587,481 active members*
3,115 visitors online*
Results 1 to 7 of 7
    Apr 2010
    3
    Need advice re removing spindle
    I have a Bridgeport Series I CNC with a Kwik-Switch spindle. The Kwik-Switch has stopped working, it won't grab the tool holder. Worked fine until yesterday. It seems to me that I will need to remove the spindle to examine and fix the Kwik-Switch. But it looks like there is not enough room over the table to drop the spindle. My options appear to be:
    1) pull the head, mount it on a bench, then remove the spindle,
    2) rotate the head about the Y axis so the spindle is parallel to the table,
    3) rotate the ram and head about the Z axls, so the spindle stays vertical but is not over the table and there is room to drop it.
    I would appreciate any advice.
    Jul 2015
    20
    Re: Need advice re removing spindle
    Not familiar with the Kwik Switch itself ( Bridgeport had a variety of rapid-change noses - mine are for NMTB holders) - but for removing the spindled itself, I'd be surprised if you cannot drop the table enough to have the clearance necessary to remove the spindle. However, if there isn't enough, I'd go for rotating the head sideways.
    Jan 2005
    15362
    Quote Originally Posted by jrlandau View Post
    If you have to remove the spindle which I doubt you have to, depending on what model machine you have is to how you would have to remove it, series 1 Boss machines comes in more than one head type so a photo of your head would say how you would have to take it apart, the Kwik- Switch is removeable by it's self the spindle does not have to be removed to take it apart
    Here is some information on how to repair it
    Assembly and disassembly of Kwik-Switch II nuts and triggers on Spindles
    Kwik-Switch Master Lock Nuts
    Mactec54
    Sep 2005
    250
    You do Not have to remove the spindle. Look at the knurled nut that you put your hand on to remove the tools, there are a few holes in it look for ( i think it's brass if i can remember correctly ) a brass piece and push it in with a small screw driver and loosen the nut.
    There are a couple springs inside so be careful. One or both of these springs broke this is why it doesn't hold the tool.
    Sep 2005
    250
    Now that i think about it more there is a screw you have to remove in one of the holes...Remove it and loosen the nut.
    Apr 2010
    3
    Thanks, guys, for saving me from foolishly removing the spindle. I got the KS nut off and gave it a good cleaning (found no broken springs). So far, so good--seems to work now
    Jul 2015
    20
    Yes, many times just a simple cleaning will get the various holders to work again - they love to gunk up with dries coolant and tiny metal chips (especially cast iron powder), and then start to give problems.
  1. Removing the spindle cover on my 08' VF1
    By vance1911 in forum Haas Mills
    Last Post: 07-26-2017, 04:06 PM
  2. Removing the spindle pulley
    By Andre' B in forum Taig Mills / Lathes
    Last Post: 02-06-2016, 03:18 PM
  3. Replies: 3
    Last Post: 06-30-2014, 08:47 PM
  4. X2 - Removing the R8 Spindle
    By webgeek in forum Benchtop Machines
    Last Post: 04-03-2010, 06:28 PM
  5. Removing R8 key from X3 Spindle shaft
    By stag53 in forum Benchtop Machines
    Last Post: 04-23-2009, 01:46 PM
