603,832 active members*
4,324 visitors online*
    Jan 2005
    19
    Talking My CNC Machine and Questions
    Hello! I joined this site last nite so I thought I would post some photos and ProE images of my CNC machine I have been putting together over the past five months. I am to the point of testing my electric system and motors so that is why the latest photos show the machine disassembled. I am having problems at the moment firing up the motors. I suspect an electrical connection problem. I am using a SP3 stepper motor setup from StepperWorld. The machine I am building is called the 7th Sojourn. It uses a Dremel tool for cutting and construction is fairly straight forward and simple. I thought it would be a good way to get my feet wet in CNC. The good thing about my first machine is that I figure total cost to get the machine completed and up and running will only be around $500. Anyway if anyone out there has experience working with the SP3 motor and circuit setup I could use any advise you have to getting mine up and running. Enjoy the photos I'll send more as I progress. Dave
    Attached Thumbnails Attached Thumbnails cnc_machine.jpg   CNC6.JPG   CNC10.JPG   CNC13.JPG
    Mar 2003
    6855
    Very nice machine, are you still have trouble with your stepper motors?
    Oct 2003
    399
    I like the table! Did you mill those pieces or are they some kind of standard part that can be bought?
    Arvid
  1. Maho MH600E Milling machine questions???
    By marx911 in forum Uncategorised MetalWorking Machines
    Last Post: 01-23-2009, 07:51 PM
  2. My First CNC Machine, Mr. Chips
    By Mr.Chips in forum DIY CNC Router Table Machines
    Last Post: 02-10-2007, 04:04 PM
  3. Questions - Micro CNC router?
    By DarkWolf in forum DIY CNC Router Table Machines
    Last Post: 10-22-2004, 03:24 PM
  4. More Beginner CNC Mill Questions - Please Help!!
    By 8SECNOTCH in forum Benchtop Machines
    Last Post: 09-17-2004, 05:29 PM
  5. Hardware Setup Questions for New CNC Machine
    By tpicker1 in forum Benchtop Machines
    Last Post: 05-04-2004, 03:43 PM
