588,380 active members*
5,165 visitors online*
Results 1 to 6 of 6
    May 2009
    29
    Exclamation NC HELP!! Num 750
    I'm 3/4 of the way through completing an extremely important job list and the controller has just started giving errors and beeping and flickering, showing random symbols at different sizes all over the screen. You name it.
    It started off as a dodgy connection to the PC, I was hoping it would be the PC instead of the NC because that would be a lot easier to fix. I have no idea where to start on this thing...
    Any recommendations on what to look at first?
    I think it may be an electrical component somewhere inside, or maybe even a battery? I'm not sure...
    Jan 2009
    32
    please if you can help me with that DNC program to use and what parameters that would conektovao PC to NUM 750 on a machine WEEKE 05 bp
    thank you greeting
    Aug 2013
    8
    Re: NC HELP!! Num 750
    Hi, did you have any luck getting your DNC (drip feed) to work? Maybe post it here.....
    https://www.facebook.com/SCMrecord2?ref=hl
    Jan 2009
    32
    I dismantled the NUM 750 and installed MACH3 and it now works
    https://www.youtube.com/channel/UCZ-...8V0RVqg/videos
    Jan 2009
    32
    Aug 2013
    8
    Wow, you did what??? I really need to know more, your link didn't seem to work. Was it easy?
    [email protected]
