603,884 active members*
5,929 visitors online*
Page 3 of 4 1234
Results 41 to 60 of 70
  1. #41
    Apr 2003
    1876
    Screenie..
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
  2. #42
    Apr 2003
    1876
    Screenie
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
  3. #43
    Apr 2003
    1876
    One more..
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
  4. #44
    Jan 2004
    21
    Rekd any chance to get hold of your last version of this program?
  5. #45
    Apr 2003
    1876
    Yeah, PM me monday and I'll get it.
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
  6. #46
    Jan 2004
    21
    Will do, thanks!
  7. #47
    May 2004
    600
    moved to new thread
  8. #48
    Apr 2003
    1876
    Quote Originally Posted by phillipmc
    ...(B) If I go with the computer beside the machine route: positive: better control of machine???, real time graphic display of tool path. negative: expensive computer sitting in a dusty environment.
    What's your thoughts everyone?
    Phil...!
    Have a look at this.
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
  9. #49
    May 2004
    600
    moved to new thread
  10. #50
    May 2004
    600
    moved to new thread
  11. #51
    Jan 2004
    21
    Quote Originally Posted by Rekd
    Your PM folder is full, cant send to you.
  12. #52
    Apr 2003
    1876
    Updated version of SComm.
    After you install, copy the SComm.EXE file to the install directory and over-write the existing one.
    If you have ?'s or !'s lemme know.
    http://members.cox.net/fuknrekd/Scomm Setup.zip
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
  13. #53
    Aug 2003
    27
    I was going to try your program but the last scomm setup.zip seems to be empty.?
  14. #54
    Apr 2003
    1876
    Quote Originally Posted by meconer
    Oops. Will upload a new one. That's weird.
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
  15. #55
    Apr 2003
    1876
    Ok. All better.
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
  16. #56
    Aug 2003
    27
    I tried to download it again from the link above and it seemed to be empty again. But then I right clicked it and chose to "Save link as" instead and this time it worked. Probably would have yesterday to. My bad. Sorry to have caused you extra work. I will try your software next week. We usually use cimco edit (mastercam version) to send/receive programs to one of our mills. But sometimes I need the hardware lock elsewere and then it's good to have an alternative.
    I used to use an editor I programmed myself in delphi years ago but after we got a new computer with xp the communication no longer works. I had big plans for this editor but the time to develop it never seems to come along. And now of course I have the cimco editor.
  17. #57
    Aug 2003
    27
    Hi again
    I tried your prog at work today. I had problems with the recieve module. When I sent from our Chiron mill with Fanuc 21-m I got everything on one long line. I didn't see any settings regarding this in your program. Are you aware of anything I can do to get around it? And by the way, thanks for your good work and for letting other people benefit from it.
    regards Mats
  18. #58
    Apr 2003
    1876
    The recieve portion has it's own settings, but does not include the option to add CR/LFs. There should be a setting on your machine's controller to send them, and SComm will pick them up.
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
  19. #59
    Jun 2003
    18
    Polling
    Rekd, How do you use polling with another program. Can you send a file using arguments ? Ex. scomm.exe,test.nc
    Could you explain a little of how polling is used?
    no problem!
  20. #60
    Apr 2003
    1876
    Quote Originally Posted by speedracer
    Polling and arguments go hand in hand. Yes, you can send a file name to SComm and have that file loaded for the send operation. (I haven't set it up to change any settings yet, except to optionally bring up a port select window)
    Code:
    SComm.exe c:\pathname\filename.ext
    With polling, if SComm is already running, the 'new' instance will send the file name to the registry, then exit.
    The 'original' instance will read the registry every 5 seconds to see if that 'key' has been modified. The value for the key is the file name. If there is a value detected, it sends that to the console and loads the port select option, if enabled. If port select is not enabled, it will just start sending.
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
Page 3 of 4 1234
  1. parametric programming
    By Karl_T in forum CamSoft Products
    Last Post: 05-24-2005, 08:58 PM
  2. How to cut multiple parts (loop a program)
    By Bird_E in forum Mach Software (ArtSoft software)
    Last Post: 05-13-2005, 09:16 PM
  3. feeds and speeds program
    By Kees Soeters in forum MetalWork Discussion
    Last Post: 05-12-2005, 06:32 PM
  4. A few honest questions
    By HuFlungDung in forum CamSoft Products
    Last Post: 06-16-2004, 12:24 AM
  5. G-Code Cutter Comp Program
    By jcc3inc in forum DIY CNC Router Table Machines
    Last Post: 02-27-2004, 05:29 PM
