587,603 active members*
3,988 visitors online*
Results 1 to 10 of 10
    May 2013
    204
    need aluminum and HDPE parts cut
    I have 2 parts that require machining.
    Part 1 is 1/16" thick 6061 aluminum. it is a rectangular bezel approximately 3"x2.5" with raduised corners. the inside of the bezel has a rectangular hole with 1/8" fillets at the corners. there are 4 x 1/8" screw holes in the bezel. tolerance in the bezel is 0.01"
    part 2 is 1" thick hdpe (1" black king starboard), the same outer dimension of the bezel with a .9" deep pocket in the middle with either similar radiused corners or dogbone fillets if you want to use a 1/4" endmill. tolerance on the plastic part is not terribly important so long as the pocket is not smaller than the hole in the bezel.
    I need 50 of each but would like pricing for 100 and 200 of each also. I can provide dimension drawings and cad files if necessary as well as materials.
    parts are needed, delivered in raleigh, nc within 3 weeks if possible
    Mar 2015
    178
    Re: need aluminum and HDPE parts cut
    Shoot me a PM
    Apr 2012
    51
    PM sent for info.
    Feb 2006
    196
    We would appreciate the opportunity.
    Please email your CAD information and contact information.
    Thank you,
    Doug Pryor
    David Wolfe Design, Inc.
    Akron, OH
    www.davidwolfedesign.com
    [email protected]
    May 2013
    204
    Pm me your email address and I'll provide drawings.
    Sent from my Nexus 5 using Tapatalk
    Feb 2014
    92
    Hi there,
    We are interested to provide quotation. Is this possible to send the 3D print to us at this email address [email protected]
    BR
    /SL Wong
    Sales Manager
    Proto Tree LLC
    Website: Proto Tree
    Email: [email protected]
    Feb 2012
    7
    Please send drawings and CAD files to [email protected]
    Sep 2008
    277
    pm sent
    Mar 2008
    22
    send any drawings and info to [email protected]
    May 2013
    204
    Request is closed
  1. Parts fitting clearances in acrylic and aluminum parts?
    By jbarber in forum Material Machining Solutions
    Last Post: 11-12-2010, 04:52 AM
  2. DIY router parts: HDPE vs cutting board
    By leaveme in forum DIY CNC Router Table Machines
    Last Post: 09-14-2010, 08:38 AM
  3. Small HDPE parts to engrave & cut
    By malcy in forum Australia, New Zealand Club House
    Last Post: 07-28-2010, 10:40 AM
  4. RFQ - 3 small hdpe parts and 1 mdf part (Indianapolis)??
    By DistortedDesign in forum Employment Opportunity
    Last Post: 11-06-2008, 05:47 PM
  5. Request fulfilled: RFQ - HDPE parts for JGRO CNC Design
    By Jtheletter in forum Employment Opportunity
    Last Post: 08-29-2006, 01:09 AM
