603,347 active members*
2,873 visitors online*
Thread: my build :)
Results 1 to 8 of 8
    Dec 2013
    13
    my build :)
    here is my build " i have never done such a thing before by the way"
    Dec 2007
    2133
    Re: my build :)
    Great job, there's not a lot of things that are cooler than having a CNC machine! Rolling your own spindle too, that's impressive, and not a simple task by any means. Those bearings though kinda look like normal radial bearings? Are they radial or AC's, as normally they'd be pairs of annular contact bearings to stop vertical movement of the spindle. Same as what you'd use for the drivescrews.
    Congrats on the build though, looks like your off to a flying start!
    cheers, Ian
    It's rumoured that everytime someone buys a TB6560 based board, an engineer cries!
    Dec 2013
    13
    Re: my build :)
    the bearings are normal exept the upper is contact. the spindle has a oil seal at the but and filled with transfergear case oil for lube
    Dec 2013
    13
    Re: my build :)
    Heii.....
    here we producing most advance,reliable Hydraulic drive shaping machine,cone Pulley drive Shaping Machine with Automatic Lubrication System,Screw press,Hydraulic press at reasonable price across India with reasonable cost.
    Contact Us: 9872891455
    Address:G.T.Road, Miller Ganj, Ludhiana.
    Apr 2013
    1916
    Re: my build :)
    Quote Originally Posted by havnerotte View Post
    Cool project, but that spindle looks like it weights a ton... so you will need powerful steppers.
    Dec 2013
    13
    Re: my build :)
    Dec 2013
    13
  1. Build Thread - 80/20 5X10 Woodworking CNC Build
    By jsantos in forum CNC Wood Router Project Log
    Last Post: 08-20-2014, 03:15 AM
  2. Replies: 3
    Last Post: 01-05-2013, 05:24 AM
  3. Mint's Build Aluminum/Steel Build thread.
    By FreshMint in forum Maintenance DIY Discussion
    Last Post: 10-31-2011, 04:18 AM
  4. Newbie - To build or not to build Router/Plasma Table
    By dfranks in forum Waterjet General Topics
    Last Post: 04-08-2011, 05:16 AM
