![Quote](images/misc/quote_icon.png)
Originally Posted by
tahustvedt
I made a hinged support for the long X ball screw from 10 mm acetal. I also made a bush to support the screw where it exits the gantry beam on the opposite end of the nut. I could have used another ball nut, which would give even better support, but this'll do. I can run 8000 mm/min now without whipping causing problems. It's whipping slightly in the exteme ends, but not badly. Without the supports it would only reach 6000 mm/min. Still, I'm running a max of 6700 mm/min to keep the kernel speed low. 6700 is pretty fast, and a great improvement over 5500, which is what I ran before. I'm a big fan of acetal. It's so easy to work with, and prototyping stuff takes minutes, even with tiny tools.
