Well I better bring this thread back to life as I'm going to be doing a few upgrades on the g0704 this winter.
1) AC Bearing upgrade
2) Motor upgrade
3) 4th axis
1) Bearing Upgrade
I am a little worried about the fitment of the bearings after reading mhackneys thread and watching a video from diyengineer on youtube. I hope I don't run into any major issues that require excessive sanding or machining of the shaft. I am planning to go with the VXB bearings listed on Hoss's site here G0704 Belt Drive . One thing to note is that vxb has raised the price on these bearings significantly since Hoss posted them. By no means a deal breaker more an observation
VXB.com
7007B Bearing 35x62x14 Angular Contact - lower bearing - $12.95 (now $16.88)
9500 rpm limit with grease, 3934 lb. dynamic load, .0004 runout - ABEC1
7005B Bearing 25x47x12 Angular Contact - upper bearing - $9.95(now $12.95)
13,000 rpm limit with grease, 2540 lb. dynamic load, .0004 runout - ABEC1
update: Leaning towards the higher RPM bearings form bearing direct
7007C Precision 15 Degree Angular Ball Bearing 35x62x14 ABEC1 NSK
7005C Precision 15 Degree Angular Ball Bearing 25x47x12 ABEC1
I'm not sure if there is a case of certain bearing brands fitting the shaft better on the g0704 but if there is I'd like to go with those.
I'm going to "Use a 35x45x4mm shim that would go on the spindle first below the lower bearing" for the shims. Unfortunately McMaster doesn't ship to Canada so I can't buy the part# 98055A346 1mm shims. I've called around and had very little luck trying to find some locally.
2)Motor Upgrade
I ordered the "G0704 belt drive prints" from Hoss and I'll study them and try and come up with a plan. There are so many options here...in fact too many for me I'll have a hard time deciding. I don't know enough about it yet but I do think I will want to try to keep Full Quill operation. I don't know what that will entail yet.
3)4th axis
I've got a couple of ideas here ranging from buying one off ebay to making one out of a rotary table. I've got the parts coming to add the 4th axis to my controller and it will be a very simple thing to do as I built it with the intention of adding it.
Anyhow so much reading to do...
