587,822 active members*
2,982 visitors online*
IndustryArena Forum > CNC Electronics > Leadshine > MX4660 troubleshooting
    Jan 2015
    27
    About one month ago I test drove my steppers with the MX4660, UC100, and Mach 3. I went to do the same exact thing today and the steppers will NOT move. I confirmed with a scope that I have step and direction pulses coming to the DB25 connector on the MX4660, but no motors will move no matter what I do. Does this mean my MX4660 is dead?
    Jan 2015
    27
    Re: MX4660 troubleshooting
    Ok I fixed it. Apparently I had to put the "charge pump" switch to the ON position. I didn't mess with this switch since I last checked things out, but I think Mach3 was set to enable charge pump remotely, and somehow in Mach3 I turned that off. I can't see anywhere in the software to control that though.
    Jun 2004
    6618
    It's called the Watchdog on the general settings page. Over to the right.
    Lee
  1. MX4660 Power questions
    By JSantars in forum Leadshine
    Last Post: 02-13-2017, 02:20 PM
  2. Replies: 9
    Last Post: 08-30-2015, 01:23 AM
  3. MX4660 kit
    By Bryan Rocker in forum Leadshine
    Last Post: 07-20-2015, 03:55 PM
  4. MX4660 Capacitors
    By ringram2077 in forum Leadshine
    Last Post: 07-19-2015, 02:56 PM
  5. Nema34 electronic for a 48x60 build with Leadshine MX4660 and KL34H260-60-4A
    By javabugz in forum DIY CNC Router Table Machines
    Last Post: 10-16-2014, 04:21 PM
