587,999 active members*
4,526 visitors online*
Results 1 to 5 of 5
    Nov 2011
    9
    NC Studio Coding
    Hello,
    I purchased a Donek Drag Knife and I need to set in the NCstudio post processor that the spindle doesnt start.
    Here is the vectric aspire PP configuration file.
    Does anyone know where to look for?
    + NC Studio Vectric output configuration file
    + History
    + Who When What
    + Mark 07/09/2010 Written
    POST_NAME = "NC Studio ATC Arcs (mm)(*.nc)"
    FILE_EXTENSION = "nc"
    UNITS = "MM"
    + Line terminating characters
    LINE_ENDING = "[13][10]"
    + Block numbering
    LINE_NUMBER_START = 0
    LINE_NUMBER_INCREMENT = 10
    LINE_NUMBER_MAXIMUM = 999999
    + Formating for variables
    VAR LINE_NUMBER = [N|A|N|1.0]
    VAR SPINDLE_SPEED = [S|A|S|1.0]
    VAR FEED_RATE = [F|C|F|1.1]
    VAR X_POSITION = [X|C|X|1.3]
    VAR Y_POSITION = [Y|C|Y|1.3]
    VAR Z_POSITION = [Z|C|Z|1.3]
    VAR ARC_CENTRE_I_INC_POSITION = [I|A|I|1.3]
    VAR ARC_CENTRE_J_INC_POSITION = [J|A|J|1.3]
    VAR X_HOME_POSITION = [XH|A|X|1.3]
    VAR Y_HOME_POSITION = [YH|A|Y|1.3]
    VAR Z_HOME_POSITION = [ZH|A|Z|1.3]
    VAR SAFE_Z_HEIGHT = [SAFEZ|A|Z|1.3]
    + Block definitions for toolpath output
    + Commands output at the start of the file
    begin HEADER
    "o0001"
    "( [TP_FILENAME] )"
    "[N] G91 G28 [XH] [YH] [ZH]"
    "[N] G00 G21 G17 G90"
    "[N] G00 G40 G49 G80"
    "[N] G71"
    "[N] T[T] M06"
    "[N] G00 G43[ZH]H[T] M8"
    "[N] [S] M03"
    "[N] [XH] [YH] [F]"
    + Commands output for rapid moves
    begin RAPID_MOVE
    "[N] G00 [X] [Y] [Z]"
    + Commands output for the first feed rate move
    begin FIRST_FEED_MOVE
    "[N] G01 [X] [Y] [Z] [F]"
    + Commands output for feed rate moves
    begin FEED_MOVE
    "[N] G01 [X] [Y] [Z]"
    + Commands output for the first clockwise arc move
    begin FIRST_CW_ARC_MOVE
    "[N] G02 [X] [Y] [I] [J] [F]"
    + Commands output for clockwise arc move
    begin CW_ARC_MOVE
    "[N] G02 [X] [Y] [I] [J]"
    + Commands output for the first counterclockwise arc move
    begin FIRST_CCW_ARC_MOVE
    "[N] G03 [X] [Y] [I] [J] [F]"
    + Commands output for counterclockwise arc move
    begin CCW_ARC_MOVE
    "[N] G03 [X] [Y] [I] [J]"
    + Commands output at toolchange
    begin TOOLCHANGE
    "[N] T[T] M6"
    "[N] G43H[T]"
    "[N] [S] M03"
    + Commands output for a new segment - toolpath
    + with same toolnumber but maybe different feedrates
    begin NEW_SEGMENT
    "[N] G00 [SAFEZ]"
    "[N] [S] M03"
    + Commands output at the end of the file
    begin FOOTER
    "[N] G00 [ZH]"
    "[N] M09"
    "[N] G00 [XH] [YH]"
    "[N] M17"
    "[N] M30"
    Jan 2009
    104
    Re: NC Studio Coding
    remove or comment out all "[N] [S] M03" lines
    Nov 2011
    9
    Thanks mcode, but it didnt work.
    Could it be that the spindle is set to start outside the gcode?
    I added M5 and when the program starts, the spindle turns on , then off.
    As I am using a dragknife, its really important that it doesnt start at all.
    Jan 2009
    104
    I'm not familiar with the machine. Does the program have any M3's in it?
    if not maybe there is a parameter setting to disable the spindle from turning on.
    Jan 2009
    104
    you can try entering S1. in MDI before running the program which is modal and will turn the spindle
    on and off but at the lowest rpm possible when the spindle automatically starts. The only problem
    would be if the spindle has a low gear, which would not let the drag knife rotate the spindle easy enough.
    hope that helps
  1. 18T and coding
    By Darth Yoda in forum Fanuc
    Last Post: 02-28-2013, 04:26 PM
  2. Need help with coding
    By whitewishes in forum PIC Programing / Design
    Last Post: 08-15-2012, 04:31 AM
  3. New to G-Coding
    By Larry Myers in forum G-Code Programing
    Last Post: 09-20-2007, 03:06 PM
  4. G2/G3 Coding
    By jrobson in forum G-Code Programing
    Last Post: 09-02-2006, 06:54 PM
  5. Chook coding in Visual studio .net
    By EdOsgood in forum Mastercam
    Last Post: 10-01-2005, 09:14 PM
