588,611 active members*
7,435 visitors online*
Page 1 of 2 12
Results 1 to 20 of 21
    Feb 2010
    202
    Cool My second big 5 axis
    Hello.A long time I was not here. I got an interesting job to do. This 5 axis. Another company did not build the machine, I received several parts to build it.
    I have a planed beam and several supports. I drew a new project and started to build the machine.
    The assumptions:
    working area x3m, y8m, z2m, head BC, c 350, B +- 120,
    Drive with servomotors Delta B2, head with harmonic gear's, xyz planetary gear's. Axis X and Z ballscrew. Y tothed rack's.
    A few photos
    Attachment 396950
    Attachment 396952
    Attachment 396954
    Attachment 396956
    Attachment 396958
    Jan 2008
    1543
    Re: My second big 5 axis
    Good to see you back Bartuss.
    I like the cnc cut plate weldment
    Feb 2010
    202
    today I welded one side, tomorrow the other, and then all angles will be set
    Feb 2010
    202
    All angles are, diagonals also after welding side's. I started to paint it
    Attachment 397132
    Attachment 397134
    Attachment 397136
    Feb 2010
    202
    Today I drew the Z axis. The drawing went to the laser.
    Feb 2010
    202
    I welding the Z axis. I bought a harmonic gear for axis C to head.
    Attachment 397502
    Attachment 397504
    Attachment 397506
    Feb 2010
    202
    I have a guides Hiwin 30. Actually I turning shaft's for drive Y axis.
Name:	Y axis shaft.jpg
    e97 Guest
    This is amazing! Whats the cost range of a build like this and capabilities?
    Whats this: "head BC, c 350, B +- 120,"
    I'm trying to build a 5-axis laser + cnc capable of working with 1/8" aluminum (cutting and welding) wiht work area of x1m x y1m 0.5mz + 360x' + 360 y'
    Looking forward to your build and learning a lot. Apologies if they are newbie questions, kindly point me to the relevant sticky or forum area.
    Mar 2013
    88
    Wow! Excellent!
    Sent from my iPhone using Tapatalk Pro
    Feb 2010
    202
    Head BC have an angle axes for spindle position, C axis 350 deg around Z axis, B axis +- 120deg around Y axis.
    My previous 5 axis machine :
    https://www.youtube.com/watch?v=pg2Fd9wUpmQ
    Cost about 60 th dollars
    Mar 2013
    88
    What do you make with the machines?
    Feb 2010
    202
    I make this to order
    Feb 2010
    202
    X axis steel plate is mounting after milling.
Name:	plate of x axis1.jpg
Name:	plat of x axis2.jpg
    Feb 2010
    202
    Tomorrow I'll be milling the Z axis
Name:	z axis in table.jpg
    Feb 2010
    202
    The drive shaft of the Y axis in place
    Attachment 399308
    Attachment 399310
    Attachment 399312
    Feb 2010
    202
  17. #17
    Feb 2010
    202
    The Z axis with counterbalance and harmonic gear with bearing in out
    Attachment 399614
Name:	z axis2.jpg
  18. #18
    May 2015
    34
    Excellent work, thank you for posting. We can learn a lot from you!
  19. #19
    Feb 2010
    202
    Thank's for watching haha
    I have a long ballscrew. 4m 2520. Previous company wanted to drive the ballscrew. At this length there would be large vibrations. So I decided to do a driven ballnut and ballscrew to stretch the string.
    Attachment 399752
Name:	drive x 2.jpg
Name:	drive x 3.jpg
  20. #20
    Great work here! Thank you sharing. What kind of CNC board you are using to control 5 delta B2 motors / 5 axis ?
Page 1 of 2 12
  1. Replies: 16
    Last Post: 09-11-2017, 10:31 PM
  2. Replies: 0
    Last Post: 04-27-2016, 04:08 PM
  3. Replies: 1
    Last Post: 11-17-2015, 07:37 PM
  4. Replies: 0
    Last Post: 08-04-2013, 05:30 AM
  5. 5-axis, 4-axis, and 3-axis CNC Router manufacturer
    By roctech in forum Roctech CNC Routers
    Last Post: 05-24-2012, 09:12 AM
