bob - thanks for hooking up the g-wizard demo.. should be helpful, although it seems that my rpm max is too slow :P
hey jeff,
i guess it's a matter of some trials and figuring out if it's worth the cost.. i figure compared to everything else, the machining and stock cost of aluminum is cheap compared to the machine/ballscrews/drivers/servos/steppers... but i guess waste is frustrating and adds up =)
what does everyone think of the enclosure setup, most specifically the bolting system? it'll be a 10" length 1/2" bolt with washers (do i need lock washers or compression springs?)... the enclosure is plywood/fiberglass.. the wooden box underneath the mill is a crowded 2x4 (vertical) frame with 5/8" plywood all around. i'm just wondering if i need to silicone the pucks in? or will the weight and compression block most of the coolant? i've pretty much built the enclosure base and fiberglassed it (been staying up way too late working on this stuff)
and what about this for a pump? i'm thinking about approx 12 feet of "pipe" and tubing.
http://www.homedepot.ca/webapp/wcs/s...k=P_PartNumber
Matt
