much practice moving WCS's around, but i should learn. I have messed with transform a bit, and it was a pain the first few times using the 4th axis (so many oddly worded check boxes)
    Also i remember support changing the Misc. value for (lock on first WCS) from 0 to 1 which 0=no, 1=yes. This apparently made things easier for 4th axis programming. Will this effect what im trying to do now? Any idea where to go to change this back? He made the change in a place other than under parameters to hold the value of 1, permanent
  1. How to: Multiple work offsets?
    By GM81 in forum Mastercam
    Last Post: 10-18-2011, 05:26 PM
  2. Using multiple work offsets in MC
    By Crashmaster in forum Mastercam
    Last Post: 08-25-2010, 04:18 PM
  3. Multiple Work Offsets
    By 9 1/2 in forum Mastercam
    Last Post: 11-15-2009, 11:28 PM
  4. Multiple Work Offsets
    By PinMan in forum BobCad-Cam
    Last Post: 06-06-2008, 10:41 PM
  5. multiple work offsets
    By rbest27 in forum Surfcam
    Last Post: 01-25-2007, 10:02 AM
