603,848 active members*
4,567 visitors online*
IndustryArena Forum > CNC Electronics > Leadshine > MX3660 - Correct wiring for limit switch sensors ?
Results 1 to 4 of 4
    Feb 2014
    25
    I have a 3 axis CNC with 4 total sensors, the Z has it`s own sensor, the X has it`s own sensor & the Y shares 2 sensors. I`m trying to figure out the wiring into the MX3660 as well as the external 12v DC plug.
    In the Leadshine mx3660 manual shows the sensors go to:Input 1,2 & 3.
    Example for machine with 4 sensors:
    Input 1 (X axis)1 black wire
    Ground: Blue wire
    Input 2 (Y axis) both black wires together
    Ground: Blue wire
    Input 3 (Z axis) 1 black wire
    Ground: Blue wire
    But there is no info showing the other +12v wire from the limit sensor. There is also no other info about what to do with the external 12v plugs (-) wire.
    I have heard on another forum that you only need to connect the black wire from the sensors to the 3 separate Inputs, and nothing goes into the MX3660 Ground
    and then wire the 4 Brown wires to the external 12v + wire and the 4 Blue wires from the sensor goes to the external 12v- wire.
    Or does something else need to me connected to the Ground for the sensors to work?
    Is there anyone who can help me with this?
    Jun 2013
    445
    Re: MX3660 - Correct wiring for limit switch sensors ?
    It sounds like they are proximity sensors if you put a picture up someone will be able to help you. NPN I have attached the wiring diagram for. Common ground and 12v supply from your board, black to input pins. When activated the sensor will provide a ground to the input pin. I also dont know how your setup is wired, but you may need to put a resistor into the circuit, the proximity sensors often max out at 300ma. What this means is they will work for a short time if at all before not working.
    Feb 2014
    25
    Yes, they are definitely proximity sensors.
    Thanks for your response, it is helpful, but I still don`t understand how the wiring goes as far as the GRND connections go with the MX3660, I think I need a more layman's instructions.
    Feb 2014
    25
    Thank you for your help.
    Yes, I have NPN NO proximity sensors on my CNC.
    I understand in the schematic that the Black goes to the "Input" ( 1,2,3) of the MX3660.
    But does this mean the "Ground" from the MX3660 goes out to connect to the (+) Brown line?
  1. HELP WITH WIRING PROXIMITY SENSORS AS HOMING AND LIMIT SENSOR
    By Mr.Chips in forum CNC Machine Related Electronics
    Last Post: 05-13-2023, 09:25 PM
  2. Limit Switch Wiring
    By Ron2d in forum Benchtop Machines
    Last Post: 07-17-2016, 03:59 PM
  3. Mx3660 limit switch input voltagee
    By naspc in forum Leadshine
    Last Post: 06-26-2016, 04:23 PM
  4. Limit switch wiring
    By rstrease in forum Gecko Drives
    Last Post: 04-17-2015, 05:02 PM
  5. Limit Switch Wiring
    By The Speaker Guy in forum CNC Machine Related Electronics
    Last Post: 01-07-2007, 11:11 AM
