588,385 active members*
5,269 visitors online*
Results 1 to 6 of 6
    Oct 2003
    208
    My Second Machine Design
    Hi.
    I just completed my second machine design after countless revisions.
    it will be made from 1" square tubing for the frame and 3/4" mdf for the rest.
    the cut area is about 19" x 30" x 3"
    here are some drawings that you all can look at and give me some feedback before i start building.
    Attached Files Attached Files
    May 2005
    101
    I like the improvement on the X-Axis, It looks to be Angle iron backing up the flex of the pipe?
    Feb 2005
    578
    Hard for me to tell. Is it square channel (or angle or plate) backing the X up? Why not do it for the Y also?
    I think I see square channel supporting the X end plates, not a bad idea but this is not where you need to worry about flex.
    Steve
    Oct 2003
    208
    Here is a drawing of the x axis support rail.
    Oct 2003
    208
    and here is a drawing of the y axis rail support assembly
    Jun 2003
    3312
    I made a pdf of the full view for those who can't see a dxf file:
    Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
    Vist my websites - http://pminmo.com & http://millpcbs.com
