Good idea, I'd need to make a variation that would keep it from wobbling around.
More pictures.. I'm pretty happy about the monitor mount with keyboakd tray that I scored almost free this week at an auction. It's perfect for my touchscreen and swings out of the way for storage.![]()
I got the rear belt guard welded up and almost have a Z-axis. More progress this weekend I hope..
The Z axis looks really tall in the picture but most cutting will be done low where it is more rigid. The extra tall part is for tool changes and clearance for parts up to 6".
@KevinCNC : What are those white fittings that you used on the monitor movement and support? They look strong but easily adapted ...
Cheers!
Paul Rowntree
Vectric Gadgets, WarpDriver, StandingWave and Topo available at PaulRowntree.weebly.com
Kevin,
Nice build!
What are the dimensions of the heated side of your workshop?
Thanks,
Paul
Hoffman: Product Catalog : HMI - Human-Machine Interface : CONCEPT? HMI Overview
Hoffman makes them, but I think they're pretty expensive new. I lucked out on mine.
I'm going to make some direct mounts for the spindle and wait on the ATC until I get everything running.
I finished the spindle mount plate last night. It and the tall one are both 5/8" thick tooling plate. I screwed up and counterbored the bearing block holes one size too big, but McMaster has washers that will fit in the c'bores so no big deal. The little bumpers are the lower stops.
OT: I love HSMXpress, it makes things so easy. The Adaptive Clearing (High Speed Machining) let me rough out the pockets at full depth in minutes. I left .010" for the finishing passes with regular pocketing, and this is probably the nicest, most accurate part I've ever made. When there are a lot of different hole sizes, I usually just spot drill and finish them on the drill press.
Thanks Louie. I made the motor mounts, and pocketed out the bore with HSM at full .775" depth with a 1/2" EM, .050" load at 20 IPM. I had no idea a Bridgeport clone could do that, especially with a 2" flute length EM. I you look at the right side of the first picture you can see some chips flying- in real life it was a flurry of chips like I've never seen coming off of my mill
The other pictures show the spindle temporarily mounted for test-fitting, and the z-axis motor mount plate. I'm starting to see the light at the end of the tunnel..
I noticed the CAM tab in Solidworks. Is that HSMXpress running in Solidworks, or what CAM program is that?
He said it's HSMExpress in the post with the images you're asking about.![]()
Gerry
UCCNC 2017 Screenset
Mach3 2010 Screenset
That seems to be their strategy CNC Lurker. They're counting on you falling in love with the 2-1/2 D so you buy the full version.
Z-Axis parts are touched-up and going out for anodizing tomorrow. There's more progress that I'll post when they are back and permanently mounted.
Thanks Louie, I'm getting close to the dreaded wiring..
I did find some nice high-flex VFD cable on ebay cheaper then any regular 14/4 shielded cable that could find. It's overkill and I had to leave out the compression bushing that came with the spindle connector. Luckily the extra-thick outer jacket went through the nut so a couple of o-rings worked to secure the cable.
The X and Z axes are done except for the X-motor mount, and Y-axis ballscrew mount plates are out for anodizing. Spindle coolant hoses will go through the cable track on the right side.
After installing my X-Axis bumpers I found that one side touched about 1/8" before the other. I knew I would have to clock the ballscrews relative to each other to fine tune the squareness but not by that much! My frame is very square so that wasn't the problem. Then I remembered that instead of ordering the precision cut ends on the gantry extrusion, I was going to clean them up on my mill just in case the precision cut wasn't good enough. Guess what I forgot to do..each end was at least .010 out of square.
So off came the gantry, and onto the mill for a cleanup cut on each end. I was wondering what I would use the giant cutter for when I got it..
Well it's back together with the Y-Axis ballscrew tied in, and the spindle cooling circuit is started. I need to drill & tap the visual flow meter (sorry, hard to see) to attach it, and mount the temperature display in a little box on the left side. I also re-mounted the Z cable tracks to allow for a larger bend radius, and added a shaft extension to Z-ballscrew for a brake. It barely stays up, so the brake may save a part from getting gouged if something faults during cutting. And yes that is a blizzard outside in Arizona.
