Machining wax, while not machine intensive you need to make sure that for jewelry, you have good resolution.
For a long time now my 4th axis has just been a stepper motor with an arbor on it. It worked, but was not very rigid. And getting things setup was a pain in the rump.
As I am more of a DIYer I didn't want to drop the $300+ for a sherline rotary table. Mainly because I dont have the $$$ to spend. So I picked up a cheap Chinese manual rotatory table. Studied it and found that the run out was really high. Took the sucker apart and found that the only vertical support was the small shaft that the face plate is part of. Towards the rear of the table, this shaft fits into a thin bearing and is pulled tight into place by a short bolt. There is NO internal front face support what so ever! Using the big manual lathe as the shop I made a step and a brass bushing. The brass bushing press fits around the inside of the face. The step was turned into the baseplate and everything fits night and tight now. It still spins free and has frontal support.
The handle on the rotary was pulled off and again with some lathe and mill work I made a stepper motor adapter. Its long and looks a little odd but it works great! I now have higher resolution on my 4th axis for machining rings. Now I just need a way to hold my wax for machining.
Well, I solved that problem as well. Using the manual lathe again, I made a adapter that bolts to the face of the new rotary table. There is a .998 bore in the center to receive different types of fixtures for the mill. I wanted to make something that was a universal fit. Undo a set screw and pull the fixture out of the receiver, and slide a different fixture in. Tighten set screw.
I am very very happy with the way these came out. Very smooth fit. And after spending about 3 hours getting the new table indicated in and the receiver plate zeroed onto the rotary I have only .005 in run out at the very end of the ring arbor. VERY VERY PLEASED!!!
Here are some pics of the whole ordeal.
