603,884 active members*
5,929 visitors online*
Results 1 to 5 of 5
    Feb 2009
    MV-JR parameter??
    Hello, I have a jr with a 10m fanuc control. I need some help turning on my rpm meter in the control. In position and program check, it will read the actual rpm but not actual. I just went thru the spindle drive and had it rebuilt. Had an issue with my m3 and m4 rpms not the same. Adjusted it in the pots as close as I could but would like to get my actual reading on the screen. Thanks so much! Mike
    Mar 2009
    do you have a copy of the manuals I have the same machine but no books! Let me know.
    559-281-2462
    Doug
    Jun 2010
    Hello, I have a moriseiki mvjr with a 10m fanuc control and AC servo motor. I need some help.I lose my nc parameter and plc parameter also. can you send parameter list? Thank you so much
    BY VEL
    Sep 2007
    371
    Machine1956.
    Do you have the spindle encoder connected??? I have a Mori Junior fanuc 10M I can send you a copy of parameters if you want. I just need to make a backup 'cause I can't find the one I have.
    Greg.
    Oct 2007
    6
    If you can provide the serial number and drawing number from the wiring diagram I probably have the factory list for that specific machine.
  1. parameter ?
    By KENNETH BROWN in forum Fanuc
    Last Post: 03-12-2008, 01:23 AM
  2. parameter
    By davek in forum Fanuc
    Last Post: 11-08-2007, 02:45 PM
  3. dnc parameter help
    By shepherd in forum DNC Problems and Solutions
    Last Post: 06-27-2007, 06:28 AM
