Hi , I an new to CNC machining and have only basic knowledge.
I need a post processor file for Ucancam.
I have a new 3 Axis Machine with the below specs:
FC2030-12 ATC ?Taiwan Syntec FC60CA Control system
?China CC 9kw air cooling spindle,24000rpm/min
?Hiddlen Linear type tool Magazine with 12 Pieces ISO30 Tool Chuck
?1500w Leadshine AC servo motor and driver
?Vacuum PVC Table
?Working size 2070*3050*200mm
?Japan SHIMPO Reducer
?1.5M helical rack
?Taiwan CSK 30 square rails for Y axis ,25 for X and Z axis
?Fuling 11kw inverter
?Taiwan TBI Ball screw
?Automatic Oil Lubrication System with Aluminum oil pipe
?Aviation aluminum alloy thickening Machine head board
?German IGUS Brand cable
?France Schneider
?Automatic Unloading Function and Unloading table
?France Schneider Brand AC CONTACTOR and Fuse
?China made CHNT Brand Motor protector
?China 11.0kw 360m³ dry type vacuum pump
?5.5kw Double Bags dust collector
?3ph 380v 50/60hz
I am Using Ucancam software and need a Post processor file to output tool paths for my machine. Manufacturer has supplied a PP file for Aspire , I need it Edited to be compatible with Ucancam. All Features eg, vaccum,offload and Tool changes needs to be included in the file from what i understand.
Any guidance/help will be highly appreciated!
I have uploaded the file the manufacturer has supplied.(Fine CNC) And the Ucancam Sample Files. Renamed to .txt.
Also this is what i found on the Software manufacturers website, but cant make much sense of it yet.
post-????????????
