Hi again
Door painted and installed. Took some tweaking to get the door to slide in and out without scraping anything. Not the cleverest design Ive made, but it will do. Still need to add a handle.
From KX3
From KX3
Spray test. Full flow at a 12mm end mill. Turns out that the coolant the goes beneath the bellow cover runs right out the back. More silicone and some small plates will do the trick i hope.
From KX3
