587,792 active members*
4,087 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Engraving / Cutting Machine General Topics > Need advise on adding a laser for engraving to existing cnc machine
Results 1 to 4 of 4
    Hi all.
    Im currently finishing my vertical machine and have been thinking about adding a laser for engraving, mostly aluminium.
    I was inspired by someone who simply added a laser on the side of his spindle.
    Question far a laser noob is:
    What parts do I need? (PSU, Laser, software?)
    What power is sufficiant for ”deep” engraving. About 0.5mm into aluminium?
    Will it work using my existing setup with Mach3?
    Thankful for any insights.
    Pictures of first quick test of machine.
    Attached Thumbnails Attached Thumbnails EAF68417-C305-4089-A70F-695FF918A1CF.jpg   2600A1F6-7F65-4E20-B3C9-516F9B3C9C1F.jpg
    Jun 2011
    692
    Re: Need advise on adding a laser for engraving to existing cnc machine
    To engrave aluminum you need a fiber laser, in the kW power range I think. I think used models are $10k+
    Mar 2019
    3
    Talking Re: Need advise on adding a laser for engraving to existing cnc machine
    This may be something we can help you with!
    https://www.hanbury-autogil.co.uk/laser-systems/
    May 2018
    35
    Fiber laser can do the engraving.For the power,it also depends the size of your design file.If you file is complicated,then the speed will be slow.If the file you want to engrave is simple,then it will be faster.The speed lower when the working area larger.We have some fiber laser machines in our factory and can test it for you.
  1. Laser controller for existing machine
    By _Mark_ in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-04-2017, 01:13 PM
  2. Adding tabs to existing file
    By budpage in forum CamBam
    Last Post: 03-22-2011, 03:10 AM
  3. adding 4th axis to an existing mill
    By BiggerHammer in forum Uncategorised MetalWorking Machines
    Last Post: 12-25-2009, 04:18 PM
