Hi all,
I am playing around with Mastercam trying to mill a part with Delrin. So I simulated the milling process. But I am having problem with the cutter cutting into the side wall as can be seen in the picture below.
As you can see in the pictures, the circled area showing where the wall of the part was over cut at the sloping face. The wall thickness should be 3mm. But the cutter toolpath was right at the wall edge. How do I adjust so the toolpath is half the diameter away from the wall? I tried many ways but I just haven't got a clue how to fix this. Anyone can help? Thanks.
