587,916 active members*
3,786 visitors online*
Results 1 to 4 of 4
    Sep 2017
    20
    my spindle is too low..
    Hi guys,
    I'm getting ready to test a new (old) router, but the spindle is too low - with a 6mm x 30mm (ish) end mill in the Z height probe won't reach the workpiece.
    Is there any problem backing off the spindle mounting bracket and raising the spindle up 30mm or so?
    pretty sure I can re-calibrate the tool height measuring setup, but will I have to get a new distance ring for the spindle holder / clamp?
    The machine was designed for chamfering steel plates with sub 3mm short bits - was never setup for general cnc milling / routing
    Cheers
    Simon
    Feb 2007
    4553
    Re: my spindle is too low..
    Simon,
    In the image you posted it appears as if the tip of your Z height probe has a knurled collet that allows adjustment of the tip.
    If the tip is not long enough to extend and reach the workpiece or table why not just replace it with a longer section of drill rod?
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Sep 2017
    20
    Quote Originally Posted by jalessi View Post
    Simon,
    Jeff...
    Hi mate,
    just tried it - no good, it's a screw in tip , same as a dial indicator.
    Feb 2007
    4553
    Simon,
    Five minutes to cut and thread a small piece of drill rod or just purchase the correct length screw from the hardware store may be what the doctor ordered.
    Have a most awesome afternoon!
    Jeff...
  1. Replies: 3
    Last Post: 10-19-2018, 05:12 PM
  2. Replies: 35
    Last Post: 03-21-2017, 02:29 PM
  3. Replies: 39
    Last Post: 01-09-2017, 06:26 AM
  4. Replies: 5
    Last Post: 07-19-2013, 05:16 AM
  5. mach3 spindle dro not working, spindle speed changing while jogging and running code
    By jasminder in forum Mach Software (ArtSoft software)
    Last Post: 02-23-2011, 07:12 AM
