Hi guys
Thought I would share my first real part on my very new 1100
Keep in mind that I am a very noob at maching - but a bit of a wizz at computers (that's my day job)
It's a door catch for the delux stand - the front door as supplied was a bit out of spec and the catch did not engage with the frame.
So I thought - what a good first real part
The process is
1. Draw it up in SolidWorks 2012 - that took 10mins 'cos I have already climbed that learning curve
2. do the CAM in Sprut - that took 2 days 'cos still in the foothills of that learning curve
3. cut metal!!!!
Attached are some pics
the solidworks dump is the part in solidworks
then some machining in some scrap - actually from a computer case - 3mm steel of some sort.
(a) is the first attempt - not too good - clamped the whole 18" length at the ends and it was bouncing - learnt about clamping from that
(b) oops - got the feeds and speeds from GWizz and did it with no coolant - doing it step by step wanted to do a simple part first to see if all worked and then put on the delux stand drip trays and link up the coolant.
within 1" the whole thing got cherry red and chips welding themselves to the cutter (1/4" HSS 4 flute center cutter) - quick bang on the EStop and reach for the extinguisher just in case. - learnt about coolant from that.
(c) Got it all together and did it - the top is as finished the bottom has been separated and the tabs cleaned up - and the door now closes :}
Peter
