603,975 active members*
3,510 visitors online*
Page 5 of 5 345
Results 81 to 87 of 87
  1. #81
    Feb 2004
    813
    I'm already planning a bigger more complex lathe for after the Big Mill project
    Maybe a turret with powered rotation might be just possible
    BTW, nice mill project you have going
  2. #82
    Oct 2003
    927
    I'm THOROUGHLY enjoying your pictorial here, Stevie!
    wunnerful!
  3. #83
    Jan 2004
    353
    Stevie: Thanks !
    Of course the turret would be powered !!
  4. #84
    Apr 2003
    1873
    Yeah guys,
    Stevie may be resourceful, talented, experienced, visionary and methodical but can he chew gum, pat his head and rub his stomach all at the same time?
  5. #85
    Feb 2004
    813
    Vertical update
    Got a chance to go into the shop again
    I made the 2 support blocks for the vertical axis ballscrew
    Here is the rough assembly; you can see the flex coupler sticking out of the upper block; there still need a small lock nut to be turned for the shaft/brg setup; the tiny 3/8"x5/8"x1/8" brg is for the lower block (still need to bore that; just roughed out)
    The 370mm slide is facing down; the ballscrew will be on the back (out of the cuttings)
    The spindle you can see fits into the cast iron sleeve; this is from the 8" cheap drill press; I'll bore it for the collet you can see in the pic (if anyone can identify this collet series let me know)
    Here is the assembly dissassembled; the lower is cleared for the lowest ballnut ball return tube to enter into the block; the upper is bored for the outer brg retainer; the brgs will be preloaded by 0.001; the retainer will be held by 4 4-40 capheads countersunk into the outer ring of the retainer; inner bore of the retainer will just clear the ball return tube of the upper ballnut
    Both blocks will be drill and tapped to mount to the back of the slide; and will then be drilled and tapped to mount the assembly to the bridge from the headstock/tailstock of the Lathe
    The sliding mass will be counterbalanced with a weight supended from a small cable
    Travel will be on the order of 7 - 7 1/4" max cutter 1/4" 4 speeds planned in the 3,000-26,000 range (got a 13,000 rpm motor 1/4hp)
  6. #86
    Feb 2004
    813
    Made the retainer/locking sleeve today with the lathe
    It's a 2 piece; the outer ring is held by 4 x 2-56 cap heads; the ring is 7mm thick; the sleeve is .5mm longer than the bore; hence the outer brg race is held firmly; the inner brg race will be spaced by a 0.001" spacer to preload the brgs
    The lower block I also worked on and other than the mounting bolt holes it's done
    Still need the upper blocks stepper mount and the small 10mm fine thread lock nut to lock the ballscrew shaft to the brg setup
    All this should provide for a nice free running assembly with zero backlash
    The ballscrew is 3/8" dia with a lead of 3/16"/rev
  7. #87
    Feb 2004
    813
    The lock nut to hold the brgs on the ballscrew
    Yeah I know Bronze again; I just love this stuff; and the stepper mount below it is also partly bronze
Page 5 of 5 345
  1. Using your CNC Mill as a CNC Lathe
    By lstool in forum Knee Vertical Mills
    Last Post: 06-12-2017, 02:29 PM
  2. Manual lathe CNC conversion
    By kong in forum Uncategorised MetalWorking Machines
    Last Post: 08-20-2005, 09:56 PM
  3. Pictures of My Lathe & CNC MILL
    By studysession in forum Uncategorised MetalWorking Machines
    Last Post: 01-04-2005, 11:07 PM
  4. The start of a big CNC project...
    By UKRobotics in forum Uncategorised MetalWorking Machines
    Last Post: 09-30-2004, 11:34 PM
  5. Taig lathe Threading and CNC questions
    By anoel in forum Mini Lathe
    Last Post: 01-12-2004, 10:43 PM
