603,884 active members*
5,380 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > My first piece, is there a better way to do it?
Results 1 to 14 of 14
    Jul 2006
    741
    Hi
    I'm doing my first piece in BobCad v21.5.3 and I'm not sure if there are better ways to do it.
    The first picture is a rendering of the piece, actually doing 2 work pieces from one piece of stock. They are 5x3.5x1 on Nylon 6. The second picture has all the auxiliary lines I need still done in Autocad (easier to do them there because of osnap, etc.). The 3rd picture is the import on BobCad after I added the points to use for drilling (done using Point/Intersect on the imported construction lines).
    So far I generated the G-code to drill the holes and now I'm working on the pockets. BTW the through holes are peck holes, just to give it a try and see if my mill does them.
    Code:
    // small thru holes
    M5
    M9
    G0 G28 G91 Z0.
    T1 M6
    S0 M3
    G90 G54 X0. Y0.
    G43 H1 D1 Z3.
    M8
    G73X-0.875Y3.75Z1.2R-.1Q.4F25
    X-2.5Y3.825
    X-4.125Y3.9
    Y1.1
    X-2.5Y1.175
    X-0.875Y1.25
    X1.625Y1.1
    X3.25Y1.175
    X4.875Y1.25
    Y3.75
    X3.25Y3.825
    X1.625Y3.9
    G80
    // countersunk holes
    M5
    M9
    G0 G28 G91 Z0.
    T2 M6
    S0 M3
    G90 G54 X0. Y0.
    G43 H2 D2 Z3.
    M8
    G81X-0.875Y3.75Z.25R-.1F25
    X-2.5Y3.825
    X-4.125Y3.9
    Y1.1
    X-2.5Y1.175
    X-0.875Y1.25
    X1.625Y1.1
    X3.25Y1.175
    X4.875Y1.25
    Y3.75
    X3.25Y3.825
    X1.625Y3.9
    G80
    Now, here it comes...
    In order to make a pocket it seems I have to do 3 operations being careful not to mess up.
    1) Rough in the pocket lying about the tool diameter (say it is 0.51 instead of 0.50) and select an artificial Z (-0.745 instead of the pocket bottom at -0.75) so that the rough box is within the finishing box by 50 mils (or less if you want). Since my pocket bleeds into the piece perimeter the wire frame boundary is slightly larger than the pocket itself in the side it bleeds over. That is the light blue line in the attached.
    2) Then you do the contour telling BobCad the real diameter of the tool (0.50) and the real depth (-0.75). The contour uses the same light blue line as the boundary in the previous step. However, since we lied about the tool diameter then we get to finish it now.
    3) Lastly you finish the pocket bottom at the real depth (-0.75), but with a fake tool diameter (0.51 instead of 0.50) so we do not touch the finished walls.
    Am I going in the right direction?
    Comments, suggestions?
    Thanks!
    Jul 2006
    741
    I did the 1st step, that is the roughing, but there is an awful lot of plunging. See the picture and commented g-code attached.
    Code:
    // roughing
    Y1.505
    G01Z-0.2483F25 // real plunge to begin 1st pass
    X0.3698
    X1.9343Y1.735
    X0.33
    Y1.965
    X2.5601
    X2.5939Y1.9782
    Z0.             // going up to top of material
    X3.1488Y2.195	//   - traversal scratching top of material
    X3.1356         //   - traversal scratching top of material
    Z-0.2483        // plunging back
    X0.33
    Y2.425
    X3.897
    X3.8975Z0.      // going up to top of material while traversing 5 mills in X
    X3.909          //   - traversal scratching top of material
    X3.9064Y2.4269  //   - traversal scratching top of material
    X3.5919Y2.6513
    X3.5866Y2.655   //   - traversal scratching top of material
    X3.5794         //   - traversal scratching top of material
    X0.33
    Y2.885
    X2.93
    X2.9194Y2.8893  //   - traversal scratching top of material
    X2.3536Y3.115
    X0.33
    Y3.345
    X1.6164
    X0.3698Y3.495
    X0.33
    G00Z0.1         // going up to rapid plane
    Y1.505
    G01Z-0.4967     // real plunge to begin 2nd pass
    X0.3698
    X1.9343Y1.735
    X0.33
    Y1.965
    X2.5601
    X2.5939Y1.9782
    Z-0.4967        // plunging back
    X0.33
    Y2.425
    X3.897
    X3.5919Y2.6513
    X0.33
    Y2.885
    X2.93
    X2.3536Y3.115
    X0.33
    Y3.345
    X1.6164
    X0.3698Y3.495
    X0.33
    Y1.505
    G01Z-0.745      // real plunge to begin 3rd pass
    X0.3698
    X1.9343Y1.735
    X0.33
    Y1.965
    X2.5601
    X2.5939Y1.9782
    Z-0.745         // plunging back
    X0.33
    Y2.425
    X3.897
    X3.5919Y2.6513
    X0.33
    Y2.885
    X2.93
    X2.3536Y3.115
    X0.33
    Y3.345
    X1.6164
    X0.3698Y3.495
    X0.33
    G00Z0.1         // going up to rapid plane and... DONE!
    What am I doing wrong?
    Jul 2006
    741
    Okay, I think I figured out what is happening. The curve is convex in certain areas (see attached) and the path is not smart enough to (a) use an arc, or (b) offer an option to stop short or (c) really clear the material before traversing.
    Bummer, I'll try the spiral.
    Jul 2006
    741
    Hmmm... spiral kinds of follow the outside contour, but it is worse since you have a lot more ups and downs and the generated code is much larger.
    Code:
    Z0.505
    X-4.7295Y2.2456
    G01Z0.005F25
    X-4.4633Y2.2842
    X-4.0209Y2.395
    X-3.7272Y2.5
    X-4.0209Y2.605
    X-4.4633Y2.7158
    X-4.7295Y2.7544
    Y2.2457
    X-4.6964Y2.018
    X-4.4187Y2.0583
    X-3.9541Y2.1746
    X-3.485Y2.3423
    X-3.0959Y2.5
    X-3.485Y2.6577
    X-3.9541Y2.8254
    X-4.4187Y2.9417
    X-4.8943Y3.0108
    X-4.9595Y3.0139
    Y1.9861
    X-4.8943Y1.9892
    X-4.6965Y2.0179
    X-4.6634Y1.7903
    X-4.3742Y1.8324
    X-3.8873Y1.9542
    X-3.403Y2.1274
    X-2.9041Y2.3296
    X-2.8881Y2.3357
    X-2.4378Y2.5
    X-2.8881Y2.6643
    X-2.9041Y2.6704
    X-3.403Y2.8726
    X-3.8873Y3.0458
    X-4.3742Y3.1676
    X-4.8722Y3.24
    X-5.1895Y3.2551
    Y1.7449
    X-4.8722Y1.76
    X-4.6634Y1.7903
    X-4.6303Y1.5627
    X-4.3296Y1.6064
    X-3.8205Y1.7338
    X-3.3211Y1.9124
    X-2.8177Y2.1164
    X-2.8093Y2.1196
    X-2.7971Y2.1241
    X-2.7966Z0.1913
    X-2.3009Y2.3052
    X-2.3004Z0.005
    X-2.2938Y2.3077
    X-2.276Y2.3135
    X-2.2621Y2.3175
    X-2.2616Z0.1913
    X-2.0247Y2.3849
    X-2.0242Z0.005
    X-2.0111Y2.3887
    X-1.9946Y2.3928
    X-1.9838Y2.3951
    Z0.1913
    X-1.7359Y2.448
    Z0.005
    X-1.725Y2.4503
    X-1.7058Y2.4536
    X-1.6971Y2.4548
    Z0.1913
    X-1.4419Y2.4891
    Z0.005
    X-1.4332Y2.4903
    X-1.4111Y2.4923
    X-1.4046
    Z0.1913
    X-1.2478Y2.5
    X-1.4041Y2.5074
    Z0.005
    X-1.4111
    X-1.4332Y2.5097
    X-1.4411Y2.5108
    Z0.1913
    X-1.6968Y2.5452
    Z0.005
    X-1.7058Y2.5464
    X-1.725Y2.5497
    X-1.7355Y2.552
    X-1.736Z0.1913
    X-1.9834Y2.6048
    Z0.005
    X-1.9946Y2.6072
    X-2.0111Y2.6113
    X-2.0244Y2.6151
    Z0.1913
    X-2.2617Y2.6825
    Z0.005
    X-2.276Y2.6865
    X-2.2938Y2.6923
    X-2.3006Y2.6948
    X-2.3011Z0.1913
    X-2.7966Y2.8757
    X-2.7971Z0.005
    X-2.8093Y2.8804
    X-2.8177Y2.8836
    X-3.3211Y3.0876
    X-3.8205Y3.2662
    X-4.3296Y3.3936
    X-4.8502Y3.4692
    X-5.3811Y3.4945
    X-5.4195
    Y1.5055
    X-5.3811
    X-4.8502Y1.5308
    X-4.6304Y1.5627
    G00Z0.505
    X-4.7295Y2.2456
    G01Z-0.245
    X-4.4633Y2.2842
    X-4.0209Y2.395
    X-3.7272Y2.5
    X-4.0209Y2.605
    X-4.4633Y2.7158
    X-4.7295Y2.7544
    Y2.2457
    X-4.6964Y2.018
    X-4.4187Y2.0583
    X-3.9541Y2.1746
    X-3.485Y2.3423
    X-3.0959Y2.5
    X-3.485Y2.6577
    X-3.9541Y2.8254
    X-4.4187Y2.9417
    X-4.8943Y3.0108
    X-4.9595Y3.0139
    Y1.9861
    X-4.8943Y1.9892
    X-4.6965Y2.0179
    X-4.6634Y1.7903
    X-4.3742Y1.8324
    X-3.8873Y1.9542
    X-3.403Y2.1274
    X-2.9041Y2.3296
    X-2.8881Y2.3357
    X-2.4378Y2.5
    X-2.8881Y2.6643
    X-2.9041Y2.6704
    X-3.403Y2.8726
    X-3.8873Y3.0458
    X-4.3742Y3.1676
    X-4.8722Y3.24
    X-5.1895Y3.2551
    Y1.7449
    X-4.8722Y1.76
    X-4.6634Y1.7903
    X-4.6303Y1.5627
    X-4.3296Y1.6064
    X-3.8205Y1.7338
    X-3.3211Y1.9124
    X-2.8177Y2.1164
    X-2.8093Y2.1196
    X-2.7971Y2.1241
    X-2.7966Z0.1275
    X-2.3009Y2.3052
    X-2.3004Z-0.245
    X-2.2938Y2.3077
    X-2.276Y2.3135
    X-2.2621Y2.3175
    X-2.2616Z0.1275
    X-2.0247Y2.3849
    X-2.0242Z-0.245
    X-2.0111Y2.3887
    X-1.9946Y2.3928
    X-1.9838Y2.3951
    Z0.1275
    X-1.7359Y2.448
    Z-0.245
    X-1.725Y2.4503
    X-1.7058Y2.4536
    X-1.6971Y2.4548
    Z0.1275
    X-1.4419Y2.4891
    Z-0.245
    X-1.4332Y2.4903
    X-1.4111Y2.4923
    X-1.4046
    Z0.1275
    X-1.2478Y2.5
    X-1.4041Y2.5074
    Z-0.245
    X-1.4111
    X-1.4332Y2.5097
    X-1.4411Y2.5108
    Z0.1275
    X-1.6968Y2.5452
    Z-0.245
    X-1.7058Y2.5464
    X-1.725Y2.5497
    X-1.7355Y2.552
    X-1.736Z0.1275
    X-1.9834Y2.6048
    Z-0.245
    X-1.9946Y2.6072
    X-2.0111Y2.6113
    X-2.0244Y2.6151
    Z0.1275
    X-2.2617Y2.6825
    Z-0.245
    X-2.276Y2.6865
    X-2.2938Y2.6923
    X-2.3006Y2.6948
    X-2.3011Z0.1275
    X-2.7966Y2.8757
    X-2.7971Z-0.245
    X-2.8093Y2.8804
    X-2.8177Y2.8836
    X-3.3211Y3.0876
    X-3.8205Y3.2662
    X-4.3296Y3.3936
    X-4.8502Y3.4692
    X-5.3811Y3.4945
    X-5.4195
    Y1.5055
    X-5.3811
    X-4.8502Y1.5308
    X-4.6304Y1.5627
    G00Z0.505
    X-4.7295Y2.2456
    G01Z-0.495
    X-4.4633Y2.2842
    X-4.0209Y2.395
    X-3.7272Y2.5
    X-4.0209Y2.605
    X-4.4633Y2.7158
    X-4.7295Y2.7544
    Y2.2457
    X-4.6964Y2.018
    X-4.4187Y2.0583
    X-3.9541Y2.1746
    X-3.485Y2.3423
    X-3.0959Y2.5
    X-3.485Y2.6577
    X-3.9541Y2.8254
    X-4.4187Y2.9417
    X-4.8943Y3.0108
    X-4.9595Y3.0139
    Y1.9861
    X-4.8943Y1.9892
    X-4.6965Y2.0179
    X-4.6634Y1.7903
    X-4.3742Y1.8324
    X-3.8873Y1.9542
    X-3.403Y2.1274
    X-2.9041Y2.3296
    X-2.8881Y2.3357
    X-2.4378Y2.5
    X-2.8881Y2.6643
    X-2.9041Y2.6704
    X-3.403Y2.8726
    X-3.8873Y3.0458
    X-4.3742Y3.1676
    X-4.8722Y3.24
    X-5.1895Y3.2551
    Y1.7449
    X-4.8722Y1.76
    X-4.6634Y1.7903
    X-4.6303Y1.5627
    X-4.3296Y1.6064
    X-3.8205Y1.7338
    X-3.3211Y1.9124
    X-2.8177Y2.1164
    X-2.8093Y2.1196
    X-2.7971Y2.1241
    X-2.7966Z0.0638
    X-2.3009Y2.3052
    X-2.3004Z-0.495
    X-2.2938Y2.3077
    X-2.276Y2.3135
    X-2.2621Y2.3175
    X-2.2616Z0.0638
    X-2.0247Y2.3849
    X-2.0242Z-0.495
    X-2.0111Y2.3887
    X-1.9946Y2.3928
    X-1.9838Y2.3951
    Z0.0638
    X-1.7359Y2.448
    Z-0.495
    X-1.725Y2.4503
    X-1.7058Y2.4536
    X-1.6971Y2.4548
    Z0.0638
    X-1.4419Y2.4891
    Z-0.495
    X-1.4332Y2.4903
    X-1.4111Y2.4923
    X-1.4046
    Z0.0638
    X-1.2478Y2.5
    X-1.4041Y2.5074
    Z-0.495
    X-1.4111
    X-1.4332Y2.5097
    X-1.4411Y2.5108
    Z0.0638
    X-1.6968Y2.5452
    Z-0.495
    X-1.7058Y2.5464
    X-1.725Y2.5497
    X-1.7355Y2.552
    X-1.736Z0.0638
    X-1.9834Y2.6048
    Z-0.495
    X-1.9946Y2.6072
    X-2.0111Y2.6113
    X-2.0244Y2.6151
    Z0.0638
    X-2.2617Y2.6825
    Z-0.495
    X-2.276Y2.6865
    X-2.2938Y2.6923
    X-2.3006Y2.6948
    X-2.3011Z0.0638
    X-2.7966Y2.8757
    X-2.7971Z-0.495
    X-2.8093Y2.8804
    X-2.8177Y2.8836
    X-3.3211Y3.0876
    X-3.8205Y3.2662
    X-4.3296Y3.3936
    X-4.8502Y3.4692
    X-5.3811Y3.4945
    X-5.4195
    Y1.5055
    X-5.3811
    X-4.8502Y1.5308
    X-4.6304Y1.5627
    G00Z0.505
    X-4.7295Y2.2456
    G01Z-0.745
    X-4.4633Y2.2842
    X-4.0209Y2.395
    X-3.7272Y2.5
    X-4.0209Y2.605
    X-4.4633Y2.7158
    X-4.7295Y2.7544
    Y2.2457
    X-4.6964Y2.018
    X-4.4187Y2.0583
    X-3.9541Y2.1746
    X-3.485Y2.3423
    X-3.0959Y2.5
    X-3.485Y2.6577
    X-3.9541Y2.8254
    X-4.4187Y2.9417
    X-4.8943Y3.0108
    X-4.9595Y3.0139
    Y1.9861
    X-4.8943Y1.9892
    X-4.6965Y2.0179
    X-4.6634Y1.7903
    X-4.3742Y1.8324
    X-3.8873Y1.9542
    X-3.403Y2.1274
    X-2.9041Y2.3296
    X-2.8881Y2.3357
    X-2.4378Y2.5
    X-2.8881Y2.6643
    X-2.9041Y2.6704
    X-3.403Y2.8726
    X-3.8873Y3.0458
    X-4.3742Y3.1676
    X-4.8722Y3.24
    X-5.1895Y3.2551
    Y1.7449
    X-4.8722Y1.76
    X-4.6634Y1.7903
    X-4.6303Y1.5627
    X-4.3296Y1.6064
    X-3.8205Y1.7338
    X-3.3211Y1.9124
    X-2.8177Y2.1164
    X-2.8093Y2.1196
    X-2.7971Y2.1241
    X-2.7966Z0.
    X-2.3009Y2.3052
    X-2.3004Z-0.745
    X-2.2938Y2.3077
    X-2.276Y2.3135
    X-2.2621Y2.3175
    X-2.2616Z0.
    X-2.0247Y2.3849
    X-2.0242Z-0.745
    X-2.0111Y2.3887
    X-1.9946Y2.3928
    X-1.9838Y2.3951
    Z0.
    X-1.7359Y2.448
    Z-0.745
    X-1.725Y2.4503
    X-1.7058Y2.4536
    X-1.6971Y2.4548
    Z0.
    X-1.4419Y2.4891
    Z-0.745
    X-1.4332Y2.4903
    X-1.4111Y2.4923
    X-1.4046
    Z0.
    X-1.2478Y2.5
    X-1.4041Y2.5074
    Z-0.745
    X-1.4111
    X-1.4332Y2.5097
    X-1.4411Y2.5108
    Z0.
    X-1.6968Y2.5452
    Z-0.745
    X-1.7058Y2.5464
    X-1.725Y2.5497
    X-1.7355Y2.552
    X-1.736Z0.
    X-1.9834Y2.6048
    Z-0.745
    X-1.9946Y2.6072
    X-2.0111Y2.6113
    X-2.0244Y2.6151
    Z0.
    X-2.2617Y2.6825
    Z-0.745
    X-2.276Y2.6865
    X-2.2938Y2.6923
    X-2.3006Y2.6948
    X-2.3011Z0.
    X-2.7966Y2.8757
    X-2.7971Z-0.745
    X-2.8093Y2.8804
    X-2.8177Y2.8836
    X-3.3211Y3.0876
    X-3.8205Y3.2662
    X-4.3296Y3.3936
    X-4.8502Y3.4692
    X-5.3811Y3.4945
    X-5.4195
    Y1.5055
    X-5.3811
    X-4.8502Y1.5308
    X-4.6304Y1.5627
    G00Z0.505
    See pic. You can see some of the ups and downs (does not show all)
    Jul 2006
    741
    Okay, I really need to move on so I edited the G-code.
    If you have a better solution please let me know so that I can learn and do it better next time
    Here is the edited G code...
    Code:
    // roughing right
    Z0.1
    X0.33Y1.505
    G01Z-0.2483F25
    X0.3698
    X1.9343Y1.735
    X0.33
    Y1.965
    X2.5601
    X2.5939Y1.9782
    //Z0.
    //X3.1488Y2.195
    X2.9488Y2.195
    X3.1356
    //Z-0.2483
    X0.33
    Y2.425
    X3.897
    //X3.8975Z0.
    //X3.909
    X3.709
    X3.9064Y2.4269
    //Z-0.2483
    X3.5919Y2.6513
    //Z0.
    //X3.5866Y2.655
    X3.3866Y2.655
    X3.5794
    //Z-0.2483
    X0.33
    Y2.885
    X2.93
    //Z0.
    X2.9194Y2.8893
    //Z-0.2483
    X2.3536Y3.115
    X0.33
    Y3.345
    X1.6164
    X0.3698Y3.495
    X0.33
    G00Z0.1
    Y1.505
    G01Z-0.4967
    X0.3698
    X1.9343Y1.735
    X0.33
    Y1.965
    X2.5601
    X2.5939Y1.9782
    //Z0.
    //X3.1488Y2.195
    X2.9488Y2.195
    X3.1356
    //Z-0.4967
    X0.33
    Y2.425
    X3.897
    //X3.8975Z0.
    //X3.909
    X3.709
    X3.9064Y2.4269
    //Z-0.4967
    X3.5919Y2.6513
    //Z0.
    //X3.5866Y2.655
    X3.3866Y2.655
    X3.5794
    //Z-0.4967
    X0.33
    Y2.885
    X2.93
    //Z0.
    X2.9194Y2.8893
    //Z-0.4967
    X2.3536Y3.115
    X0.33
    Y3.345
    X1.6164
    X0.3698Y3.495
    X0.33
    G00Z0.1
    Y1.505
    G01Z-0.745
    X0.3698
    X1.9343Y1.735
    X0.33
    Y1.965
    X2.5601
    X2.5939Y1.9782
    //Z0.
    //X3.1488Y2.195
    X2.9488Y2.195
    X3.1356
    //Z-0.745
    X0.33
    Y2.425
    X3.897
    //X3.8975Z0.
    //X3.909
    X3.709
    X3.9064Y2.4269
    //Z-0.745
    X3.5919Y2.6513
    //Z0.
    //X3.5866Y2.655
    X3.3866Y2.655
    X3.5794
    //Z-0.745
    X0.33
    Y2.885
    X2.93
    //Z0.
    X2.9194Y2.8893
    //Z-0.745
    X2.3536Y3.115
    X0.33
    Y3.345
    X1.6164
    X0.3698Y3.495
    X0.33
    G00Z0.1
    Attached is the cad drawing if you want to give it a try
    Attached Files Attached Files
    Jul 2006
    741
    Oh God!
    The Y axis is not inverted *sigh*
    If by any chance another newbie reads this and does not want to waste a couple of hours of work, the setting is in the CAM menu under Setup/Coordinates.
    Jul 2006
    741
    The code is running (there might be very minor changes I made directly on Mach3, but no more than one or two).
    The problem now is that my Z axis stepper came loose during the testing and I had to stop
    If you are following this thread here is the code I'm testing with and attached is the cad file
    Code:
    ;1/4 drill bit for thru holes
    ;make sure to zero Z on stock surface
    M5
    M9
    ;G0 G28 G91 Z0.
    G28 G91 Z0.
    T1 M6
    S1000 M3
    G90 G54 X0. Y0.
    ;G43 H1 D1 Z3.
    M8
    ; pecked holes
    G73X-0.875Y-3.75Z-1.3R0.1Q0.5F20
    X-2.5Y-3.825
    X-4.125Y-3.9
    Y-1.1
    X-2.5Y-1.175
    X-0.875Y-1.25
    X1.625Y-1.1
    X3.25Y-1.175
    X4.875Y-1.25
    Y-3.75
    X3.25Y-3.825
    X1.625Y-3.9
    G80
    ;1/2 end mill for countersinking and all milling
    M5
    M9
    ;G0 G28 G91 Z0.
    G28 G91 Z0.
    T2 M6
    S1000 M3
    G90 G54 X0. Y0.
    ;G43 H2 D2 Z0.
    M8
    G81X-0.875Y-3.75 Z-.25R0.1F25
    X-2.5Y-3.825
    X-4.125Y-3.9
    Y-1.1
    X-2.5Y-1.175
    X-0.875Y-1.25
    X1.625Y-1.1
    X3.25Y-1.175
    X4.875Y-1.25
    Y-3.75
    X3.25Y-3.825
    X1.625Y-3.9
    G80
    ;rought right
    Z0.1
    X0.33Y-1.505
    G01Z-0.2483F25
    X0.3698
    X1.9343Y-1.735
    X0.33
    Y-1.965
    X2.5601
    X2.5939Y-1.9782
    ;Z0.
    ;X3.1488Y-2.195
    X2.9488Y-2.195
    X3.1356
    ;Z-0.2483
    X0.33
    Y-2.425
    X3.897
    ;X3.8975Z0.
    ;X3.909
    X3.709
    X3.9064Y-2.4269
    ;Z-0.2483
    X3.5919Y-2.6513
    ;Z0.
    ;X3.5866Y-2.655
    X3.3866Y-2.655
    X3.5794
    ;Z-0.2483
    X0.33
    Y-2.885
    X2.93
    ;Z0.
    X2.9194Y-2.8893
    ;Z-0.2483
    X2.3536Y-3.115
    X0.33
    Y-3.345
    X1.6164
    X0.3698Y-3.495
    X0.33
    G00Z0.1
    Y-1.505
    G01Z-0.4967
    X0.3698
    X1.9343Y-1.735
    X0.33
    Y-1.965
    X2.5601
    X2.5939Y-1.9782
    ;Z0.
    ;X3.1488Y-2.195
    X2.9488Y-2.195
    X3.1356
    ;Z-0.4967
    X0.33
    Y-2.425
    X3.897
    ;X3.8975Z0.
    ;X3.909
    X3.709
    X3.9064Y-2.4269
    ;Z-0.4967
    X3.5919Y-2.6513
    ;Z0.
    ;X3.5866Y-2.655
    X3.3866Y-2.655
    X3.5794
    ;Z-0.4967
    X0.33
    Y-2.885
    X2.93
    ;Z0.
    X2.9194Y-2.8893
    ;Z-0.4967
    X2.3536Y-3.115
    X0.33
    Y-3.345
    X1.6164
    X0.3698Y-3.495
    X0.33
    G00Z0.1
    Y-1.505
    G01Z-0.745
    X0.3698
    X1.9343Y-1.735
    X0.33
    Y-1.965
    X2.5601
    X2.5939Y-1.9782
    ;Z0.
    ;X3.1488Y-2.195
    X2.9488Y-2.195
    X3.1356
    ;Z-0.745
    X0.33
    Y-2.425
    X3.897
    ;X3.8975Z0.
    ;X3.909
    X3.709
    X3.9064Y-2.4269
    ;Z-0.745
    X3.5919Y-2.6513
    ;Z0.
    ;X3.5866Y-2.655
    X3.3866Y-2.655
    X3.5794
    ;Z-0.745
    X0.33
    Y-2.885
    X2.93
    ;Z0.
    X2.9194Y-2.8893
    ;Z-0.745
    X2.3536Y-3.115
    X0.33
    Y-3.345
    X1.6164
    X0.3698Y-3.495
    X0.33
    G00Z0.1
    ;profile right
    X1.625Y-3.9
    X-0.0065Y-1.8536
    G01Z0.F15
    X0.347Y-1.5
    X0.369
    X0.9003Y-1.5253
    X1.4215Y-1.601
    X1.9311Y-1.7286
    X2.4309Y-1.9073
    X2.9344Y-2.1113
    G02X2.9426Y-2.1145I0.0939J0.2317
    G01X3.4581Y-2.3026
    G02X3.4755Y-2.3082I0.0857J0.2349
    G01X3.7404Y-2.3834
    G02X3.7565Y-2.3874I0.0683J0.2405
    G01X4.0261Y-2.4449
    G02X4.0449Y-2.4482I0.0522J0.2445
    G01X4.3176Y-2.4849
    G02X4.3392Y-2.4868I0.0333J0.2478
    G01X4.6132Y-2.4997
    G02X4.625I0.0118J0.2497
    X4.6132Y-2.5003I0.J-0.25
    G01X4.3392Y-2.5132
    G02X4.3176Y-2.5151I0.0117J-0.2497
    G01X4.0449Y-2.5518
    G02X4.0261Y-2.5551I0.0334J-0.2478
    G01X3.7565Y-2.6126
    G02X3.7404Y-2.6166I0.0522J-0.2445
    G01X3.4755Y-2.6918
    G02X3.4581Y-2.6974I0.0683J-0.2405
    G01X2.9426Y-2.8855
    G02X2.9344Y-2.8887I0.0857J-0.2349
    G01X2.4309Y-3.0927
    X1.9311Y-3.2714
    X1.4215Y-3.399
    X0.9003Y-3.4747
    X0.369Y-3.5
    X0.325
    Y-1.5
    X0.347
    X0.7006Y-1.8536
    G00Z0.1
    ;finish bottom
    X0.33Y-1.505
    G01Z-0.75F15
    X0.3698
    X1.9343Y-1.735
    X0.33
    Y-1.965
    X2.5601
    X2.5939Y-1.9782
    ;Z0.
    ;X3.1488Y-2.195
    X2.9488Y-2.195
    X3.1356
    ;Z-0.75
    X0.33
    Y-2.425
    X3.897
    ;X3.8975Z0.
    ;X3.909
    X3.709
    X3.9064Y-2.4269
    ;Z-0.75
    X3.5919Y-2.6513
    ;Z0.
    ;X3.5866Y-2.655
    X3.3866Y-2.655
    X3.5794
    ;Z-0.75
    X0.33
    Y-2.885
    X2.93
    ;Z0.
    X2.9194Y-2.8893
    ;Z-0.75
    X2.3536Y-3.115
    X0.33
    Y-3.345
    X1.6164
    X0.3698Y-3.495
    X0.33
    G00Z0.1
    ;end of test
    G00 X0 Y0 Z0
    As you can see a lot of g-code edited and we have not even done the external profile or looked at tool paths between operations.
    Is this really the way it is or am I trying too hard?
    Thanks!
    Jul 2006
    741
    Okay, I made it into subroutines...
    Problem is either my subroutines are messed up of BobCad does not understand subroutines.
    Simulation, tool path representation... all gone
    Will need to wait a day or two till I have time to check the Z axis to run it on the machine on air and then on Styrofoam or something cheap and forgiving (not sure what).
    ; through holes with peck drilling
    M5 M9
    G00 X0 Y0 Z0
    T1 M06 (0.25 drill bit, 1000 RPM, zero Z on workpiece height)
    M3 S1000 M8
    M98 P6
    G80
    ; countersunk holes with spot drilling
    M5 M9
    G00 X0 Y0 Z4
    T1 M06 (0.50 3 flute end mill, 1000 RPM, zero Z on workpiece height)
    M3 S1000 M8
    M98 P6
    G80
    ; pocketing and profile
    M5 M9
    T1 M06 (no tool change, manualy set RPM to 2500 RPM)
    M3 S2500 M8
    G52 X0 Y0 (right pocket)
    M98 P1
    G52 X-5.75 Y0 (left pocket)
    M98 P1
    ; missing external profile
    ; done!
    G00 G93 X0 Y0 Z0 (go to machine zero)
    M30 (finish)
    ; subroutine to do pocket
    ; does provide Z clearance
    ; does reset G92
    O1
    G52 Z0 (pass 1 - rough)
    G00 Z0.1
    M98 P2
    G52 Z-0.25 (pass 2 - rough)
    G00 Z0.1
    M98 P2
    G52 Z-0.495 (pass 3 - rough)
    G00 Z0.1
    M98 P2
    G52 Z-0.5 (pass 4 - finish)
    G00 Z0.1
    M98 P3
    G52 Z0 (finish side)
    G00 Z0.1
    M98 P5
    G52 X0 Y0 Z0 (reset G52)
    G00 Z0.1 (rapid plane)
    M99
    ; subroutine to remove one rough pass on pocket
    ; assumes no responsability for Z clearance
    O2
    X0.33Y-1.505
    G01Z-0.25F25 (plunges -0.25 in relation to G52, sets roughing IPM)
    M98 P4
    M99
    ; subroutine to finish pocket bottom
    O3
    X0.33Y-1.505
    G01Z-0.25F15 (plunges -0.25 in relation to G52, sets finishing IPM)
    M98 P4
    M99
    ; helper subroutine to remove one pass on pocket
    O4
    X0.3698
    X1.9343Y-1.735
    X0.33
    Y-1.965
    X2.5601
    X2.5939Y-1.9782
    X2.9488Y-2.195
    X3.1356
    X0.33
    Y-2.425
    X3.897
    X3.709
    X3.9064Y-2.4269
    X3.5919Y-2.6513
    X3.3866Y-2.655
    X3.5794
    X0.33
    Y-2.885
    X2.93
    X2.9194Y-2.8893
    X2.3536Y-3.115
    X0.33
    Y-3.345
    X1.6164
    X0.3698Y-3.495
    X0.33
    M99
    ; subroutine to finish pocket side
    O5
    X0.33Y-1.505
    G01Z-0.75F15 (plunge -0.75 in relation to G52, sets finishing IPM)
    X0.347Y-1.5
    X0.369
    X0.9003Y-1.5253
    X1.4215Y-1.601
    X1.9311Y-1.7286
    X2.4309Y-1.9073
    X2.9344Y-2.1113
    G01X3.4581Y-2.3026
    G01X3.7404Y-2.3834
    G01X4.0261Y-2.4449
    G01X4.3176Y-2.4849
    G01X4.6132Y-2.4997
    G01X4.3392Y-2.5132
    G01X4.0449Y-2.5518
    G01X3.7565Y-2.6126
    G01X3.4755Y-2.6918
    G01X2.9426Y-2.8855
    G01X2.4309Y-3.0927
    X1.9311Y-3.2714
    X1.4215Y-3.399
    X0.9003Y-3.4747
    X0.369Y-3.5
    X0.325
    Y-1.5
    X0.347
    X0.7006Y-1.8536
    M99
    ; subroutine to drill holes
    ; assumes modal G73 or G81
    O6
    X-2.5Y-3.825
    X-4.125Y-3.9
    Y-1.1
    X-2.5Y-1.175
    X-0.875Y-1.25
    X1.625Y-1.1
    X3.25Y-1.175
    X4.875Y-1.25
    Y-3.75
    X3.25Y-3.825
    X1.625Y-3.9
    M99
    Jul 2006
    741
    Weird, I also tried the CNC Simulator (http://www.cncsimulator.com/) and they do not support subroutines either.
    So I guess if you start touching up code in that way it will be between you and your text editor.
    Apr 2007
    243
    Ed,
    I think you are trying too hard on this project.
    1) If you are having the tool scuff up the wall on the pocket. Offset the pocket wall to leave stock for a finish path. .100 or so. You could just do this in the pocket tool path feature there is a setting for stock left for finishing.
    2) In order to get a nice and clean wall you need to run a finish tool on just the profile of the wall.
    Jul 2006
    741
    Quote Originally Posted by Allen123 View Post
    Ed,
    Yeap, you are right. I got carried away big time with the subroutine stuff. It started because I did not want to do both pockets so I said, oh well just do a G92 and put it in a subroutine... and it grew from there... now I lost the graphical representation of the tool paths... not a big deal, but probably not something I want to keep doing
    Above I'm using the finishing tool as the same end mill just with a slower feed (F15 instead of F25). If I want to use the same end mill (because I do not have another) can I do it that way or should I up the RPM as well?
    BTW, the reason why I chose to change only the feed is because the spindle control on my mill is not working from gcode , but I could rearrange things so that the roughing takes place in both pockets, then I manually change the RPM, and then do the finishing on both pockets if that would work a bit better.
    Jul 2009
    4
    Ed,
    I think you would find this to be much more simple to work with if you draw it in 2D.
    You can use the same tool for both operations, but in reality then you're finishing the entire part. I would suggest investing in some roughers. You will be able to run much higher feed rates.
    Jun 2009
    7
    Quote Originally Posted by Ed from NY View Post
    Code:
    // roughing
    Y1.505
    X0.3698
    X1.9343Y1.735
    X0.33
    Y1.965
    X2.5601
    X2.5939Y1.9782
    X0.33
    Y2.425
    X3.897
    X3.5919Y2.6513
    X0.33
    Y2.885
    X2.93
    X2.3536Y3.115
    X0.33
    Y3.345
    X1.6164
    X0.3698Y3.495
    X0.33
    Y1.505
    X0.3698
    X1.9343Y1.735
    X0.33
    Y1.965
    X2.5601
    X2.5939Y1.9782
    X0.33
    Y2.425
    X3.897
    X3.5919Y2.6513
    X0.33
    Y2.885
    X2.93
    X2.3536Y3.115
    X0.33
    Y3.345
    X1.6164
    X0.3698Y3.495
    X0.33
    Y1.505
    X0.3698
    X1.9343Y1.735
    X0.33
    Y1.965
    X2.5601
    X2.5939Y1.9782
    X0.33
    Y2.425
    X3.897
    X3.5919Y2.6513
    X0.33
    Y2.885
    X2.93
    X2.3536Y3.115
    X0.33
    Y3.345
    X1.6164
    X0.3698Y3.495
    X0.33
    Wow, I'm really lazy. I just fire my CompuCarve up.
    Jul 2006
    1062
    Code:
      G00 X0. Y0. Z3.
      X-115.145 Y64.2017
      G01 Z-2.8222 F100
      G00
      G01 X-117.145 F200
      Y60.4867
      X-113.9459 Y60.9515
      X-103.7632 Y63.5
      X-113.9459 Y66.0485
      X-117.145 Y66.5133
      Y64.2018
      X-119.145
      Y58.1751
      X-113.5584 Y58.9868
      X-102.4179 Y61.775
      X-97.5938 Y63.5
      X-102.4179 Y65.225
      X-113.5584 Y68.0132
      X-119.145 Y68.8249
      Y64.2018
      X-121.145
      Y55.8634
      X-113.1708 Y57.0221
      X-101.837 Y59.8587
      X-91.6537 Y63.5
      X-101.837 Y67.1413
      X-113.1708 Y69.9779
      X-121.145 Y71.1366
      Y64.2018
      X-123.145
      Y53.5518
      X-112.7832 Y55.0574
      X-101.2561 Y57.9424
      X-89.5256 Y62.1369
      X-86.1617 Y63.5
      X-89.5256 Y64.8631
      X-101.2561 Y69.0576
      X-112.7832 Y71.9426
      X-123.145 Y73.4482
      Y64.2018
      X-125.145
      Y51.3135
      X-124.3946 Y51.3493
      X-112.3957 Y53.0927
      X-100.6753 Y56.0261
      X-88.813 Y60.2677
      X-80.8361 Y63.5
      X-88.813 Y66.7323
      X-100.6753 Y70.9739
      X-112.3957 Y73.9073
      X-124.3946 Y75.6507
      X-125.145 Y75.6865
      Y64.2018
      X-127.145
      Y49.216
      X-124.2027 Y49.3561
      X-112.0081 Y51.128
      X-100.0944 Y54.1098
      X-88.1005 Y58.3985
      X-75.5162 Y63.4977
      G01 X-88.1005 Y68.6015
      X-100.0944 Y72.8902
      X-112.0081 Y75.872
      X-124.2027 Y77.6439
      X-127.145 Y77.784
      Y64.2018
      X-129.145
      Y47.1185
      X-124.0109 Y47.363
      X-111.6205 Y49.1634
      X-99.5135 Y52.1935
      X-87.3879 Y56.5293
      X-74.7651 Y61.6441
      G02 X-74.2736 Y61.8332 R15.
      G01 X-69.7057 Y63.5
      X-74.2736 Y65.1668
      G02 X-74.7651 Y65.3559 R15.
      G01 X-87.3879 Y70.4707
      X-99.5135 Y74.8065
      X-111.6205 Y77.8366
      X-124.0109 Y79.637
      X-129.145 Y79.8815
      Y64.2018
      X-131.145
      Y45.021
      X-123.8191 Y45.3699
      X-111.233 Y47.1987
      X-98.9326 Y50.2772
      X-86.6754 Y54.66
      X-74.014 Y59.7905
      G02 X-73.5881 Y59.9544 R13.
      G01 X-63.871 Y63.5
      X-73.5881 Y67.0456
      G02 X-74.014 Y67.2095 R13.
      G01 X-86.6754 Y72.34
      X-98.9326 Y76.7228
      X-111.233 Y79.8013
      X-123.8191 Y81.6301
      X-131.145 Y81.979
      Y64.2018
      X-133.145
      Y42.9234
      X-123.6273 Y43.3767
      X-110.8454 Y45.234
      X-98.3517 Y48.3609
      X-85.9628 Y52.7908
      X-73.2629 Y57.9368
      G02 X-72.9025 Y58.0756 R11.
      G01 X-59.8086 Y62.8533
      G02 X-59.0428 Y63.1014 R11.
      G01 X-57.639 Y63.5
      X-59.0428 Y63.8986
      G02 X-59.8086 Y64.1467 R11.
      G01 X-72.9025 Y68.9244
      G02 X-73.2629 Y69.0632 R11.
      G01 X-85.9628 Y74.2092
      X-98.3517 Y78.6391
      X-110.8454 Y81.766
      X-123.6273 Y83.6233
      X-133.145 Y84.0766
      Y64.2018
      X-135.145
      Y40.8259
      X-123.4355 Y41.3836
      X-110.4578 Y43.2693
      X-97.7708 Y46.4446
      X-85.2503 Y50.9216
      X-72.5118 Y56.0832
      G02 X-72.217 Y56.1967 R9.
      G01 X-59.1231 Y60.9745
      G02 X-58.4964 Y61.1775 R9.
      G01 X-51.7683 Y63.0879
      G02 X-51.1864 Y63.2324 R9.
      G01 X-49.9311 Y63.5
      X-51.1864 Y63.7676
      G02 X-51.7683 Y63.9121 R9.
      G01 X-58.4964 Y65.8225
      G02 X-59.1231 Y66.0255 R9.
      G01 X-72.217 Y70.8033
      G02 X-72.5118 Y70.9168 R9.
      G01 X-85.2503 Y76.0784
      X-97.7708 Y80.5554
      X-110.4578 Y83.7307
      X-123.4355 Y85.6164
      X-135.145 Y86.1741
      Y64.2018
      X-137.145
      Y38.75
      X-136.6916
      X-123.2437 Y39.3905
      X-110.0703 Y41.3046
      X-97.19 Y44.5283
      X-84.5377 Y49.0524
      X-71.7608 Y54.2296
      G02 X-71.5314 Y54.3179 R7.
      G01 X-58.4375 Y59.0956
      G02 X-57.9501 Y59.2535 R7.
      G01 X-51.222 Y61.164
      G02 X-50.7694 Y61.2763 R7.
      G01 X-43.9215 Y62.7361
      G02 X-43.3959 Y62.8274 R7.
      G01 X-38.399 Y63.5
      X-43.3959 Y64.1726
      G02 X-43.9215 Y64.2639 R7.
      G01 X-50.7694 Y65.7237
      G02 X-51.222 Y65.836 R7.
      G01 X-57.9501 Y67.7465
      G02 X-58.4375 Y67.9044 R7.
      G01 X-71.5314 Y72.6821
      G02 X-71.7608 Y72.7704 R7.
      G01 X-84.5377 Y77.9476
      X-97.19 Y82.4717
      X-110.0703 Y85.6954
      X-123.2437 Y87.6095
      X-136.6916 Y88.25
      X-137.145
      Y64.2018
      X-139.145
      Y36.75
      X-136.644
      X-123.0519 Y37.3974
      X-109.6827 Y39.3399
      X-96.6091 Y42.612
      X-83.8252 Y47.1831
      X-71.0097 Y52.376
      G02 X-70.8458 Y52.4391 R5.
      G01 X-57.752 Y57.2168
      G02 X-57.4038 Y57.3296 R5.
      G01 X-50.6757 Y59.24
      G02 X-50.3524 Y59.3203 R5.
      G01 X-43.5046 Y60.7801
      G02 X-43.1291 Y60.8453 R5.
      G01 X-36.2034 Y61.7775
      G02 X-35.7716 Y61.8167 R5.
      G01 X-28.8102 Y62.1445
      G02 X-28.575 R5.
      G03 Y64.85 R1.35
      G02 X-28.8102 R5.
      G01 X-35.7716 Y65.1833
      G02 X-36.2034 Y65.2225 R5.
      G01 X-43.1291 Y66.1547
      G02 X-43.5046 Y66.2199 R5.
      G01 X-50.3524 Y67.6797
      G02 X-50.6757 Y67.76 R5.
      G01 X-57.4038 Y69.6704
      G02 X-57.752 Y69.7832 R5.
      G01 X-70.8458 Y74.5609
      G02 X-71.0097 Y74.624 R5.
      G01 X-83.8252 Y79.8169
      X-96.6091 Y84.388
      X-109.6827 Y87.6601
      X-123.0519 Y89.6026
      X-136.644 Y90.25
      X-139.145
      Y64.2018
      G00 Z3.
      X-115.145
      G01 Z-5.6444 F100
      G00
      G01 X-117.145 F200
      Y60.4867
      X-113.9459 Y60.9515
      X-103.7632 Y63.5
      X-113.9459 Y66.0485
      X-117.145 Y66.5133
      Y64.2018
      X-119.145
      Y58.1751
      X-113.5584 Y58.9868
      X-102.4179 Y61.775
      X-97.5938 Y63.5
      X-102.4179 Y65.225
      X-113.5584 Y68.0132
      X-119.145 Y68.8249
      Y64.2018
      X-121.145
      Y55.8634
      X-113.1708 Y57.0221
      X-101.837 Y59.8587
      X-91.6537 Y63.5
      X-101.837 Y67.1413
      X-113.1708 Y69.9779
      X-121.145 Y71.1366
      Y64.2018
      X-123.145
      Y53.5518
      X-112.7832 Y55.0574
      X-101.2561 Y57.9424
      X-89.5256 Y62.1369
      X-86.1617 Y63.5
      X-89.5256 Y64.8631
      X-101.2561 Y69.0576
      X-112.7832 Y71.9426
      X-123.145 Y73.4482
      Y64.2018
      X-125.145
      Y51.3135
      X-124.3946 Y51.3493
      X-112.3957 Y53.0927
      X-100.6753 Y56.0261
      X-88.813 Y60.2677
      X-80.8361 Y63.5
      X-88.813 Y66.7323
      X-100.6753 Y70.9739
      X-112.3957 Y73.9073
      X-124.3946 Y75.6507
      X-125.145 Y75.6865
      Y64.2018
      X-127.145
      Y49.216
      X-124.2027 Y49.3561
      X-112.0081 Y51.128
      X-100.0944 Y54.1098
      X-88.1005 Y58.3985
      X-75.5162 Y63.4977
      X-100.0944 Y72.8902
      X-112.0081 Y75.872
      X-124.2027 Y77.6439
      X-127.145 Y77.784
      Y64.2018
      X-129.145
      Y47.1185
      X-124.0109 Y47.363
      X-111.6205 Y49.1634
      X-99.5135 Y52.1935
      X-87.3879 Y56.5293
      X-74.7651 Y61.6441
      G01 X-69.7057 Y63.5
      X-74.2736 Y65.1668
      X-99.5135 Y74.8065
      X-111.6205 Y77.8366
      X-124.0109 Y79.637
      X-129.145 Y79.8815
      Y64.2018
      X-131.145
      Y45.021
      X-123.8191 Y45.3699
      X-111.233 Y47.1987
      X-98.9326 Y50.2772
      X-86.6754 Y54.66
      X-74.014 Y59.7905
      G01 X-63.871 Y63.5
      X-73.5881 Y67.0456
      X-98.9326 Y76.7228
      X-111.233 Y79.8013
      X-123.8191 Y81.6301
      X-131.145 Y81.979
      Y64.2018
      X-133.145
      Y42.9234
      X-123.6273 Y43.3767
      X-110.8454 Y45.234
      X-98.3517 Y48.3609
      X-85.9628 Y52.7908
      X-73.2629 Y57.9368
      G01 X-57.639 Y63.5
      X-59.0428 Y63.8986
      X-98.3517 Y78.6391
      X-110.8454 Y81.766
      X-123.6273 Y83.6233
      X-133.145 Y84.0766
      Y64.2018
      X-135.145
      Y40.8259
      X-123.4355 Y41.3836
      X-110.4578 Y43.2693
      X-97.7708 Y46.4446
      X-85.2503 Y50.9216
      X-72.5118 Y56.0832
      G01 X-49.9311 Y63.5
      X-51.1864 Y63.7676
      X-97.7708 Y80.5554
      X-110.4578 Y83.7307
      X-123.4355 Y85.6164
      X-135.145 Y86.1741
      Y64.2018
      X-137.145
      Y38.75
      X-136.6916
      X-123.2437 Y39.3905
      X-110.0703 Y41.3046
      X-97.19 Y44.5283
      X-84.5377 Y49.0524
      X-71.7608 Y54.2296
      G01 X-38.399 Y63.5
      X-43.3959 Y64.1726
      X-97.19 Y82.4717
      X-110.0703 Y85.6954
      X-123.2437 Y87.6095
      X-136.6916 Y88.25
      X-137.145
      Y64.2018
      X-139.145
      Y36.75
      X-136.644
      X-123.0519 Y37.3974
      X-109.6827 Y39.3399
      X-96.6091 Y42.612
      X-83.8252 Y47.1831
      X-71.0097 Y52.376
      G02 X-28.575 R5.
      G03 Y64.85 R1.35
      G02 X-28.8102 R5.
      X-96.6091 Y84.388
      X-109.6827 Y87.6601
      X-123.0519 Y89.6026
      X-136.644 Y90.25
      X-139.145
      Y64.2018
      G00 Z3.
      X-115.145
      G01 Z-8.4667 F100
      G00
      G01 X-117.145 F200
      Y60.4867
      X-113.9459 Y60.9515
      X-103.7632 Y63.5
      X-113.9459 Y66.0485
      X-117.145 Y66.5133
      Y64.2018
      X-119.145
      Y58.1751
      X-113.5584 Y58.9868
      X-102.4179 Y61.775
      X-97.5938 Y63.5
      X-102.4179 Y65.225
      X-113.5584 Y68.0132
      X-119.145 Y68.8249
      Y64.2018
      X-121.145
      Y55.8634
      X-113.1708 Y57.0221
      X-101.837 Y59.8587
      X-91.6537 Y63.5
      X-101.837 Y67.1413
      X-113.1708 Y69.9779
      X-121.145 Y71.1366
      Y64.2018
      X-123.145
      Y53.5518
      X-112.7832 Y55.0574
      X-101.2561 Y57.9424
      X-89.5256 Y62.1369
      X-86.1617 Y63.5
      X-89.5256 Y64.8631
      X-101.2561 Y69.0576
      X-112.7832 Y71.9426
      X-123.145 Y73.4482
      Y64.2018
      X-125.145
      Y51.3135
      X-124.3946 Y51.3493
      X-112.3957 Y53.0927
      X-100.6753 Y56.0261
      X-88.813 Y60.2677
      X-80.8361 Y63.5
      X-88.813 Y66.7323
      X-100.6753 Y70.9739
      X-112.3957 Y73.9073
      X-124.3946 Y75.6507
      X-125.145 Y75.6865
      Y64.2018
      X-127.145
      Y49.216
      X-124.2027 Y49.3561
      X-112.0081 Y51.128
      X-100.0944 Y54.1098
      X-88.1005 Y58.3985
      X-75.5162 Y63.4977
      X-100.0944 Y72.8902
      X-112.0081 Y75.872
      X-124.2027 Y77.6439
      X-127.145 Y77.784
      Y64.2018
      X-129.145
      Y47.1185
      X-124.0109 Y47.363
      X-111.6205 Y49.1634
      X-99.5135 Y52.1935
      X-87.3879 Y56.5293
      X-74.7651 Y61.6441
      G01 X-69.7057 Y63.5
      X-74.2736 Y65.1668
      X-99.5135 Y74.8065
      X-111.6205 Y77.8366
      X-124.0109 Y79.637
      X-129.145 Y79.8815
      Y64.2018
      X-131.145
      Y45.021
      X-123.8191 Y45.3699
      X-111.233 Y47.1987
      X-98.9326 Y50.2772
      X-86.6754 Y54.66
      X-74.014 Y59.7905
      G01 X-63.871 Y63.5
      X-73.5881 Y67.0456
      X-98.9326 Y76.7228
      X-111.233 Y79.8013
      X-123.8191 Y81.6301
      X-131.145 Y81.979
      Y64.2018
      X-133.145
      Y42.9234
      X-123.6273 Y43.3767
      X-110.8454 Y45.234
      X-98.3517 Y48.3609
      X-85.9628 Y52.7908
      X-73.2629 Y57.9368
      G01 X-57.639 Y63.5
      X-59.0428 Y63.8986
      X-98.3517 Y78.6391
      X-110.8454 Y81.766
      X-123.6273 Y83.6233
      X-133.145 Y84.0766
      Y64.2018
      X-135.145
      Y40.8259
      X-123.4355 Y41.3836
      X-110.4578 Y43.2693
      X-97.7708 Y46.4446
      X-85.2503 Y50.9216
      X-72.5118 Y56.0832
      G01 X-49.9311 Y63.5
      X-51.1864 Y63.7676
      X-97.7708 Y80.5554
      X-110.4578 Y83.7307
      X-123.4355 Y85.6164
      X-135.145 Y86.1741
      Y64.2018
      X-137.145
      Y38.75
      X-136.6916
      X-123.2437 Y39.3905
      X-110.0703 Y41.3046
      X-97.19 Y44.5283
      X-84.5377 Y49.0524
      X-71.7608 Y54.2296
      G01 X-38.399 Y63.5
      X-43.3959 Y64.1726
      X-97.19 Y82.4717
      X-110.0703 Y85.6954
      X-123.2437 Y87.6095
      X-136.6916 Y88.25
      X-137.145
      Y64.2018
      X-139.145
      Y36.75
      X-136.644
      X-123.0519 Y37.3974
      X-109.6827 Y39.3399
      X-96.6091 Y42.612
      X-83.8252 Y47.1831
      X-71.0097 Y52.376
      G02 X-28.575 R5.
      G03 Y64.85 R1.35
      G02 X-28.8102 R5.
      X-96.6091 Y84.388
      X-109.6827 Y87.6601
      X-123.0519 Y89.6026
      X-136.644 Y90.25
      X-139.145
      Y64.2018
      G00 Z3.
      X-115.145
      G01 Z-11.2889 F100
      G00
      G01 X-117.145 F200
      Y60.4867
      X-113.9459 Y60.9515
      X-103.7632 Y63.5
      X-113.9459 Y66.0485
      X-117.145 Y66.5133
      Y64.2018
      X-119.145
      Y58.1751
      X-113.5584 Y58.9868
      X-102.4179 Y61.775
      X-97.5938 Y63.5
      X-102.4179 Y65.225
      X-113.5584 Y68.0132
      X-119.145 Y68.8249
      Y64.2018
      X-121.145
      Y55.8634
      X-113.1708 Y57.0221
      X-101.837 Y59.8587
      X-91.6537 Y63.5
      X-101.837 Y67.1413
      X-113.1708 Y69.9779
      X-121.145 Y71.1366
      Y64.2018
      X-123.145
      Y53.5518
      X-112.7832 Y55.0574
      X-101.2561 Y57.9424
      X-89.5256 Y62.1369
      X-86.1617 Y63.5
      X-89.5256 Y64.8631
      X-101.2561 Y69.0576
      X-112.7832 Y71.9426
      X-123.145 Y73.4482
      Y64.2018
      X-125.145
      Y51.3135
      X-124.3946 Y51.3493
      X-112.3957 Y53.0927
      X-100.6753 Y56.0261
      X-88.813 Y60.2677
      X-80.8361 Y63.5
      X-88.813 Y66.7323
      X-100.6753 Y70.9739
      X-112.3957 Y73.9073
      X-124.3946 Y75.6507
      X-125.145 Y75.6865
      Y64.2018
      X-127.145
      Y49.216
      X-124.2027 Y49.3561
      X-112.0081 Y51.128
      X-100.0944 Y54.1098
      X-88.1005 Y58.3985
      X-75.5162 Y63.4977
      X-100.0944 Y72.8902
      X-112.0081 Y75.872
      X-124.2027 Y77.6439
      X-127.145 Y77.784
      Y64.2018
      X-129.145
      Y47.1185
      X-124.0109 Y47.363
      X-111.6205 Y49.1634
      X-99.5135 Y52.1935
      X-87.3879 Y56.5293
      X-74.7651 Y61.6441
      G01 X-69.7057 Y63.5
      X-74.2736 Y65.1668
      X-99.5135 Y74.8065
      X-111.6205 Y77.8366
      X-124.0109 Y79.637
      X-129.145 Y79.8815
      Y64.2018
      X-131.145
      Y45.021
      X-123.8191 Y45.3699
      X-111.233 Y47.1987
      X-98.9326 Y50.2772
      X-86.6754 Y54.66
      X-74.014 Y59.7905
      G01 X-63.871 Y63.5
      X-73.5881 Y67.0456
      X-98.9326 Y76.7228
      X-111.233 Y79.8013
      X-123.8191 Y81.6301
      X-131.145 Y81.979
      Y64.2018
      X-133.145
      Y42.9234
      X-123.6273 Y43.3767
      X-110.8454 Y45.234
      X-98.3517 Y48.3609
      X-85.9628 Y52.7908
      X-73.2629 Y57.9368
      G01 X-57.639 Y63.5
      X-59.0428 Y63.8986
      X-98.3517 Y78.6391
      X-110.8454 Y81.766
      X-123.6273 Y83.6233
      X-133.145 Y84.0766
      Y64.2018
      X-135.145
      Y40.8259
      X-123.4355 Y41.3836
      X-110.4578 Y43.2693
      X-97.7708 Y46.4446
      X-85.2503 Y50.9216
      X-72.5118 Y56.0832
      G01 X-49.9311 Y63.5
      X-51.1864 Y63.7676
      X-97.7708 Y80.5554
      X-110.4578 Y83.7307
      X-123.4355 Y85.6164
      X-135.145 Y86.1741
      Y64.2018
      X-137.145
      Y38.75
      X-136.6916
      X-123.2437 Y39.3905
      X-110.0703 Y41.3046
      X-97.19 Y44.5283
      X-84.5377 Y49.0524
      X-71.7608 Y54.2296
      G01 X-38.399 Y63.5
      X-43.3959 Y64.1726
      X-97.19 Y82.4717
      X-110.0703 Y85.6954
      X-123.2437 Y87.6095
      X-136.6916 Y88.25
      X-137.145
      Y64.2018
      X-139.145
      Y36.75
      X-136.644
      X-123.0519 Y37.3974
      X-109.6827 Y39.3399
      X-96.6091 Y42.612
      X-83.8252 Y47.1831
      X-71.0097 Y52.376
      G02 X-28.575 R5.
      G03 Y64.85 R1.35
      G02 X-28.8102 R5.
      X-96.6091 Y84.388
      X-109.6827 Y87.6601
      X-123.0519 Y89.6026
      X-136.644 Y90.25
      X-139.145
      Y64.2018
      G00 Z3.
      X-115.145
      G01 Z-14.1111 F100
      G00
      G01 X-117.145 F200
      Y60.4867
      X-113.9459 Y60.9515
      X-103.7632 Y63.5
      X-113.9459 Y66.0485
      X-117.145 Y66.5133
      Y64.2018
      X-119.145
      Y58.1751
      X-113.5584 Y58.9868
      X-102.4179 Y61.775
      X-97.5938 Y63.5
      X-102.4179 Y65.225
      X-113.5584 Y68.0132
      X-119.145 Y68.8249
      Y64.2018
      X-121.145
      Y55.8634
      X-113.1708 Y57.0221
      X-101.837 Y59.8587
      X-91.6537 Y63.5
      X-101.837 Y67.1413
      X-113.1708 Y69.9779
      X-121.145 Y71.1366
      Y64.2018
      X-123.145
      Y53.5518
      X-112.7832 Y55.0574
      X-101.2561 Y57.9424
      X-89.5256 Y62.1369
      X-86.1617 Y63.5
      X-89.5256 Y64.8631
      X-101.2561 Y69.0576
      X-112.7832 Y71.9426
      X-123.145 Y73.4482
      Y64.2018
      X-125.145
      Y51.3135
      X-124.3946 Y51.3493
      X-112.3957 Y53.0927
      X-100.6753 Y56.0261
      X-88.813 Y60.2677
      X-80.8361 Y63.5
      X-88.813 Y66.7323
      X-100.6753 Y70.9739
      X-112.3957 Y73.9073
      X-124.3946 Y75.6507
      X-125.145 Y75.6865
      Y64.2018
      X-127.145
      Y49.216
      X-124.2027 Y49.3561
      X-112.0081 Y51.128
      X-100.0944 Y54.1098
      X-88.1005 Y58.3985
      X-75.5162 Y63.4977
      X-100.0944 Y72.8902
      X-112.0081 Y75.872
      X-124.2027 Y77.6439
      X-127.145 Y77.784
      Y64.2018
      X-129.145
      Y47.1185
      X-124.0109 Y47.363
      X-111.6205 Y49.1634
      X-99.5135 Y52.1935
      X-87.3879 Y56.5293
      X-74.7651 Y61.6441
      G01 X-69.7057 Y63.5
      X-74.2736 Y65.1668
      X-99.5135 Y74.8065
      X-111.6205 Y77.8366
      X-124.0109 Y79.637
      X-129.145 Y79.8815
      Y64.2018
      X-131.145
      Y45.021
      X-123.8191 Y45.3699
      X-111.233 Y47.1987
      X-98.9326 Y50.2772
      X-86.6754 Y54.66
      X-74.014 Y59.7905
      G01 X-63.871 Y63.5
      X-73.5881 Y67.0456
      X-98.9326 Y76.7228
      X-111.233 Y79.8013
      X-123.8191 Y81.6301
      X-131.145 Y81.979
      Y64.2018
      X-133.145
      Y42.9234
      X-123.6273 Y43.3767
      X-110.8454 Y45.234
      X-98.3517 Y48.3609
      X-85.9628 Y52.7908
      X-73.2629 Y57.9368
      G01 X-57.639 Y63.5
      X-59.0428 Y63.8986
      X-98.3517 Y78.6391
      X-110.8454 Y81.766
      X-123.6273 Y83.6233
      X-133.145 Y84.0766
      Y64.2018
      X-135.145
      Y40.8259
      X-123.4355 Y41.3836
      X-110.4578 Y43.2693
      X-97.7708 Y46.4446
      X-85.2503 Y50.9216
      X-72.5118 Y56.0832
      G01 X-49.9311 Y63.5
      X-51.1864 Y63.7676
      X-97.7708 Y80.5554
      X-110.4578 Y83.7307
      X-123.4355 Y85.6164
      X-135.145 Y86.1741
      Y64.2018
      X-137.145
      Y38.75
      X-136.6916
      X-123.2437 Y39.3905
      X-110.0703 Y41.3046
      X-97.19 Y44.5283
      X-84.5377 Y49.0524
      X-71.7608 Y54.2296
      G01 X-38.399 Y63.5
      X-43.3959 Y64.1726
      X-97.19 Y82.4717
      X-110.0703 Y85.6954
      X-123.2437 Y87.6095
      X-136.6916 Y88.25
      X-137.145
      Y64.2018
      X-139.145
      Y36.75
      X-136.644
      X-123.0519 Y37.3974
      X-109.6827 Y39.3399
      X-96.6091 Y42.612
      X-83.8252 Y47.1831
      X-71.0097 Y52.376
      G02 X-28.575 R5.
      G03 Y64.85 R1.35
      G02 X-28.8102 R5.
      X-96.6091 Y84.388
      X-109.6827 Y87.6601
      X-123.0519 Y89.6026
      X-136.644 Y90.25
      X-139.145
      Y64.2018
      G00 Z3.
      X-115.145
      G01 Z-16.9333 F100
      G00
      G01 X-117.145 F200
      Y60.4867
      X-113.9459 Y60.9515
      X-103.7632 Y63.5
      X-113.9459 Y66.0485
      X-117.145 Y66.5133
      Y64.2018
      X-119.145
      Y58.1751
      X-113.5584 Y58.9868
      X-102.4179 Y61.775
      X-97.5938 Y63.5
      X-102.4179 Y65.225
      X-113.5584 Y68.0132
      X-119.145 Y68.8249
      Y64.2018
      X-121.145
      Y55.8634
      X-113.1708 Y57.0221
      X-101.837 Y59.8587
      X-91.6537 Y63.5
      X-101.837 Y67.1413
      X-113.1708 Y69.9779
      X-121.145 Y71.1366
      Y64.2018
      X-123.145
      Y53.5518
      X-112.7832 Y55.0574
      X-101.2561 Y57.9424
      X-89.5256 Y62.1369
      X-86.1617 Y63.5
      X-89.5256 Y64.8631
      X-101.2561 Y69.0576
      X-112.7832 Y71.9426
      X-123.145 Y73.4482
      Y64.2018
      X-125.145
      Y51.3135
      X-124.3946 Y51.3493
      X-112.3957 Y53.0927
      X-100.6753 Y56.0261
      X-88.813 Y60.2677
      X-80.8361 Y63.5
      X-88.813 Y66.7323
      X-100.6753 Y70.9739
      X-112.3957 Y73.9073
      X-124.3946 Y75.6507
      X-125.145 Y75.6865
      Y64.2018
      X-127.145
      Y49.216
      X-124.2027 Y49.3561
      X-112.0081 Y51.128
      X-100.0944 Y54.1098
      X-88.1005 Y58.3985
      X-75.5162 Y63.4977
      X-100.0944 Y72.8902
      X-112.0081 Y75.872
      X-124.2027 Y77.6439
      X-127.145 Y77.784
      Y64.2018
      X-129.145
      Y47.1185
      X-124.0109 Y47.363
      X-111.6205 Y49.1634
      X-99.5135 Y52.1935
      X-87.3879 Y56.5293
      X-74.7651 Y61.6441
      G01 X-69.7057 Y63.5
      X-74.2736 Y65.1668
      X-99.5135 Y74.8065
      X-111.6205 Y77.8366
      X-124.0109 Y79.637
      X-129.145 Y79.8815
      Y64.2018
      X-131.145
      Y45.021
      X-123.8191 Y45.3699
      X-111.233 Y47.1987
      X-98.9326 Y50.2772
      X-86.6754 Y54.66
      X-74.014 Y59.7905
      G01 X-63.871 Y63.5
      X-73.5881 Y67.0456
      X-98.9326 Y76.7228
      X-111.233 Y79.8013
      X-123.8191 Y81.6301
      X-131.145 Y81.979
      Y64.2018
      X-133.145
      Y42.9234
      X-123.6273 Y43.3767
      X-110.8454 Y45.234
      X-98.3517 Y48.3609
      X-85.9628 Y52.7908
      X-73.2629 Y57.9368
      G01 X-57.639 Y63.5
      X-59.0428 Y63.8986
      X-98.3517 Y78.6391
      X-110.8454 Y81.766
      X-123.6273 Y83.6233
      X-133.145 Y84.0766
      Y64.2018
      X-135.145
      Y40.8259
      X-123.4355 Y41.3836
      X-110.4578 Y43.2693
      X-97.7708 Y46.4446
      X-85.2503 Y50.9216
      X-72.5118 Y56.0832
      G01 X-49.9311 Y63.5
      X-51.1864 Y63.7676
      X-97.7708 Y80.5554
      X-110.4578 Y83.7307
      X-123.4355 Y85.6164
      X-135.145 Y86.1741
      Y64.2018
      X-137.145
      Y38.75
      X-136.6916
      X-123.2437 Y39.3905
      X-110.0703 Y41.3046
      X-97.19 Y44.5283
      X-84.5377 Y49.0524
      X-71.7608 Y54.2296
      G01 X-38.399 Y63.5
      X-43.3959 Y64.1726
      X-97.19 Y82.4717
      X-110.0703 Y85.6954
      X-123.2437 Y87.6095
      X-136.6916 Y88.25
      X-137.145
      Y64.2018
      X-139.145
      Y36.75
      X-136.644
      X-123.0519 Y37.3974
      X-109.6827 Y39.3399
      X-96.6091 Y42.612
      X-83.8252 Y47.1831
      X-71.0097 Y52.376
      G02 X-28.575 R5.
      G03 Y64.85 R1.35
      G02 X-28.8102 R5.
      X-96.6091 Y84.388
      X-109.6827 Y87.6601
      X-123.0519 Y89.6026
      X-136.644 Y90.25
      X-139.145
      Y64.2018
      G00 Z3.
      X-115.145
      G01 Z-19.7556 F100
      G00
      G01 X-117.145 F200
      Y60.4867
      X-113.9459 Y60.9515
      X-103.7632 Y63.5
      X-113.9459 Y66.0485
      X-117.145 Y66.5133
      Y64.2018
      X-119.145
      Y58.1751
      X-113.5584 Y58.9868
      X-102.4179 Y61.775
      X-97.5938 Y63.5
      X-102.4179 Y65.225
      X-113.5584 Y68.0132
      X-119.145 Y68.8249
      Y64.2018
      X-121.145
      Y55.8634
      X-113.1708 Y57.0221
      X-101.837 Y59.8587
      X-91.6537 Y63.5
      X-101.837 Y67.1413
      X-113.1708 Y69.9779
      X-121.145 Y71.1366
      Y64.2018
      X-123.145
      Y53.5518
      X-112.7832 Y55.0574
      X-101.2561 Y57.9424
      X-89.5256 Y62.1369
      X-86.1617 Y63.5
      X-89.5256 Y64.8631
      X-101.2561 Y69.0576
      X-112.7832 Y71.9426
      X-123.145 Y73.4482
      Y64.2018
      X-125.145
      Y51.3135
      X-124.3946 Y51.3493
      X-112.3957 Y53.0927
      X-100.6753 Y56.0261
      X-88.813 Y60.2677
      X-80.8361 Y63.5
      X-88.813 Y66.7323
      X-100.6753 Y70.9739
      X-112.3957 Y73.9073
      X-124.3946 Y75.6507
      X-125.145 Y75.6865
      Y64.2018
      X-127.145
      Y49.216
      X-124.2027 Y49.3561
      X-112.0081 Y51.128
      X-100.0944 Y54.1098
      X-88.1005 Y58.3985
      X-75.5162 Y63.4977
      X-100.0944 Y72.8902
      X-112.0081 Y75.872
      X-124.2027 Y77.6439
      X-127.145 Y77.784
      Y64.2018
      X-129.145
      Y47.1185
      X-124.0109 Y47.363
      X-111.6205 Y49.1634
      X-99.5135 Y52.1935
      X-87.3879 Y56.5293
      X-74.7651 Y61.6441
      G01 X-69.7057 Y63.5
      X-74.2736 Y65.1668
      X-99.5135 Y74.8065
      X-111.6205 Y77.8366
      X-124.0109 Y79.637
      X-129.145 Y79.8815
      Y64.2018
      X-131.145
      Y45.021
      X-123.8191 Y45.3699
      X-111.233 Y47.1987
      X-98.9326 Y50.2772
      X-86.6754 Y54.66
      X-74.014 Y59.7905
      G01 X-63.871 Y63.5
      X-73.5881 Y67.0456
      X-98.9326 Y76.7228
      X-111.233 Y79.8013
      X-123.8191 Y81.6301
      X-131.145 Y81.979
      Y64.2018
      X-133.145
      Y42.9234
      X-123.6273 Y43.3767
      X-110.8454 Y45.234
      X-98.3517 Y48.3609
      X-85.9628 Y52.7908
      X-73.2629 Y57.9368
      G01 X-57.639 Y63.5
      X-59.0428 Y63.8986
      X-98.3517 Y78.6391
      X-110.8454 Y81.766
      X-123.6273 Y83.6233
      X-133.145 Y84.0766
      Y64.2018
      X-135.145
      Y40.8259
      X-123.4355 Y41.3836
      X-110.4578 Y43.2693
      X-97.7708 Y46.4446
      X-85.2503 Y50.9216
      X-72.5118 Y56.0832
      G01 X-49.9311 Y63.5
      X-51.1864 Y63.7676
      X-97.7708 Y80.5554
      X-110.4578 Y83.7307
      X-123.4355 Y85.6164
      X-135.145 Y86.1741
      Y64.2018
      X-137.145
      Y38.75
      X-136.6916
      X-123.2437 Y39.3905
      X-110.0703 Y41.3046
      X-97.19 Y44.5283
      X-84.5377 Y49.0524
      X-71.7608 Y54.2296
      G01 X-38.399 Y63.5
      X-43.3959 Y64.1726
      X-97.19 Y82.4717
      X-110.0703 Y85.6954
      X-123.2437 Y87.6095
      X-136.6916 Y88.25
      X-137.145
      Y64.2018
      X-139.145
      Y36.75
      X-136.644
      X-123.0519 Y37.3974
      X-109.6827 Y39.3399
      X-96.6091 Y42.612
      X-83.8252 Y47.1831
      X-71.0097 Y52.376
      G02 X-28.575 R5.
      G03 Y64.85 R1.35
      G02 X-28.8102 R5.
      X-96.6091 Y84.388
      X-109.6827 Y87.6601
      X-123.0519 Y89.6026
      X-136.644 Y90.25
      X-139.145
      Y64.2018
      G00 Z3.
      X-115.145
      G01 Z-22.5778 F100
      G00
      G01 X-117.145 F200
      Y60.4867
      X-113.9459 Y60.9515
      X-103.7632 Y63.5
      X-113.9459 Y66.0485
      X-117.145 Y66.5133
      Y64.2018
      X-119.145
      Y58.1751
      X-113.5584 Y58.9868
      X-102.4179 Y61.775
      X-97.5938 Y63.5
      X-102.4179 Y65.225
      X-113.5584 Y68.0132
      X-119.145 Y68.8249
      Y64.2018
      X-121.145
      Y55.8634
      X-113.1708 Y57.0221
      X-101.837 Y59.8587
      X-91.6537 Y63.5
      X-101.837 Y67.1413
      X-113.1708 Y69.9779
      X-121.145 Y71.1366
      Y64.2018
      X-123.145
      Y53.5518
      X-112.7832 Y55.0574
      X-101.2561 Y57.9424
      X-89.5256 Y62.1369
      X-86.1617 Y63.5
      X-89.5256 Y64.8631
      X-101.2561 Y69.0576
      X-112.7832 Y71.9426
      X-123.145 Y73.4482
      Y64.2018
      X-125.145
      Y51.3135
      X-124.3946 Y51.3493
      X-112.3957 Y53.0927
      X-100.6753 Y56.0261
      X-88.813 Y60.2677
      X-80.8361 Y63.5
      X-88.813 Y66.7323
      X-100.6753 Y70.9739
      X-112.3957 Y73.9073
      X-124.3946 Y75.6507
      X-125.145 Y75.6865
      Y64.2018
      X-127.145
      Y49.216
      X-124.2027 Y49.3561
      X-112.0081 Y51.128
      X-100.0944 Y54.1098
      X-88.1005 Y58.3985
      X-75.5162 Y63.4977
      X-100.0944 Y72.8902
      X-112.0081 Y75.872
      X-124.2027 Y77.6439
      X-127.145 Y77.784
      Y64.2018
      X-129.145
      Y47.1185
      X-124.0109 Y47.363
      X-111.6205 Y49.1634
      X-99.5135 Y52.1935
      X-87.3879 Y56.5293
      X-74.7651 Y61.6441
      G01 X-69.7057 Y63.5
      X-74.2736 Y65.1668
      X-99.5135 Y74.8065
      X-111.6205 Y77.8366
      X-124.0109 Y79.637
      X-129.145 Y79.8815
      Y64.2018
      X-131.145
      Y45.021
      X-123.8191 Y45.3699
      X-111.233 Y47.1987
      X-98.9326 Y50.2772
      X-86.6754 Y54.66
      X-74.014 Y59.7905
      G01 X-63.871 Y63.5
      X-73.5881 Y67.0456
      X-98.9326 Y76.7228
      X-111.233 Y79.8013
      X-123.8191 Y81.6301
      X-131.145 Y81.979
      Y64.2018
      X-133.145
      Y42.9234
      X-123.6273 Y43.3767
      X-110.8454 Y45.234
      X-98.3517 Y48.3609
      X-85.9628 Y52.7908
      X-73.2629 Y57.9368
      G01 X-57.639 Y63.5
      X-59.0428 Y63.8986
      X-98.3517 Y78.6391
      X-110.8454 Y81.766
      X-123.6273 Y83.6233
      X-133.145 Y84.0766
      Y64.2018
      X-135.145
      Y40.8259
      X-123.4355 Y41.3836
      X-110.4578 Y43.2693
      X-97.7708 Y46.4446
      X-85.2503 Y50.9216
      X-72.5118 Y56.0832
      G01 X-49.9311 Y63.5
      X-51.1864 Y63.7676
      X-97.7708 Y80.5554
      X-110.4578 Y83.7307
      X-123.4355 Y85.6164
      X-135.145 Y86.1741
      Y64.2018
      X-137.145
      Y38.75
      X-136.6916
      X-123.2437 Y39.3905
      X-110.0703 Y41.3046
      X-97.19 Y44.5283
      X-84.5377 Y49.0524
      X-71.7608 Y54.2296
      G01 X-38.399 Y63.5
      X-43.3959 Y64.1726
      X-97.19 Y82.4717
      X-110.0703 Y85.6954
      X-123.2437 Y87.6095
      X-136.6916 Y88.25
      X-137.145
      Y64.2018
      X-139.145
      Y36.75
      X-136.644
      X-123.0519 Y37.3974
      X-109.6827 Y39.3399
      X-96.6091 Y42.612
      X-83.8252 Y47.1831
      X-71.0097 Y52.376
      G02 X-28.575 R5.
      G03 Y64.85 R1.35
      G02 X-28.8102 R5.
      X-96.6091 Y84.388
      X-109.6827 Y87.6601
      X-123.0519 Y89.6026
      X-136.644 Y90.25
      X-139.145
      Y64.2018
      G00 Z3.
      X-115.145
      G01 Z-25.4 F100
      G00
      G01 X-117.145 F200
      Y60.4867
      X-113.9459 Y60.9515
      X-103.7632 Y63.5
      X-113.9459 Y66.0485
      X-117.145 Y66.5133
      Y64.2018
      X-119.145
      Y58.1751
      X-113.5584 Y58.9868
      X-102.4179 Y61.775
      X-97.5938 Y63.5
      X-102.4179 Y65.225
      X-113.5584 Y68.0132
      X-119.145 Y68.8249
      Y64.2018
      X-121.145
      Y55.8634
      X-113.1708 Y57.0221
      X-101.837 Y59.8587
      X-91.6537 Y63.5
      X-101.837 Y67.1413
      X-113.1708 Y69.9779
      X-121.145 Y71.1366
      Y64.2018
      X-123.145
      Y53.5518
      X-112.7832 Y55.0574
      X-101.2561 Y57.9424
      X-89.5256 Y62.1369
      X-86.1617 Y63.5
      X-89.5256 Y64.8631
      X-101.2561 Y69.0576
      X-112.7832 Y71.9426
      X-123.145 Y73.4482
      Y64.2018
      X-125.145
      Y51.3135
      X-124.3946 Y51.3493
      X-112.3957 Y53.0927
      X-100.6753 Y56.0261
      X-88.813 Y60.2677
      X-80.8361 Y63.5
      X-88.813 Y66.7323
      X-100.6753 Y70.9739
      X-112.3957 Y73.9073
      X-124.3946 Y75.6507
      X-125.145 Y75.6865
      Y64.2018
      X-127.145
      Y49.216
      X-124.2027 Y49.3561
      X-112.0081 Y51.128
      X-100.0944 Y54.1098
      X-88.1005 Y58.3985
      X-75.5162 Y63.4977
      X-100.0944 Y72.8902
      X-112.0081 Y75.872
      X-124.2027 Y77.6439
      X-127.145 Y77.784
      Y64.2018
      X-129.145
      Y47.1185
      X-124.0109 Y47.363
      X-111.6205 Y49.1634
      X-99.5135 Y52.1935
      X-87.3879 Y56.5293
      X-74.7651 Y61.6441
      G01 X-69.7057 Y63.5
      X-74.2736 Y65.1668
      X-99.5135 Y74.8065
      X-111.6205 Y77.8366
      X-124.0109 Y79.637
      X-129.145 Y79.8815
      Y64.2018
      X-131.145
      Y45.021
      X-123.8191 Y45.3699
      X-111.233 Y47.1987
      X-98.9326 Y50.2772
      X-86.6754 Y54.66
      X-74.014 Y59.7905
      G01 X-63.871 Y63.5
      X-73.5881 Y67.0456
      X-98.9326 Y76.7228
      X-111.233 Y79.8013
      X-123.8191 Y81.6301
      X-131.145 Y81.979
      Y64.2018
      X-133.145
      Y42.9234
      X-123.6273 Y43.3767
      X-110.8454 Y45.234
      X-98.3517 Y48.3609
      X-85.9628 Y52.7908
      X-73.2629 Y57.9368
      G01 X-57.639 Y63.5
      X-59.0428 Y63.8986
      X-98.3517 Y78.6391
      X-110.8454 Y81.766
      X-123.6273 Y83.6233
      X-133.145 Y84.0766
      Y64.2018
      X-135.145
      Y40.8259
      X-123.4355 Y41.3836
      X-110.4578 Y43.2693
      X-97.7708 Y46.4446
      X-85.2503 Y50.9216
      X-72.5118 Y56.0832
      G01 X-49.9311 Y63.5
      X-51.1864 Y63.7676
      X-97.7708 Y80.5554
      X-110.4578 Y83.7307
      X-123.4355 Y85.6164
      X-135.145 Y86.1741
      Y64.2018
      X-137.145
      Y38.75
      X-136.6916
      X-123.2437 Y39.3905
      X-110.0703 Y41.3046
      X-97.19 Y44.5283
      X-84.5377 Y49.0524
      X-71.7608 Y54.2296
      G01 X-38.399 Y63.5
      X-43.3959 Y64.1726
      X-97.19 Y82.4717
      X-110.0703 Y85.6954
      X-123.2437 Y87.6095
      X-136.6916 Y88.25
      X-137.145
      Y64.2018
      X-139.145
      Y36.75
      X-136.644
      X-123.0519 Y37.3974
      X-109.6827 Y39.3399
      X-96.6091 Y42.612
      X-83.8252 Y47.1831
      X-71.0097 Y52.376
      G02 X-28.575 R5.
      G03 Y64.85 R1.35
      G02 X-28.8102 R5.
      X-96.6091 Y84.388
      X-109.6827 Y87.6601
      X-123.0519 Y89.6026
      X-136.644 Y90.25
      X-139.145
      Y64.2018
      G00 Z3.
      X30.905
      G01 Z-2.8222 F100
      G00
      G01 X28.905 F200
      Y60.4867
      X32.1041 Y60.9515
      X42.2868 Y63.5
      X32.1041 Y66.0485
      X28.905 Y66.5133
      Y64.2018
      X26.905
      Y58.1751
      X32.4916 Y58.9868
      X43.6321 Y61.775
      X48.4562 Y63.5
      X43.6321 Y65.225
      X32.4916 Y68.0132
      X26.905 Y68.8249
      Y64.2018
      X24.905
      Y55.8634
      X32.8792 Y57.0221
      X44.213 Y59.8587
      X54.3963 Y63.5
      X44.213 Y67.1413
      X32.8792 Y69.9779
      X24.905 Y71.1366
      Y64.2018
      X22.905
      Y53.5518
      X33.2668 Y55.0574
      X44.7939 Y57.9424
      X56.5244 Y62.1369
      X59.8883 Y63.5
      X56.5244 Y64.8631
      X44.7939 Y69.0576
      X33.2668 Y71.9426
      X22.905 Y73.4482
      Y64.2018
      X20.905
      Y51.3135
      X21.6554 Y51.3493
      X33.6543 Y53.0927
      X45.3747 Y56.0261
      X57.237 Y60.2677
      X65.2139 Y63.5
      X57.237 Y66.7323
      X45.3747 Y70.9739
      X33.6543 Y73.9073
      X21.6554 Y75.6507
      X20.905 Y75.6865
      Y64.2018
      X18.905
      Y49.216
      X21.8473 Y49.3561
      X34.0419 Y51.128
      X45.9556 Y54.1098
      X57.9495 Y58.3985
      X70.5338 Y63.4977
      G01 X57.9495 Y68.6015
      X45.9556 Y72.8902
      X34.0419 Y75.872
      X21.8473 Y77.6439
      X18.905 Y77.784
      Y64.2018
      X16.905
      Y47.1185
      X22.0391 Y47.363
      X34.4295 Y49.1634
      X46.5365 Y52.1935
      X58.6621 Y56.5293
      X71.2849 Y61.6441
      G02 X71.7764 Y61.8332 R15.
      G01 X76.3443 Y63.5
      X71.7764 Y65.1668
      G02 X71.2849 Y65.3559 R15.
      G01 X58.6621 Y70.4707
      X46.5365 Y74.8065
      X34.4295 Y77.8366
      X22.0391 Y79.637
      X16.905 Y79.8815
      Y64.2018
      X14.905
      Y45.021
      X22.2309 Y45.3699
      X34.817 Y47.1987
      X47.1174 Y50.2772
      X59.3746 Y54.66
      X72.036 Y59.7905
      G02 X72.4619 Y59.9544 R13.
      G01 X82.179 Y63.5
      X72.4619 Y67.0456
      G02 X72.036 Y67.2095 R13.
      G01 X59.3746 Y72.34
      X47.1174 Y76.7228
      X34.817 Y79.8013
      X22.2309 Y81.6301
      X14.905 Y81.979
      Y64.2018
      X12.905
      Y42.9234
      X22.4227 Y43.3767
      X35.2046 Y45.234
      X47.6983 Y48.3609
      X60.0872 Y52.7908
      X72.7871 Y57.9368
      G02 X73.1475 Y58.0756 R11.
      G01 X86.2414 Y62.8533
      G02 X87.0072 Y63.1014 R11.
      G01 X88.411 Y63.5
      X87.0072 Y63.8986
      G02 X86.2414 Y64.1467 R11.
      G01 X73.1475 Y68.9244
      G02 X72.7871 Y69.0632 R11.
      G01 X60.0872 Y74.2092
      X47.6983 Y78.6391
      X35.2046 Y81.766
      X22.4227 Y83.6233
      X12.905 Y84.0766
      Y64.2018
      X10.905
      Y40.8259
      X22.6145 Y41.3836
      X35.5922 Y43.2693
      X48.2792 Y46.4446
      X60.7997 Y50.9216
      X73.5382 Y56.0832
      G02 X73.833 Y56.1967 R9.
      G01 X86.9269 Y60.9745
      G02 X87.5536 Y61.1775 R9.
      G01 X94.2817 Y63.0879
      G02 X94.8636 Y63.2324 R9.
      G01 X96.1189 Y63.5
      X94.8636 Y63.7676
      G02 X94.2817 Y63.9121 R9.
      G01 X87.5536 Y65.8225
      G02 X86.9269 Y66.0255 R9.
      G01 X73.833 Y70.8033
      G02 X73.5382 Y70.9168 R9.
      G01 X60.7997 Y76.0784
      X48.2792 Y80.5554
      X35.5922 Y83.7307
      X22.6145 Y85.6164
      X10.905 Y86.1741
      Y64.2018
      X8.905
      Y38.75
      X9.3584
      X22.8063 Y39.3905
      X35.9797 Y41.3046
      X48.86 Y44.5283
      X61.5123 Y49.0524
      X74.2892 Y54.2296
      G02 X74.5186 Y54.3179 R7.
      G01 X87.6125 Y59.0956
      G02 X88.0999 Y59.2535 R7.
      G01 X94.828 Y61.164
      G02 X95.2806 Y61.2763 R7.
      G01 X102.1285 Y62.7361
      G02 X102.6541 Y62.8274 R7.
      G01 X107.651 Y63.5
      X102.6541 Y64.1726
      G02 X102.1285 Y64.2639 R7.
      G01 X95.2806 Y65.7237
      G02 X94.828 Y65.836 R7.
      G01 X88.0999 Y67.7465
      G02 X87.6125 Y67.9044 R7.
      G01 X74.5186 Y72.6821
      G02 X74.2892 Y72.7704 R7.
      G01 X61.5123 Y77.9476
      X48.86 Y82.4717
      X35.9797 Y85.6954
      X22.8063 Y87.6095
      X9.3584 Y88.25
      X8.905
      Y64.2018
      X6.905
      Y36.75
      X9.406
      X22.9981 Y37.3974
      X36.3673 Y39.3399
      X49.4409 Y42.612
      X62.2248 Y47.1831
      X75.0403 Y52.376
      G02 X75.2042 Y52.4391 R5.
      G01 X88.298 Y57.2168
      G02 X88.6462 Y57.3296 R5.
      G01 X95.3743 Y59.24
      G02 X95.6976 Y59.3203 R5.
      G01 X102.5454 Y60.7801
      G02 X102.9209 Y60.8453 R5.
      G01 X109.8466 Y61.7775
      G02 X110.2784 Y61.8167 R5.
      G01 X117.2398 Y62.1445
      G02 X117.475 R5.
      G03 Y64.85 R-1.35
      G02 X117.2398 R5.
      G01 X110.2784 Y65.1833
      G02 X109.8466 Y65.2225 R5.
      G01 X102.9209 Y66.1547
      G02 X102.5454 Y66.2199 R5.
      G01 X95.6976 Y67.6797
      G02 X95.3743 Y67.76 R5.
      G01 X88.6462 Y69.6704
      G02 X88.298 Y69.7832 R5.
      G01 X75.2042 Y74.5609
      G02 X75.0403 Y74.624 R5.
      G01 X62.2248 Y79.8169
      X49.4409 Y84.388
      X36.3673 Y87.6601
      X22.9981 Y89.6026
      X9.406 Y90.25
      X6.905
      Y64.2018
      G00 Z3.
      X30.905
      G01 Z-5.6444 F100
      G00
      G01 X28.905 F200
      Y60.4867
      X32.1041 Y60.9515
      X42.2868 Y63.5
      X32.1041 Y66.0485
      X28.905 Y66.5133
      Y64.2018
      X26.905
      Y58.1751
      X32.4916 Y58.9868
      X43.6321 Y61.775
      X48.4562 Y63.5
      X43.6321 Y65.225
      X32.4916 Y68.0132
      X26.905 Y68.8249
      Y64.2018
      X24.905
      Y55.8634
      X32.8792 Y57.0221
      X44.213 Y59.8587
      X54.3963 Y63.5
      X44.213 Y67.1413
      X32.8792 Y69.9779
      X24.905 Y71.1366
      Y64.2018
      X22.905
      Y53.5518
      X33.2668 Y55.0574
      X44.7939 Y57.9424
      X56.5244 Y62.1369
      X59.8883 Y63.5
      X56.5244 Y64.8631
      X44.7939 Y69.0576
      X33.2668 Y71.9426
      X22.905 Y73.4482
      Y64.2018
      X20.905
      Y51.3135
      X21.6554 Y51.3493
      X33.6543 Y53.0927
      X45.3747 Y56.0261
      X57.237 Y60.2677
      X65.2139 Y63.5
      X57.237 Y66.7323
      X45.3747 Y70.9739
      X33.6543 Y73.9073
      X21.6554 Y75.6507
      X20.905 Y75.6865
      Y64.2018
      X18.905
      Y49.216
      X21.8473 Y49.3561
      X34.0419 Y51.128
      X45.9556 Y54.1098
      X57.9495 Y58.3985
      X70.5338 Y63.4977
      X45.9556 Y72.8902
      X34.0419 Y75.872
      X21.8473 Y77.6439
      X18.905 Y77.784
      Y64.2018
      X16.905
      Y47.1185
      X22.0391 Y47.363
      X34.4295 Y49.1634
      X46.5365 Y52.1935
      X58.6621 Y56.5293
      X71.2849 Y61.6441
      G01 X76.3443 Y63.5
      X71.7764 Y65.1668
      X46.5365 Y74.8065
      X34.4295 Y77.8366
      X22.0391 Y79.637
      X16.905 Y79.8815
      Y64.2018
      X14.905
      Y45.021
      X22.2309 Y45.3699
      X34.817 Y47.1987
      X47.1174 Y50.2772
      X59.3746 Y54.66
      X72.036 Y59.7905
      G01 X82.179 Y63.5
      X72.4619 Y67.0456
      G01 X59.3746 Y72.34
      X47.1174 Y76.7228
      X34.817 Y79.8013
      X22.2309 Y81.6301
      X14.905 Y81.979
      Y64.2018
      X12.905
      Y42.9234
      X22.4227 Y43.3767
      X35.2046 Y45.234
      X47.6983 Y48.3609
      X60.0872 Y52.7908
      X72.7871 Y57.9368
      G01 X88.411 Y63.5
      X87.0072 Y63.8986
      X47.6983 Y78.6391
      X35.2046 Y81.766
      X22.4227 Y83.6233
      X12.905 Y84.0766
      Y64.2018
      X10.905
      Y40.8259
      X22.6145 Y41.3836
      X35.5922 Y43.2693
      X48.2792 Y46.4446
      X60.7997 Y50.9216
      X73.5382 Y56.0832
      G01 X96.1189 Y63.5
      X94.8636 Y63.7676
      X48.2792 Y80.5554
      X35.5922 Y83.7307
      X22.6145 Y85.6164
      X10.905 Y86.1741
      Y64.2018
      X8.905
      Y38.75
      X9.3584
      X22.8063 Y39.3905
      X35.9797 Y41.3046
      X48.86 Y44.5283
      X61.5123 Y49.0524
      X74.2892 Y54.2296
      G01 X94.828 Y61.164
      G01 X107.651 Y63.5
      X102.6541 Y64.1726
      X48.86 Y82.4717
      X35.9797 Y85.6954
      X22.8063 Y87.6095
      X9.3584 Y88.25
      X8.905
      Y64.2018
      X6.905
      Y36.75
      X9.406
      X22.9981 Y37.3974
      X36.3673 Y39.3399
      X49.4409 Y42.612
      X62.2248 Y47.1831
      X75.0403 Y52.376
      G01 X95.3743 Y59.24
      G02 X117.475 R5.
      G03 Y64.85 R-1.35
      G02 X117.2398 R5.
      X49.4409 Y84.388
      X36.3673 Y87.6601
      X22.9981 Y89.6026
      X9.406 Y90.25
      X6.905
      Y64.2018
      G00 Z3.
      X30.905
      G01 Z-8.4667 F100
      G00
      G01 X28.905 F200
      Y60.4867
      X32.1041 Y60.9515
      X42.2868 Y63.5
      X32.1041 Y66.0485
      X28.905 Y66.5133
      Y64.2018
      X26.905
      Y58.1751
      X32.4916 Y58.9868
      X43.6321 Y61.775
      X48.4562 Y63.5
      X43.6321 Y65.225
      X32.4916 Y68.0132
      X26.905 Y68.8249
      Y64.2018
      X24.905
      Y55.8634
      X32.8792 Y57.0221
      X44.213 Y59.8587
      X54.3963 Y63.5
      X44.213 Y67.1413
      X32.8792 Y69.9779
      X24.905 Y71.1366
      Y64.2018
      X22.905
      Y53.5518
      X33.2668 Y55.0574
      X44.7939 Y57.9424
      X56.5244 Y62.1369
      X59.8883 Y63.5
      X56.5244 Y64.8631
      X44.7939 Y69.0576
      X33.2668 Y71.9426
      X22.905 Y73.4482
      Y64.2018
      X20.905
      Y51.3135
      X21.6554 Y51.3493
      X33.6543 Y53.0927
      X45.3747 Y56.0261
      X57.237 Y60.2677
      X65.2139 Y63.5
      X57.237 Y66.7323
      X45.3747 Y70.9739
      X33.6543 Y73.9073
      X21.6554 Y75.6507
      X20.905 Y75.6865
      Y64.2018
      X18.905
      Y49.216
      X21.8473 Y49.3561
      X34.0419 Y51.128
      X45.9556 Y54.1098
      X57.9495 Y58.3985
      X70.5338 Y63.4977
      X45.9556 Y72.8902
      X34.0419 Y75.872
      X21.8473 Y77.6439
      X18.905 Y77.784
      Y64.2018
      X16.905
      Y47.1185
      X22.0391 Y47.363
      X34.4295 Y49.1634
      X46.5365 Y52.1935
      X58.6621 Y56.5293
      X71.2849 Y61.6441
      G01 X76.3443 Y63.5
      X71.7764 Y65.1668
      X46.5365 Y74.8065
      X34.4295 Y77.8366
      X22.0391 Y79.637
      X16.905 Y79.8815
      Y64.2018
      X14.905
      Y45.021
      X22.2309 Y45.3699
      X34.817 Y47.1987
      X47.1174 Y50.2772
      X59.3746 Y54.66
      X72.036 Y59.7905
      G01 X82.179 Y63.5
      X72.4619 Y67.0456
      G01 X59.3746 Y72.34
      X47.1174 Y76.7228
      X34.817 Y79.8013
      X22.2309 Y81.6301
      X14.905 Y81.979
      Y64.2018
      X12.905
      Y42.9234
      X22.4227 Y43.3767
      X35.2046 Y45.234
      X47.6983 Y48.3609
      X60.0872 Y52.7908
      X72.7871 Y57.9368
      G01 X88.411 Y63.5
      X87.0072 Y63.8986
      X47.6983 Y78.6391
      X35.2046 Y81.766
      X22.4227 Y83.6233
      X12.905 Y84.0766
      Y64.2018
      X10.905
      Y40.8259
      X22.6145 Y41.3836
      X35.5922 Y43.2693
      X48.2792 Y46.4446
      X60.7997 Y50.9216
      X73.5382 Y56.0832
      G01 X96.1189 Y63.5
      X94.8636 Y63.7676
      X48.2792 Y80.5554
      X35.5922 Y83.7307
      X22.6145 Y85.6164
      X10.905 Y86.1741
      Y64.2018
      X8.905
      Y38.75
      X9.3584
      X22.8063 Y39.3905
      X35.9797 Y41.3046
      X48.86 Y44.5283
      X61.5123 Y49.0524
      X74.2892 Y54.2296
      G01 X94.828 Y61.164
      G01 X107.651 Y63.5
      X102.6541 Y64.1726
      X48.86 Y82.4717
      X35.9797 Y85.6954
      X22.8063 Y87.6095
      X9.3584 Y88.25
      X8.905
      Y64.2018
      X6.905
      Y36.75
      X9.406
      X22.9981 Y37.3974
      X36.3673 Y39.3399
      X49.4409 Y42.612
      X62.2248 Y47.1831
      X75.0403 Y52.376
      G01 X95.3743 Y59.24
      G02 X117.475 R5.
      G03 Y64.85 R-1.35
      G02 X117.2398 R5.
      X49.4409 Y84.388
      X36.3673 Y87.6601
      X22.9981 Y89.6026
      X9.406 Y90.25
      X6.905
      Y64.2018
      G00 Z3.
      X30.905
      G01 Z-11.2889 F100
      G00
      G01 X28.905 F200
      Y60.4867
      X32.1041 Y60.9515
      X42.2868 Y63.5
      X32.1041 Y66.0485
      X28.905 Y66.5133
      Y64.2018
      X26.905
      Y58.1751
      X32.4916 Y58.9868
      X43.6321 Y61.775
      X48.4562 Y63.5
      X43.6321 Y65.225
      X32.4916 Y68.0132
      X26.905 Y68.8249
      Y64.2018
      X24.905
      Y55.8634
      X32.8792 Y57.0221
      X44.213 Y59.8587
      X54.3963 Y63.5
      X44.213 Y67.1413
      X32.8792 Y69.9779
      X24.905 Y71.1366
      Y64.2018
      X22.905
      Y53.5518
      X33.2668 Y55.0574
      X44.7939 Y57.9424
      X56.5244 Y62.1369
      X59.8883 Y63.5
      X56.5244 Y64.8631
      X44.7939 Y69.0576
      X33.2668 Y71.9426
      X22.905 Y73.4482
      Y64.2018
      X20.905
      Y51.3135
      X21.6554 Y51.3493
      X33.6543 Y53.0927
      X45.3747 Y56.0261
      X57.237 Y60.2677
      X65.2139 Y63.5
      X57.237 Y66.7323
      X45.3747 Y70.9739
      X33.6543 Y73.9073
      X21.6554 Y75.6507
      X20.905 Y75.6865
      Y64.2018
      X18.905
      Y49.216
      X21.8473 Y49.3561
      X34.0419 Y51.128
      X45.9556 Y54.1098
      X57.9495 Y58.3985
      X70.5338 Y63.4977
      X45.9556 Y72.8902
      X34.0419 Y75.872
      X21.8473 Y77.6439
      X18.905 Y77.784
      Y64.2018
      X16.905
      Y47.1185
      X22.0391 Y47.363
      X34.4295 Y49.1634
      X46.5365 Y52.1935
      X58.6621 Y56.5293
      X71.2849 Y61.6441
      G01 X76.3443 Y63.5
      X71.7764 Y65.1668
      X46.5365 Y74.8065
      X34.4295 Y77.8366
      X22.0391 Y79.637
      X16.905 Y79.8815
      Y64.2018
      X14.905
      Y45.021
      X22.2309 Y45.3699
      X34.817 Y47.1987
      X47.1174 Y50.2772
      X59.3746 Y54.66
      X72.036 Y59.7905
      G01 X82.179 Y63.5
      X72.4619 Y67.0456
      G01 X59.3746 Y72.34
      X47.1174 Y76.7228
      X34.817 Y79.8013
      X22.2309 Y81.6301
      X14.905 Y81.979
      Y64.2018
      X12.905
      Y42.9234
      X22.4227 Y43.3767
      X35.2046 Y45.234
      X47.6983 Y48.3609
      X60.0872 Y52.7908
      X72.7871 Y57.9368
      G01 X88.411 Y63.5
      X87.0072 Y63.8986
      X47.6983 Y78.6391
      X35.2046 Y81.766
      X22.4227 Y83.6233
      X12.905 Y84.0766
      Y64.2018
      X10.905
      Y40.8259
      X22.6145 Y41.3836
      X35.5922 Y43.2693
      X48.2792 Y46.4446
      X60.7997 Y50.9216
      X73.5382 Y56.0832
      G01 X96.1189 Y63.5
      X94.8636 Y63.7676
      X48.2792 Y80.5554
      X35.5922 Y83.7307
      X22.6145 Y85.6164
      X10.905 Y86.1741
      Y64.2018
      X8.905
      Y38.75
      X9.3584
      X22.8063 Y39.3905
      X35.9797 Y41.3046
      X48.86 Y44.5283
      X61.5123 Y49.0524
      X74.2892 Y54.2296
      G01 X94.828 Y61.164
      G01 X107.651 Y63.5
      X102.6541 Y64.1726
      X48.86 Y82.4717
      X35.9797 Y85.6954
      X22.8063 Y87.6095
      X9.3584 Y88.25
      X8.905
      Y64.2018
      X6.905
      Y36.75
      X9.406
      X22.9981 Y37.3974
      X36.3673 Y39.3399
      X49.4409 Y42.612
      X62.2248 Y47.1831
      X75.0403 Y52.376
      G01 X95.3743 Y59.24
      G02 X117.475 R5.
      G03 Y64.85 R-1.35
      G02 X117.2398 R5.
      X49.4409 Y84.388
      X36.3673 Y87.6601
      X22.9981 Y89.6026
      X9.406 Y90.25
      X6.905
      Y64.2018
      G00 Z3.
      X30.905
      G01 Z-14.1111 F100
      G00
      G01 X28.905 F200
      Y60.4867
      X32.1041 Y60.9515
      X42.2868 Y63.5
      X32.1041 Y66.0485
      X28.905 Y66.5133
      Y64.2018
      X26.905
      Y58.1751
      X32.4916 Y58.9868
      X43.6321 Y61.775
      X48.4562 Y63.5
      X43.6321 Y65.225
      X32.4916 Y68.0132
      X26.905 Y68.8249
      Y64.2018
      X24.905
      Y55.8634
      X32.8792 Y57.0221
      X44.213 Y59.8587
      X54.3963 Y63.5
      X44.213 Y67.1413
      X32.8792 Y69.9779
      X24.905 Y71.1366
      Y64.2018
      X22.905
      Y53.5518
      X33.2668 Y55.0574
      X44.7939 Y57.9424
      X56.5244 Y62.1369
      X59.8883 Y63.5
      X56.5244 Y64.8631
      X44.7939 Y69.0576
      X33.2668 Y71.9426
      X22.905 Y73.4482
      Y64.2018
      X20.905
      Y51.3135
      X21.6554 Y51.3493
      X33.6543 Y53.0927
      X45.3747 Y56.0261
      X57.237 Y60.2677
      X65.2139 Y63.5
      X57.237 Y66.7323
      X45.3747 Y70.9739
      X33.6543 Y73.9073
      X21.6554 Y75.6507
      X20.905 Y75.6865
      Y64.2018
      X18.905
      Y49.216
      X21.8473 Y49.3561
      X34.0419 Y51.128
      X45.9556 Y54.1098
      X57.9495 Y58.3985
      X70.5338 Y63.4977
      X45.9556 Y72.8902
      X34.0419 Y75.872
      X21.8473 Y77.6439
      X18.905 Y77.784
      Y64.2018
      X16.905
      Y47.1185
      X22.0391 Y47.363
      X34.4295 Y49.1634
      X46.5365 Y52.1935
      X58.6621 Y56.5293
      X71.2849 Y61.6441
      G01 X76.3443 Y63.5
      X71.7764 Y65.1668
      X46.5365 Y74.8065
      X34.4295 Y77.8366
      X22.0391 Y79.637
      X16.905 Y79.8815
      Y64.2018
      X14.905
      Y45.021
      X22.2309 Y45.3699
      X34.817 Y47.1987
      X47.1174 Y50.2772
      X59.3746 Y54.66
      X72.036 Y59.7905
      G01 X82.179 Y63.5
      X72.4619 Y67.0456
      G01 X59.3746 Y72.34
      X47.1174 Y76.7228
      X34.817 Y79.8013
      X22.2309 Y81.6301
      X14.905 Y81.979
      Y64.2018
      X12.905
      Y42.9234
      X22.4227 Y43.3767
      X35.2046 Y45.234
      X47.6983 Y48.3609
      X60.0872 Y52.7908
      X72.7871 Y57.9368
      G01 X88.411 Y63.5
      X87.0072 Y63.8986
      X47.6983 Y78.6391
      X35.2046 Y81.766
      X22.4227 Y83.6233
      X12.905 Y84.0766
      Y64.2018
      X10.905
      Y40.8259
      X22.6145 Y41.3836
      X35.5922 Y43.2693
      X48.2792 Y46.4446
      X60.7997 Y50.9216
      X73.5382 Y56.0832
      G01 X96.1189 Y63.5
      X94.8636 Y63.7676
      X48.2792 Y80.5554
      X35.5922 Y83.7307
      X22.6145 Y85.6164
      X10.905 Y86.1741
      Y64.2018
      X8.905
      Y38.75
      X9.3584
      X22.8063 Y39.3905
      X35.9797 Y41.3046
      X48.86 Y44.5283
      X61.5123 Y49.0524
      X74.2892 Y54.2296
      G01 X94.828 Y61.164
      G01 X107.651 Y63.5
      X102.6541 Y64.1726
      X48.86 Y82.4717
      X35.9797 Y85.6954
      X22.8063 Y87.6095
      X9.3584 Y88.25
      X8.905
      Y64.2018
      X6.905
      Y36.75
      X9.406
      X22.9981 Y37.3974
      X36.3673 Y39.3399
      X49.4409 Y42.612
      X62.2248 Y47.1831
      X75.0403 Y52.376
      G01 X95.3743 Y59.24
      G02 X117.475 R5.
      G03 Y64.85 R-1.35
      G02 X117.2398 R5.
      X49.4409 Y84.388
      X36.3673 Y87.6601
      X22.9981 Y89.6026
      X9.406 Y90.25
      X6.905
      Y64.2018
      G00 Z3.
      X30.905
      G01 Z-16.9333 F100
      G00
      G01 X28.905 F200
      Y60.4867
      X32.1041 Y60.9515
      X42.2868 Y63.5
      X32.1041 Y66.0485
      X28.905 Y66.5133
      Y64.2018
      X26.905
      Y58.1751
      X32.4916 Y58.9868
      X43.6321 Y61.775
      X48.4562 Y63.5
      X43.6321 Y65.225
      X32.4916 Y68.0132
      X26.905 Y68.8249
      Y64.2018
      X24.905
      Y55.8634
      X32.8792 Y57.0221
      X44.213 Y59.8587
      X54.3963 Y63.5
      X44.213 Y67.1413
      X32.8792 Y69.9779
      X24.905 Y71.1366
      Y64.2018
      X22.905
      Y53.5518
      X33.2668 Y55.0574
      X44.7939 Y57.9424
      X56.5244 Y62.1369
      X59.8883 Y63.5
      X56.5244 Y64.8631
      X44.7939 Y69.0576
      X33.2668 Y71.9426
      X22.905 Y73.4482
      Y64.2018
      X20.905
      Y51.3135
      X21.6554 Y51.3493
      X33.6543 Y53.0927
      X45.3747 Y56.0261
      X57.237 Y60.2677
      X65.2139 Y63.5
      X57.237 Y66.7323
      X45.3747 Y70.9739
      X33.6543 Y73.9073
      X21.6554 Y75.6507
      X20.905 Y75.6865
      Y64.2018
      X18.905
      Y49.216
      X21.8473 Y49.3561
      X34.0419 Y51.128
      X45.9556 Y54.1098
      X57.9495 Y58.3985
      X70.5338 Y63.4977
      X45.9556 Y72.8902
      X34.0419 Y75.872
      X21.8473 Y77.6439
      X18.905 Y77.784
      Y64.2018
      X16.905
      Y47.1185
      X22.0391 Y47.363
      X34.4295 Y49.1634
      X46.5365 Y52.1935
      X58.6621 Y56.5293
      X71.2849 Y61.6441
      G01 X76.3443 Y63.5
      X71.7764 Y65.1668
      X46.5365 Y74.8065
      X34.4295 Y77.8366
      X22.0391 Y79.637
      X16.905 Y79.8815
      Y64.2018
      X14.905
      Y45.021
      X22.2309 Y45.3699
      X34.817 Y47.1987
      X47.1174 Y50.2772
      X59.3746 Y54.66
      X72.036 Y59.7905
      G01 X82.179 Y63.5
      X72.4619 Y67.0456
      G01 X59.3746 Y72.34
      X47.1174 Y76.7228
      X34.817 Y79.8013
      X22.2309 Y81.6301
      X14.905 Y81.979
      Y64.2018
      X12.905
      Y42.9234
      X22.4227 Y43.3767
      X35.2046 Y45.234
      X47.6983 Y48.3609
      X60.0872 Y52.7908
      X72.7871 Y57.9368
      G01 X88.411 Y63.5
      X87.0072 Y63.8986
      X47.6983 Y78.6391
      X35.2046 Y81.766
      X22.4227 Y83.6233
      X12.905 Y84.0766
      Y64.2018
      X10.905
      Y40.8259
      X22.6145 Y41.3836
      X35.5922 Y43.2693
      X48.2792 Y46.4446
      X60.7997 Y50.9216
      X73.5382 Y56.0832
      G01 X96.1189 Y63.5
      X94.8636 Y63.7676
      X48.2792 Y80.5554
      X35.5922 Y83.7307
      X22.6145 Y85.6164
      X10.905 Y86.1741
      Y64.2018
      X8.905
      Y38.75
      X9.3584
      X22.8063 Y39.3905
      X35.9797 Y41.3046
      X48.86 Y44.5283
      X61.5123 Y49.0524
      X74.2892 Y54.2296
      G01 X94.828 Y61.164
      G01 X107.651 Y63.5
      X102.6541 Y64.1726
      X48.86 Y82.4717
      X35.9797 Y85.6954
      X22.8063 Y87.6095
      X9.3584 Y88.25
      X8.905
      Y64.2018
      X6.905
      Y36.75
      X9.406
      X22.9981 Y37.3974
      X36.3673 Y39.3399
      X49.4409 Y42.612
      X62.2248 Y47.1831
      X75.0403 Y52.376
      G01 X95.3743 Y59.24
      G02 X117.475 R5.
      G03 Y64.85 R-1.35
      G02 X117.2398 R5.
      X49.4409 Y84.388
      X36.3673 Y87.6601
      X22.9981 Y89.6026
      X9.406 Y90.25
      X6.905
      Y64.2018
      G00 Z3.
      X30.905
      G01 Z-19.7556 F100
      G00
      G01 X28.905 F200
      Y60.4867
      X32.1041 Y60.9515
      X42.2868 Y63.5
      X32.1041 Y66.0485
      X28.905 Y66.5133
      Y64.2018
      X26.905
      Y58.1751
      X32.4916 Y58.9868
      X43.6321 Y61.775
      X48.4562 Y63.5
      X43.6321 Y65.225
      X32.4916 Y68.0132
      X26.905 Y68.8249
      Y64.2018
      X24.905
      Y55.8634
      X32.8792 Y57.0221
      X44.213 Y59.8587
      X54.3963 Y63.5
      X44.213 Y67.1413
      X32.8792 Y69.9779
      X24.905 Y71.1366
      Y64.2018
      X22.905
      Y53.5518
      X33.2668 Y55.0574
      X44.7939 Y57.9424
      X56.5244 Y62.1369
      X59.8883 Y63.5
      X56.5244 Y64.8631
      X44.7939 Y69.0576
      X33.2668 Y71.9426
      X22.905 Y73.4482
      Y64.2018
      X20.905
      Y51.3135
      X21.6554 Y51.3493
      X33.6543 Y53.0927
      X45.3747 Y56.0261
      X57.237 Y60.2677
      X65.2139 Y63.5
      X57.237 Y66.7323
      X45.3747 Y70.9739
      X33.6543 Y73.9073
      X21.6554 Y75.6507
      X20.905 Y75.6865
      Y64.2018
      X18.905
      Y49.216
      X21.8473 Y49.3561
      X34.0419 Y51.128
      X45.9556 Y54.1098
      X57.9495 Y58.3985
      X70.5338 Y63.4977
      X45.9556 Y72.8902
      X34.0419 Y75.872
      X21.8473 Y77.6439
      X18.905 Y77.784
      Y64.2018
      X16.905
      Y47.1185
      X22.0391 Y47.363
      X34.4295 Y49.1634
      X46.5365 Y52.1935
      X58.6621 Y56.5293
      X71.2849 Y61.6441
      G01 X76.3443 Y63.5
      X71.7764 Y65.1668
      X46.5365 Y74.8065
      X34.4295 Y77.8366
      X22.0391 Y79.637
      X16.905 Y79.8815
      Y64.2018
      X14.905
      Y45.021
      X22.2309 Y45.3699
      X34.817 Y47.1987
      X47.1174 Y50.2772
      X59.3746 Y54.66
      X72.036 Y59.7905
      G01 X82.179 Y63.5
      X72.4619 Y67.0456
      G01 X59.3746 Y72.34
      X47.1174 Y76.7228
      X34.817 Y79.8013
      X22.2309 Y81.6301
      X14.905 Y81.979
      Y64.2018
      X12.905
      Y42.9234
      X22.4227 Y43.3767
      X35.2046 Y45.234
      X47.6983 Y48.3609
      X60.0872 Y52.7908
      X72.7871 Y57.9368
      G01 X88.411 Y63.5
      X87.0072 Y63.8986
      X47.6983 Y78.6391
      X35.2046 Y81.766
      X22.4227 Y83.6233
      X12.905 Y84.0766
      Y64.2018
      X10.905
      Y40.8259
      X22.6145 Y41.3836
      X35.5922 Y43.2693
      X48.2792 Y46.4446
      X60.7997 Y50.9216
      X73.5382 Y56.0832
      G01 X96.1189 Y63.5
      X94.8636 Y63.7676
      X48.2792 Y80.5554
      X35.5922 Y83.7307
      X22.6145 Y85.6164
      X10.905 Y86.1741
      Y64.2018
      X8.905
      Y38.75
      X9.3584
      X22.8063 Y39.3905
      X35.9797 Y41.3046
      X48.86 Y44.5283
      X61.5123 Y49.0524
      X74.2892 Y54.2296
      G01 X94.828 Y61.164
      G01 X107.651 Y63.5
      X102.6541 Y64.1726
      X48.86 Y82.4717
      X35.9797 Y85.6954
      X22.8063 Y87.6095
      X9.3584 Y88.25
      X8.905
      Y64.2018
      X6.905
      Y36.75
      X9.406
      X22.9981 Y37.3974
      X36.3673 Y39.3399
      X49.4409 Y42.612
      X62.2248 Y47.1831
      X75.0403 Y52.376
      G01 X95.3743 Y59.24
      G02 X117.475 R5.
      G03 Y64.85 R-1.35
      G02 X117.2398 R5.
      X49.4409 Y84.388
      X36.3673 Y87.6601
      X22.9981 Y89.6026
      X9.406 Y90.25
      X6.905
      Y64.2018
      G00 Z3.
      X30.905
      G01 Z-22.5778 F100
      G00
      G01 X28.905 F200
      Y60.4867
      X32.1041 Y60.9515
      X42.2868 Y63.5
      X32.1041 Y66.0485
      X28.905 Y66.5133
      Y64.2018
      X26.905
      Y58.1751
      X32.4916 Y58.9868
      X43.6321 Y61.775
      X48.4562 Y63.5
      X43.6321 Y65.225
      X32.4916 Y68.0132
      X26.905 Y68.8249
      Y64.2018
      X24.905
      Y55.8634
      X32.8792 Y57.0221
      X44.213 Y59.8587
      X54.3963 Y63.5
      X44.213 Y67.1413
      X32.8792 Y69.9779
      X24.905 Y71.1366
      Y64.2018
      X22.905
      Y53.5518
      X33.2668 Y55.0574
      X44.7939 Y57.9424
      X56.5244 Y62.1369
      X59.8883 Y63.5
      X56.5244 Y64.8631
      X44.7939 Y69.0576
      X33.2668 Y71.9426
      X22.905 Y73.4482
      Y64.2018
      X20.905
      Y51.3135
      X21.6554 Y51.3493
      X33.6543 Y53.0927
      X45.3747 Y56.0261
      X57.237 Y60.2677
      X65.2139 Y63.5
      X57.237 Y66.7323
      X45.3747 Y70.9739
      X33.6543 Y73.9073
      X21.6554 Y75.6507
      X20.905 Y75.6865
      Y64.2018
      X18.905
      Y49.216
      X21.8473 Y49.3561
      X34.0419 Y51.128
      X45.9556 Y54.1098
      X57.9495 Y58.3985
      X70.5338 Y63.4977
      X45.9556 Y72.8902
      X34.0419 Y75.872
      X21.8473 Y77.6439
      X18.905 Y77.784
      Y64.2018
      X16.905
      Y47.1185
      X22.0391 Y47.363
      X34.4295 Y49.1634
      X46.5365 Y52.1935
      X58.6621 Y56.5293
      X71.2849 Y61.6441
      G01 X76.3443 Y63.5
      X71.7764 Y65.1668
      X46.5365 Y74.8065
      X34.4295 Y77.8366
      X22.0391 Y79.637
      X16.905 Y79.8815
      Y64.2018
      X14.905
      Y45.021
      X22.2309 Y45.3699
      X34.817 Y47.1987
      X47.1174 Y50.2772
      X59.3746 Y54.66
      X72.036 Y59.7905
      G01 X82.179 Y63.5
      X72.4619 Y67.0456
      G01 X59.3746 Y72.34
      X47.1174 Y76.7228
      X34.817 Y79.8013
      X22.2309 Y81.6301
      X14.905 Y81.979
      Y64.2018
      X12.905
      Y42.9234
      X22.4227 Y43.3767
      X35.2046 Y45.234
      X47.6983 Y48.3609
      X60.0872 Y52.7908
      X72.7871 Y57.9368
      G01 X88.411 Y63.5
      X87.0072 Y63.8986
      X47.6983 Y78.6391
      X35.2046 Y81.766
      X22.4227 Y83.6233
      X12.905 Y84.0766
      Y64.2018
      X10.905
      Y40.8259
      X22.6145 Y41.3836
      X35.5922 Y43.2693
      X48.2792 Y46.4446
      X60.7997 Y50.9216
      X73.5382 Y56.0832
      G01 X96.1189 Y63.5
      X94.8636 Y63.7676
      X48.2792 Y80.5554
      X35.5922 Y83.7307
      X22.6145 Y85.6164
      X10.905 Y86.1741
      Y64.2018
      X8.905
      Y38.75
      X9.3584
      X22.8063 Y39.3905
      X35.9797 Y41.3046
      X48.86 Y44.5283
      X61.5123 Y49.0524
      X74.2892 Y54.2296
      G01 X94.828 Y61.164
      G01 X107.651 Y63.5
      X102.6541 Y64.1726
      X48.86 Y82.4717
      X35.9797 Y85.6954
      X22.8063 Y87.6095
      X9.3584 Y88.25
      X8.905
      Y64.2018
      X6.905
      Y36.75
      X9.406
      X22.9981 Y37.3974
      X36.3673 Y39.3399
      X49.4409 Y42.612
      X62.2248 Y47.1831
      X75.0403 Y52.376
      G01 X95.3743 Y59.24
      G02 X117.475 R5.
      G03 Y64.85 R-1.35
      G02 X117.2398 R5.
      X49.4409 Y84.388
      X36.3673 Y87.6601
      X22.9981 Y89.6026
      X9.406 Y90.25
      X6.905
      Y64.2018
      G00 Z3.
      X30.905
      G01 Z-25.4 F100
      G00
      G01 X28.905 F200
      Y60.4867
      X32.1041 Y60.9515
      X42.2868 Y63.5
      X32.1041 Y66.0485
      X28.905 Y66.5133
      Y64.2018
      X26.905
      Y58.1751
      X32.4916 Y58.9868
      X43.6321 Y61.775
      X48.4562 Y63.5
      X43.6321 Y65.225
      X32.4916 Y68.0132
      X26.905 Y68.8249
      Y64.2018
      X24.905
      Y55.8634
      X32.8792 Y57.0221
      X44.213 Y59.8587
      X54.3963 Y63.5
      X44.213 Y67.1413
      X32.8792 Y69.9779
      X24.905 Y71.1366
      Y64.2018
      X22.905
      Y53.5518
      X33.2668 Y55.0574
      X44.7939 Y57.9424
      X56.5244 Y62.1369
      X59.8883 Y63.5
      X56.5244 Y64.8631
      X44.7939 Y69.0576
      X33.2668 Y71.9426
      X22.905 Y73.4482
      Y64.2018
      X20.905
      Y51.3135
      X21.6554 Y51.3493
      X33.6543 Y53.0927
      X45.3747 Y56.0261
      X57.237 Y60.2677
      X65.2139 Y63.5
      X57.237 Y66.7323
      X45.3747 Y70.9739
      X33.6543 Y73.9073
      X21.6554 Y75.6507
      X20.905 Y75.6865
      Y64.2018
      X18.905
      Y49.216
      X21.8473 Y49.3561
      X34.0419 Y51.128
      X45.9556 Y54.1098
      X57.9495 Y58.3985
      X70.5338 Y63.4977
      X45.9556 Y72.8902
      X34.0419 Y75.872
      X21.8473 Y77.6439
      X18.905 Y77.784
      Y64.2018
      X16.905
      Y47.1185
      X22.0391 Y47.363
      X34.4295 Y49.1634
      X46.5365 Y52.1935
      X58.6621 Y56.5293
      X71.2849 Y61.6441
      G01 X76.3443 Y63.5
      X71.7764 Y65.1668
      X46.5365 Y74.8065
      X34.4295 Y77.8366
      X22.0391 Y79.637
      X16.905 Y79.8815
      Y64.2018
      X14.905
      Y45.021
      X22.2309 Y45.3699
      X34.817 Y47.1987
      X47.1174 Y50.2772
      X59.3746 Y54.66
      X72.036 Y59.7905
      G01 X82.179 Y63.5
      X72.4619 Y67.0456
      G01 X59.3746 Y72.34
      X47.1174 Y76.7228
      X34.817 Y79.8013
      X22.2309 Y81.6301
      X14.905 Y81.979
      Y64.2018
      X12.905
      Y42.9234
      X22.4227 Y43.3767
      X35.2046 Y45.234
      X47.6983 Y48.3609
      X60.0872 Y52.7908
      X72.7871 Y57.9368
      G01 X88.411 Y63.5
      X87.0072 Y63.8986
      X47.6983 Y78.6391
      X35.2046 Y81.766
      X22.4227 Y83.6233
      X12.905 Y84.0766
      Y64.2018
      X10.905
      Y40.8259
      X22.6145 Y41.3836
      X35.5922 Y43.2693
      X48.2792 Y46.4446
      X60.7997 Y50.9216
      X73.5382 Y56.0832
      G01 X96.1189 Y63.5
      X94.8636 Y63.7676
      X48.2792 Y80.5554
      X35.5922 Y83.7307
      X22.6145 Y85.6164
      X10.905 Y86.1741
      Y64.2018
      X8.905
      Y38.75
      X9.3584
      X22.8063 Y39.3905
      X35.9797 Y41.3046
      X48.86 Y44.5283
      X61.5123 Y49.0524
      X74.2892 Y54.2296
      G01 X94.828 Y61.164
      G01 X107.651 Y63.5
      X102.6541 Y64.1726
      X48.86 Y82.4717
      X35.9797 Y85.6954
      X22.8063 Y87.6095
      X9.3584 Y88.25
      X8.905
      Y64.2018
      X6.905
      Y36.75
      X9.406
      X22.9981 Y37.3974
      X36.3673 Y39.3399
      X49.4409 Y42.612
      X62.2248 Y47.1831
      X75.0403 Y52.376
      G01 X95.3743 Y59.24
      G02 X117.475 R5.
      G03 Y64.85 R-1.35
      G02 X117.2398 R5.
      X49.4409 Y84.388
      X36.3673 Y87.6601
      X22.9981 Y89.6026
      X9.406 Y90.25
      X6.905
      Y64.2018
      G00 Z3.
    I like pockets
    Keith
  1. Please help me with this piece
    By serandre in forum Mastercam
    Last Post: 08-03-2009, 07:01 PM
  2. What process for this piece?
    By fer_mayrl in forum Bending, Forging, Extrusion...
    Last Post: 03-29-2009, 07:59 PM
  3. Advice on how to do this piece
    By Swami in forum Uncategorised MetalWorking Machines
    Last Post: 10-20-2004, 05:37 PM
  4. a waterblock, a piece of art.. what do you think
    By Ferenczyg in forum Computers / Desktops / Networking
    Last Post: 04-24-2004, 06:30 PM
