588,169 active members*
4,613 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > NCFadal v1.3 - 95 4020 88HS question
Results 1 to 4 of 4
    Jul 2005
    84
    I have a 95 4020 with 88HS - cpu 1400-4 and am using NC Fadal v1.3 and the cable I found described by Gar on this forum. DB25: jumper 4&5 together, and 6,8 & 20 together and
    DB25 ---> DB9
    2 ---> 2
    3 ---> 3
    7 ---> 5
    No jumpered pins on the DB9 end
    I can download and upload programs no prob at baud 38400 - nice and easy, and pretty darn fast.
    In the program, it shows "radio buttons" where I supposedly can download from the machine, tool table, current program, all programs, axis summary - backlash (going from memory here)... But the only thing I can get is programs.
    If I try and get tool offsets or anything other than a program or all programs, I either get an error saying it cant communicate (only on one of them), or, I just get the program that is in memory.
    Was wanting to pull down everything from the machine just to have a back up to dig though and look at... without standing in the shop at the machine. Not to mention should all the memory get cleared, would be nice to have backups of everything.
    Im wondering if since the software I think is a few years newer than the machine, if its just a case that my control cant send some of that info, but the software is designed to get it if the control will send. And just wanted to make sure I wasnt doing something wrong. The NCFadal manual makes it look easy as pie...
    Wade
    Mar 2010
    software
    The older cnc software is unable to send the other opitions, programs only.you can go to command SETP and see the parameter list and write it down and the backlash is command BL.
    Mar 2003
    900
    You need a dash 5CPU in order to download via software.
    Jul 2005
    84
    Thanks, I wondered if it was a version thing or age of control deal... knowing the software is newer than the machine, it was my main suspicion.
    Wade
  1. BobCAD V23 on Fadal 4020 CNC88HS question
    By MBX5 in forum BobCad-Cam
    Last Post: 05-21-2014, 02:13 AM
  2. 4020 Spindle fault question
    By kentsui in forum Fadal
    Last Post: 11-01-2010, 11:46 AM
  3. Fadal 4020 88HS IMPORT / EXPORT
    By cam280 in forum Fadal
    Last Post: 06-30-2009, 03:14 PM
  4. VMC 4020 CNC 88HS language operation
    By krzysztofz1 in forum Fadal
    Last Post: 02-25-2008, 12:02 PM
  5. Ncfadal on xp
    By dango in forum Fadal
    Last Post: 02-11-2007, 05:46 PM
