587,877 active members*
4,303 visitors online*
Results 1 to 10 of 10
    Jan 2006
    4396
    Question NC Plot with Big Files
    NC Plot seems to choke on files that are over 60,000 Sequence Blocks. Then turns into a Non Responding Program.
    What can I do to prevent this?
    I have it set to change back plot colors with tool changes and Letter Addresses.
    If anything I'd like to keep the Back Plot Colors and get rid of the Letter Adderss Colors.
    BTW: The program it choked on was 183,434 Sequence Blocks, too big to post here.
    Any one have an Idea?
    Toby D.
    "Imagination and Memory are but one thing, but for divers considerations have divers names"
    Schwarzwald
    www.refractotech.com
    Mar 2003
    765
    Hi Toby,
    You can improve the load time on big programs by turning off the address coloring. This is the 'Colorize' option on the 'Edit' menu. When you load a large program, you can see loading progress in the status bar. First, you see a message that says "Formatting ... " and then it should begin to plot. One thing I've noticed, and I haven't figured out why or if I can do anything about it, is that there seems to be a long pause between the formatting and the plotting. If you wait though, it should begin to plot. One other option is to turn off the 'Plot file when loaded' option on the Preferences window. Then the file only plots when you refresh it manually.
    Thanks,
    Scott
    Jan 2006
    4396
    Thanks Scott,
    That worked perfectly.
    Here is one of the Files Posted in BCC V2007. It was one of the files I had a problem with.
    I still use NC Plot to edit G-Code created from V2007 even though I have the Predator Virtual CNC Level 3.
    NC Plot will always be on every PC I own. It Kicks Butt You can't Beat NC Plots Price for Lathe and Mill Back Plotting.
    Cheers!!!!!!
    Attached Files Attached Files
    Toby D.
    Schwarzwald
    Aug 2003
    20
    I just load this file into free tool (NC2DXF) I made. Worked pretty fine.
    Does Tool-4 toolpath I arrowed on picture is correct ???
    Resulting DXF is here
    Jan 2006
    4396
    Quote Originally Posted by anorec View Post
    I noticed those as well and informed BCC Tech Support. They should be getting back to me soon about this.
    I also noticed that the drilled holes and counter bores aren't in your back plot, Is there a reason for that or you didn't finish back plotting?
    Toby D.
    Schwarzwald
    Aug 2003
    20
    Hi!
    Yes on my capture I only showed Tool-4 toolpathes. Holes are there of course
    If you want to compare my backplot, you can import DXF file here in any CAM software.
    Jan 2006
    4396
    The Flat Areas where done Manually due to some issues that haven't been fixed in BCC V2007. It came out nice though.
    Nice back plotter, have you seen NC Plot? www.ncplot.com
    Toby D.
    Schwarzwald
    Aug 2003
    20
    Of course I know of NC plot. We are chatting on its dedicated forum
    I only tried it, it's amazing and it seems one of the best wire backplotter speaking of settings possibilities and features. But it's slow with big files to compare to Cimco edit for example...
    And I couldn't make it ouput a complete and nice DXF file as I do with my little tool
    Jan 2006
    4396
    Does your Cimco Edit Support Sub Programs, Macro Variables, Lathes and Full 4th Axis Machining?
    Toby D.
    Schwarzwald
    Aug 2003
    20
    Quote Originally Posted by tobyaxis View Post
    I am talking about last version 5.1x here:
    Subs: YES (Fanuc and Heidenhain)
    Macro: NO
    Variables: YES with Heidenhain
    Lathes: YES
    4th axis: YES (even 5th axis)
    Both are great softs and they have their strength.
    Cimco: editing/fast processing/good looking/tabbed windows/(basic) solid verify
    NC plot: Macro management/a lot of settings/entities database
  1. NC Plot v2 Beta 5
    By MetLHead in forum NCPlot G-Code editor / backplotter
    Last Post: 09-14-2008, 10:20 PM
  2. NC PLOT Question?
    By TURNER in forum NCPlot G-Code editor / backplotter
    Last Post: 09-13-2005, 10:15 PM
  3. NC Plot Discussion
    By jonbanquer in forum NCPlot G-Code editor / backplotter
    Last Post: 07-24-2005, 01:22 AM
  4. Batch plot?
    By cncadmin in forum Autodesk
    Last Post: 08-04-2004, 01:52 PM
  5. Batch Plot??
    Last Post: 07-16-2003, 05:02 PM
