587,370 active members*
3,623 visitors online*
Page 1 of 2 12
Results 1 to 20 of 33
    Mar 2003
    6855
    My mill CNC converstion
    I started my Mill to CNC converstion. Here is a pic of the parts
    Mar 2003
    52
    Why not go with direct drive, and turn you some flexable disk couplings ?
    Mar 2003
    6855
    Because of the motor being in the way.
    Mar 2003
    6855
    Is that how you did it?
    Mar 2003
    52
    Yeah, I mounted them on roughly 2-1/2"x 0.50" Al standoffs, to accomodate the couplings, directly to the saddle and table.
    The z axis, I mounted off to the right of the column utilizing the same standoffs.
    I could have used some old motor mounts that came with some NSK ballscrew assemblies, but opted not to becuase they were too long, and I didnt want to cut them(might find a use for them in the future)
    I was just wondering why you decided to go with what looks like(cant really tell from the pic) to be a 4:3 ratio on 20 TPI leadscrews that come with the MIcromark mill?
    Seems it would be pretty slow using steppers, and you would get very low rapids with it(alot of torque though)
    If you run your motors at a higher voltage than specified, youll not lose much torque anyway.
    IMO a stepper system really has no need for a gear reduction.......this is best used for a servo system where you have >1000 RPM motors.
    Just my opinion though.
    And Im ,by no means, a pro at this stuff.............just an addicted hobbiest!
    Mar 2003
    6855
    I'm really want the torque, and I plan on using 10 tpi ballscrews. The pulley's are used to allow me to mount them off to the side of the bed. I was doing to go the direct route, but I did'nt want the NEMA 34 steppers in the way of the bed. I got the Idea from a website that converted the same machine as mine.
    Mar 2003
    6855
    Well I got my ball nuts and ball screw and will start maching them. I will post pics as I convert my machine to CNC. Stay tuned.
    Mar 2003
    271
    wHAT DOES SOMETHING LIKE THIS COST TO DO, RUFFLY? I have a homier mini mill and might do this in the future....
    My little piece of the web!
    http://users.adelphia.net/~wjdupont
    Mar 2003
    6855
    The ball and screws cost me 100.00.
    Hey I recognize some of those parts. Werent they made at a place called L.S. Tool ?
    L.S. Tool & Precision Inc.
    Taking machining to the
    next level, combining creativity, ingenuity and the technology of CAD/CAM & CNC Machining
    “When ingenuity makes all the difference”
    http://hometown.aol.com/lstool1/myhomepage/business.html
    Mar 2003
    6855
    Yes they were .
    Mar 2003
    6855
    Well I start to lathe my ballscrews and learned a thing or to about positive and negitive rake angles. I have to buy some cutter's to make my life easier. So once I get the right cutters I will see how well my 7x10 lathe cuts. Stay tuned!
    Mar 2003
    271
    Still like your 7x12? I stilll havent got one yet. I have access to a 9inch south bend lathe. But want something here at my home. Was looking at that or a 9x20. I like the idea the 7x12 are more easy to move around..
    Mar 2003
    6855
    I'd like to get the converstion the littlemachines has to make it a 14" lathe.
    Mar 2003
    6855
    My little lathe will not cut hardened steel, I will have to get machined on a bigger lathe. So i'm waiting to do that.
    Mar 2003
    6855
    Next week, I'm going to try to complete the machining to the screws and I have to make a addon to hold the thrust bearings. I will post pics of the rest of the converstion.
  17. #17
    May 2003
    325
    Lightbulb
    Time to look at mounting your Dremel on the tool post.
    Start at http:/mini-lathe.com/ for info
    robotic regards,
    Tom
  18. #18
    Mar 2003
    6855
    I have a question, do you guy thing I should use a belt drive to drive my screws or direct drive?
    The steppers I'm using have about 250 in oz of torque. I was going to belt drive it to get more torque out of the system. I plan on cutting steel and alum.
  19. #19
    Mar 2003
    6855
    Here is why I question myself-
    http://www.cnczone.com/links.php?s=&...link&linkid=54
    It would make my life easier to do it this way. HELP!
  20. #20
    Apr 2003
    80
    My plan is to belt drive, with a 2:1 ratio. But that is because I am going rack/pinion, and I need to gear down the servo a little. The smallest pinion is 1.7" per revolution (0.00425").
    After further research, it looks like the feature that I thought added accuracy actually divided it out. The G340 has a step multiplier, but that means it sends the equivalent of 2/5/10 pulses to the servo for each input step.
    I need the opposite, more resolution, not less. I guess I could find encoders with more counts.
    I know the Shop-bots do a 3.5:1 gear down on their steppers.
    Zeph
Page 1 of 2 12
  1. Using your CNC Mill as a CNC Lathe
    By lstool in forum Knee Vertical Mills
    Last Post: 06-12-2017, 02:29 PM
  2. Which CNC Mill and what software?
    By MaxxMan-X in forum Knee Vertical Mills
    Last Post: 12-31-2014, 04:27 AM
  3. Pictures of My Lathe & CNC MILL
    By studysession in forum Uncategorised MetalWorking Machines
    Last Post: 01-04-2005, 11:07 PM
  4. Need to CNC my mill quickly - advise?
    By SRT Mike in forum Uncategorised MetalWorking Machines
    Last Post: 03-15-2004, 07:10 PM
