587,419 active members*
3,309 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > Mysterious Problem-Grinding Sound
    May 2010
    5
    Im trying to work on a Milltronics RW12 VMC with Centurion 6 control and there is a nagging problem that Im not sure how to address.
    When the table travels in the X axis, only one direction, it makes a grinding/rumbling sound as it travels. Its enough to be heard throughout the shop and can be seen in the poor finish when that direction of the X axis is engaged in cutting.
    After many months of working with the machine I believe it can only be something in the servo/encoder/control. Perhaps its a parameter setting that Im unaware of. People have suggested bearings or ball screws but I absolutely cannot agree with them, it just doesn't sound like bearings/ball screws.
    When I switch between axes using handwheel I will sometimes get an additional .001" or so step in the axis Im switching from so I know something is wrong with what the machine is telling the servos to do.
    We all know what a machine sounds like when you are using handwheel and you have the increment set to .01" or greater. Sort of a knocking sound each time that step is taken. Well thats exactly what it sounds like in one direction on X the other direction is silent.
    A few months ago the CMOS battery died and many settings were lost. Im suspicious this problem started happening around this time which is good because it would indicate a setting needs changing.
    If anyone has any thoughts they'd be much appreciated.
    Jan 2005
    15362
    Wolfe88
    Can you do a video of the axes moving, we should be able to hear the noise it is making
    Mactec54
  1. LITTLE 'G' PROBLEM? Sound familiar
    By DomB in forum Haas Mills
    Last Post: 02-04-2015, 07:52 PM
  2. Still have mysterious circles....
    By rewster in forum CamBam
    Last Post: 12-07-2010, 04:31 PM
  3. Z axis is mysterious
    By lilimike in forum Mach Software (ArtSoft software)
    Last Post: 09-11-2010, 02:37 PM
  4. L297 l298 vibration sound problem
    By ez-cnc.com in forum Stepper Motors / Drives
    Last Post: 04-30-2006, 01:29 AM
  5. Rattling almost grinding sound with first tests of Y axis
    By phantomcow2 in forum CNC Machine Related Electronics
    Last Post: 10-09-2005, 01:44 PM
