Originally Posted by
rowbare
HP is a function of torque and speed. It is a measure of power i.e. how much work can be done in a given time. In our case, it is normally rated in how many cubic inches of metal can be removed in a minute. You can find tables listing the Metal Removal Rate for various metals expressed in cubic inches per minute per HP. A 1 HP 1000 rpm motor will remove as much metal as a 1 HP 5000 rpm motor. However the conditions under which it will do so are different.
Changing speed via mechanical reduction is very different than changing speed with a VFD. When changing speed mechanically, the motor stays at its rated speed and will therefore will put out its rated power (minor mechanical losses aside) at all speeds. The metal removal rate remains the same since the power is the same.
Now using a VFD is a different story. An AC motor under VFD control can be treated as a constant torque device under its rated speed and a constant power device above. Thus if you run a 3450 rpm 1HP motor at 1725 rpm, it will be putting out 1/2 HP. Run it at 4500 rpm and it will put out 1HP albeit at reduced torque. At half speed, it can remove half as much metal as it can at its rated speed or higher.
