603,350 active members*
3,413 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Need to backup parameters on VF2 (USB)
    Hello,
    The flash drive that came with the VF2 just stopped working, so I need to make a back up of the parameters of that machine.
    Does anyone knows how to do that?
    Thank you
    jolulank
    Aug 2010
    579
    In the newest software version:
    1. Insert new USB
    2. Go to List Prog
    3. Select USB
    4. Type a file name (Serial number and model=good choice)
    5. Press F4
    6. Highlight "Save All"
    7. Press Write/Enter
    8. You should have several file names with different extensions.
    note: If you want to backup the probing files and other 9000 series programs, you need to turn off setting 23. You can turn it back on after the copy.
    Thanks,
    Ken Foulks
    Thank you!
    Thanks,
    I already did backup the parameters with the info you sent me.:banana:
    Jolulank
    http://www.cnczone.com/forums/images/smilies/banana.gif
    Quote Originally Posted by KenFoulks View Post
    1. Insert new USB
    2. Go to List Prog
    3. Select USB
    5. Press F4
  1. 810M-810T Backup parameters
    By nabil_elbadri in forum SIEMENS -> Sinumerik 810M/810T
    Last Post: 12-27-2013, 06:49 PM
  2. Replies: 0
    Last Post: 07-22-2010, 02:03 PM
  3. Meldas 64M Backup
    By Hypnotique in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-13-2009, 05:24 PM
  4. Replies: 1
    Last Post: 11-28-2008, 03:22 PM
  5. Fanuc 11M Backup Parameters?
    By giantcake in forum Fanuc
    Last Post: 07-23-2007, 03:34 AM
