Hello Everyone,
Just thought I would post a few pictures of the enclosure that I am building. It is constructed of 2 separate frames. 1 upper and 1 lower. Both are made of aluminum. The lower is made of aluminum tubing and is tig welded at the joints. It is covered on the front and sides by aluminum diamond deck. The bottom and back sheets of aluminum are plain.
The upper is made from aluminum architectural angle and is also welded at the joints.
The sheets of aluminum attached to the bottom frame rise above the frame to allow the top to set just inside, stopping any chips from escaping and also allowing for easy dis-assembly which was a good thing since I live in an apartment and needed to be able to get this thing through the door!
The lower frame is lined with vibration absorbing material so that none is present when the top is installed.
There are a total of 14 lexan sheets which are held in place by screws.
I will be hanging the lifting struts for the door and the door it's self this weekend.
As soon as the last piece of Lexan comes, I will be adding exhaust fan mounting holes and run dryer venting to the exhaust fan.
The light that you see will be replaced with a "machine light".
I also plan at some point in the future, to add a coolant system.
And then a finally,a coating of cobalt blue paint for the upper frame.
While there are a few things that I would change if I had to build this thing again, Overall I am pretty happy with the out come.
Thanks for looking and any comments or suggestions that any might have to offer!
Matt
P.S. Will post more pics when it is complete.
Just the upper frame with no lexan attached sitting in the lower frame.
Upper frame set on the lower frame. I needed to use the mill before the lexan got here so the plastic provided a barrier to keep the chips from getting out!
Lexan partially hung just set the upper frame on the lower to see how it looked and fit....
Upper Frame with nearly all of the lexan hung
All the lexan hung accept for the top piece. The door still needs to be hung (along with the lifting struts!!
Just a different angle (hope to eventually switch to a smaller pc and monitor)
