I have an application where I need to output a 0-10V analog signal at least 14 bit would be nice, may settle for less. I would like to use a PLC to output a certain voltage when a certain input is active. For example, I would like to have 8 switches connected to the PLC. When I push button 1, the PLC outputs 1V, button 2 outputs 3.7V, etc. The voltage values are arbitrary and I would like to be able to set them using buttons and a small lcd screen on the PLC. That way I could change the voltage output for each button, use them for awhile, then change them to something else when I needed to. I have used zelio smart relays in the past and they have everything I need except an analog output. Something similar is what I am looking for.
Something like this but with analog output: http://www.us.telemecanique.com/prod...lay/index.html
Any suggestions?
Matt
