First of all, I am new here, so HI to everyone
I found this site a week ago and I've just started building my JGRO router.
As I am Dutch and use the metric system I do have to adjust the plans a little and recalculate a lot of stuff.
So far things are coming along fine, I do have a couple of questions though:
- I've been reading about 'backlash' in leadscrews, what does this mean? I don't know the word. Hence I can't figure out what the anti-backlash nut thing in the plans is supposed to do. Can someone please explain the concept?
- The stocklist shows what type of nuts and bolts I need, but since everything is different here in the Netherlands, I need some help translating the specs.
EXAMPLE: HEX HEAD BOLT 1/4-20 x 3.
I figure this means a bolt with a 6 sided head. 1/4 means the diameter of the bolt is 0.25 inch, and the x3 means its 3 inches long. Is this correct? And what does the -20 mean?
Thanks in advance,
Ill try to take some pictures of the build asap
